BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Wheel Spacers for the X1 (F48)
      04-20-2018, 02:28 PM   #45
bimmerdriver2
bimmerdriver2's Avatar
180
Drives: 2020 M2C DCT
Wheel spacers can make a noticeable difference to handling, and not always for the better. IMO, the biggest affect is caused by increasing the scrub radius. I increased the front spacers on my car from 10 mm to 15 mm (so I could move the 10 mm to rear) and I noticed the difference right away. The steering was more sensitive and twitchy, especially at turn-in. I got used to it, but not everyone will appreciate such a change.
Here is a link about spacers with separate links to sub-issues such as scrub radius: Wheel Spacers & Adapters - Good Or Bad?
DARKMTTR229.00
      05-04-2018, 02:02 PM   #46
DARKMTTR
DARKMTTR's Avatar
229
Drives: '20 M2 Competition & '18 X1
Originally Posted by 808X1 View Post
I like the ECS Spacers . I now run 15F and 15R. When I was running 20R, there were no drastic changes that I could discern for every day driving, but there was more understeer at 7/10 during cornering; however, when I went to 15R, cornering was a bit more neutral and less understeering than the prior set up. Despite this, the car was more stable in the corners with either set ups due to the wider stance, I suppose.
Awesome to hear! I look forward to getting them installed tomorrow. Thanks!
2020 BSM M2 Competition | Blue Stitching | 6MT | Sunroof | My M2C European Delivery Story! | AA EL Midpipe | TMS Skid Plate
      05-07-2018, 03:48 PM   #47
hbing
Drives: X1 SDRIVE
Could you show us what these spacers look like?
      05-07-2018, 04:01 PM   #48
hbing
Drives: X1 SDRIVE
Hey 808X1, Why do you return to 15F and 15R? had a problem with the 20R ?, can you send us images of the current configuration?
      05-09-2018, 02:37 AM   #49
808X1
80
Drives: F48 X1 M-Sport
20R gave me more understeer at 7/10. Will get u images of 15F & 15R soon
      05-09-2018, 02:38 AM   #50
808X1
80
Go to ECS Tuning website and you will find those spacers.
      05-09-2018, 07:25 AM   #51
hbing
Drives: X1 SDRIVE
thanks, I'd like to see what the car looks like with this configuration.
      05-09-2018, 07:28 AM   #52
hbing
Drives: X1 SDRIVE
Hello MSport X1, I'd like to see what the car looks like with this configuration, 15F 20R
      05-09-2018, 01:17 PM   #53
mr_lab_rat
mr_lab_rat's Avatar
565
Drives: 2017 M2, 2018 X1
I took some pics of 15F/20R spacers with stock wheels -
View post on imgur.com
The tires are a bit bulkier than stock (winter tires)
      05-09-2018, 07:18 PM   #54
hbing
Drives: X1 SDRIVE
Thanks, with this configuration it looks great
      05-10-2018, 08:41 PM   #55
808X1
80
Here is the 15F/15R version:
      05-11-2018, 06:25 PM   #56
hbing
Drives: X1 SDRIVE
Attachment 1822326
Attachment 1822328
looks very good, it seems that it is better to increase the same size forward and back
      05-11-2018, 08:04 PM   #57
808X1
80
In my case, yes. The handling is better in my experience.
      05-15-2018, 01:49 AM   #58
alex809809
Drives: X1 20i
Does anyone know if the 19'' wheel (R9J, ET45) with 245 40 19 tyre can fit F48 X1? Do i need to add spacer?
      05-17-2018, 12:37 AM   #59
mr_lab_rat
mr_lab_rat's Avatar
565
I don't know how much space there is between the rim and the shock.
This setup would be 13mm closer to the shock on the inside so it might interfere. On the outside it would be 25mm wider so pretty much flush with the fender.
8.5 width would be a safer fit.
      01-21-2019, 02:10 AM   #60
TSiSPY007
70
Drives: 13 335i xDrive;16 X1;96 4G63T
The understeer issue was when you ran 15mm Front and 20mm Rear... so, it shouldn't be an issue if I go 20mm Front and Rear, especially in day-to-day mixed city/highway driving, correct?
Likely going to order from ECS soon, unless there are other viable options.
Thanks, guys!
Fred
      01-21-2019, 08:00 PM   #61
808X1
80
Thanks, guys!
Fred
Possibly yes.
      01-29-2019, 10:05 AM   #62
Proper
Proper's Avatar
100
Drives: X1 M-Sport
I went with 12.5mm all around from Turner Motorsport, but I am running the factory 19x8's.
      02-16-2019, 06:58 PM   #63
ventjock
65
Drives: 2020 M340i
I currently have 225/50/18 winter tires with 18X8 ET 40 wheels. I just ordered H&R sports springs and I'm looking to add some spacers for a flushed look.
Looks like I should be able to place 15mm spacers on the front and rear unless I'm missing something. Any input is appreciated.
Thanks in advance
      02-19-2019, 08:35 AM   #64
Proper
Proper's Avatar
100
Drives: X1 M-Sport
Thanks in advance
Are they factory 18’s? Or aftermarket ?
      02-19-2019, 04:53 PM   #65
ventjock
65
Drives: 2020 M340i
aftermarket, MSW Type 48 wheels
      02-19-2019, 08:28 PM   #66
Proper
Proper's Avatar
100
Drives: X1 M-Sport
Im running the factory 19's right now. 19x8 ET47. With my 12.5mm spacer im at 34.5 and im pretty flush I could prob go a little more but honestly its perfect right there. You'll be at 25 with a 15mm spacer. Id go conservative and maybe get the 5mm? Get the wheels in and mount them up. If its not enough, measure where you want to be and order up what spacer you want to get.
Turner Motorsport had my spacers available and shipping was free and fast.
