10-24-2020, 08:44 AM | #1 |
On the Go!
79
Rep 235
Rumble / crack / rattle
Anyone notice & have a fix for this weird type of rumble / creaking noise at lower speeds (<25 mph) as if it were coming from under the car?
Car: MY16, early build date; <22000. Did some research and found this PUMA registered with BMW -> (in German; chrome auto translates to English) https://www.motor-talk.de/forum/knac...07.html?page=2 However, after reading the 16+ pages of comments, I realized some of the symptoms are same: I get it when when the car is warmed up, even on right turns and even when its 90F outside. Appreciate your help!
It doesn't matter if you win by a mile or inch, Winning is WINNING!
10-24-2020, 05:19 PM | #2 |
282
Rep 1,491
There are three TSBs that may be relevant:
BMW Service Bulletins concerning front end/suspension knock/clunk TSB for knocking noise from engine compartment. Cause is a damaged right side engine mount. Service bulletin #B22 02 17. And there another TSB for creaking noise when cornering. Cause is the rubber transmission mount rubs on the aluminum housing. Service #B22 01 17. Third TSB (ref unknown) says to change both front left and right control arms with a revised control arm for certain production dates — original parts both defective from factory 414 234 668
Peugeot T9 308 GTi 270 Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182. |
NotSooFast79.00 |
