BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) SOS Error
      11-30-2021, 03:05 PM   #1
andylew0
andylew0's Avatar
Wales
Drives: BMW X2 S 2.0
SOS Error
Is it possible to code out the SOS on the X2 ? I’m use the VCDS/VAG com.
Can’t decide if I need Bimmer link or Bimmer code. I’ve seen it being done using Bimmer Code but not for the X2.
Thanks
Andy.
      12-08-2021, 03:56 AM   #2
maximking
108
Drives: F10
you need Enet Cable for bmw jobs . i can help you out remotely code out the SOS error
      12-10-2021, 10:13 AM   #3
andylew0
andylew0's Avatar
Wales
Thanks for the offer, just coded it out with Bimmercode
      12-19-2023, 01:19 PM   #4
jehill
Drives: 2019 X2
Coding to eliminate SOS error
Hi. Can you provide the coding for Bimmercode that worked for you? I have an F39 and searched in Instrument cluster and elsewhere but can't find anything related to the TCM. Thanks
      12-19-2023, 02:14 PM   #5
chowser51
chowser51's Avatar
2025
Drives: F33 430 and F39 M35i
Instrument Cluster in Expert Mode -> 3001 CC_ID_Sperre -> CC_AKTIVIERUNG_5 -> Byte 5 -> CHANGE FROM 0xFF to 0x F7
      12-23-2023, 11:09 AM   #6
jehill
Drives: 2019 X2
Thanks chowser51. Had already found the coding elsewhere and fixed it before I saw your reply. Maxiking, there are a number of OBD2 scanner options to connect Bimmercode besides Enet cable. I used the Android version of Bimmercode with Vgate icar pro bluetooth.
