10-18-2020, 11:31 AM | #111 |
10340
Rep 40,302
Drives: 2018 Alpina B6 650ix GC
Flashing has no effect on FSC Codes.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
11-01-2020, 10:32 AM | #113 |
10340
Rep 40,302
PM sent.
11-04-2020, 03:35 PM | #115 |
10340
Rep 40,302
PM sent.
11-11-2020, 04:38 PM | #117 |
10340
Rep 40,302
PM sent.
11-21-2020, 04:34 PM | #118 |
Rep 121
Trying to understand the process to upgrade my 2017 X1 with EntryNav to a second hand EntryNav2. What I think I understand is:
1) It doesn't matter what year or model the EntryNav2 came from. But if my car is a US car, then I should look for a US EntryNav2 Unit. 2) A NBT emulator is needed. With this, all options/FSC's on the donor vehicle will be retained (Nav, Satellite Carplay if I can find one) 3) With an emulator, no coding is needed. Can anyone confirm the above assumptions? Questions re activating Carplay: 1) Is there any advantage if the original car had Carplay Prep? 2) Any advantage to donor car having Nav? I think I read that Nav FSC must be purchased too, if the car doesn't have it. 3) Where is the least expensive source for the Carplay FSC Code? Thanks in advance for any help! Last edited by stealth1; 11-21-2020 at 04:51 PM.. |
11-21-2020, 06:07 PM | #119 | |
10340
Rep 40,302
Why not get better EVO Head Unit, and bypass the Emulator altogether?
11-22-2020, 05:49 PM | #120 |
Rep 121
Shawn,
Thanks for your insight. I was only considering ENTRYNAV2 because carplay is the only missing/upgrade feature that really matters to me besides Satellite, and I thought it would be a more cost effective solution than EVO HU (and I really don't like the aftermarket via aux options). Re EVO unit upgrade, wouldn't this also require an ATM swap and new $$ wiring harness? In the case of an EVO upgrade vs ENTRYNAV2 upgrade, is the coding work essentially the same? |
11-22-2020, 07:40 PM | #121 | |
10340
Rep 40,302
Coding for EVO is of course different, but same in terms of ease.
11-23-2020, 02:57 AM | #122 |
1751
Rep 3,050
He has Entrynav so there is no ATM in his X1
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
11-23-2020, 09:15 AM | #123 |
10340
Rep 40,302
Telematics is overrated.
11-24-2020, 07:02 PM | #124 |
Rep 62
So, I finally have a 100% fullscreen carplay working on my 2018 X2. Big thanks to kubax86
We had to upgrade the firmware and then code the fullscreen carplay. Everything was done remotely. And it took about 20min total. Maybe less, but not more. He clearly knows what he is doing. Reach out to him if you want fullscreen carplay on your X1's and X2's. It's finally available and you won't regret. Thanks again my friend! |
11-25-2020, 04:42 PM | #125 |
Rep 121
11-25-2020, 04:45 PM | #126 |
10340
Rep 40,302
Both ENTRYNAV2 and EVO have ATM if car is equipped with Telematics.
11-25-2020, 04:52 PM | #127 |
Rep 121
11-25-2020, 04:56 PM | #128 |
10340
Rep 40,302
No. ATM is not a requirement. It there only if Telematics are installed / needed.
11-25-2020, 05:08 PM | #129 |
Rep 121
11-25-2020, 05:39 PM | #130 |
1751
Rep 3,050
Without ATM, if you want to use GPS functions you need headunit with Built-in GPS (blue plug).
11-26-2020, 02:56 PM | #131 |
Rep 121
11-26-2020, 04:55 PM | #132 |
1751
Rep 3,050
You need different USB cable or rotate it, CID cable and depends if you will get Headunit with GPS or you're going to retrofit ATM. So many variables.
