04-25-2024, 02:11 PM | #1 |
384
Rep 1,203
Drives: 2021 M2C
Spun crank hub! Looking reputable shops in the Toronto area
Sooooo my S55 spun it's crank hub. Dealer won't warranty it because of a tune, and wants at least $2200 just to look at it as it requires disassembly of the engine. And that's not even including the cost of the fix. Since it'll cost that much I may as well get a proper aftermarket crank hub fix. Any shop around the Hamilton or Toronto area that has good experience with the S55 crank hub fix? A quick search pulls up RMP Motors in Etobicoke as the place to go but the fastest they can get my car in is mid May. Any other shops I should look into? The car is still drivable but with far less power so hopefully no other damage has been done.
04-25-2024, 02:40 PM | #2 |
26
Rep 87
RMP or Eurocharged.
If car drives then you’re lucky. You need to get it re-timed etc..not as bad a full build. Just don’t drive it. Have it towed to one of those two spots get it checked out and re-timed. Then do the full crankhub fix. |
04-25-2024, 06:35 PM | #3 |
21
Rep 179
I’m selling unused crank hub if you are interested.
https://f80.bimmerpost.com/forums/sh....php?t=2096827 |
