TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      03-15-2019, 01:27 PM   #1
9vapors
652
Drives: CB X5M
What Did You Do To Your E70 Today?
Most forums have this thread, they usually do pretty well and have some interesting stuff. Even small things, pictures, anything!
pdX5M111.50
      03-15-2019, 01:29 PM   #2
9vapors
652
Drives: CB X5M
I'll start it off...
I installed some heat wrap onto the crossover pipe that likes to crack from all the heat. Maybe it will help, maybe not. Might be worse! But it's supposed to reflect and protect, and I'm a believed with the tape on my intake pipes. They went from not being able to touch them to a cool to the touch feel.
I also got rid of the final thin hose clamp on the intake side... I kept ordering the wrong size t-bolt clamp...
Appreciate 6
      03-15-2019, 01:40 PM   #3
pdX5M
pdX5M's Avatar
112
Drives: E70 X5M
2013 BMW X5 M  [0.00]
Today I gave the M a thorough cleaning. Went over some mountain passes for work this week and needless to say it was the dirtiest any car I've ever owned was. Pic shows everything that washed off - the driveway isn't red that's just all the dirt they throw on the roads. Dirt baked onto the exhaust tips as well so polished those up after this pic.
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
Appreciate 3
9vapors651.50
Nexo13.00
      03-15-2019, 01:47 PM   #4
9vapors
652
Drives: CB X5M
Awesome man, looking good. Jealous of those headlights!
      03-15-2019, 01:52 PM   #5
pdX5M
pdX5M's Avatar
112
Drives: E70 X5M
Thanks man I'm loving the LED headlights as well! Wonder if the laser headlights will be on the new X5 M when it comes out. Now those are something to drool over!!!
This thread is an awesome idea. I'll eventually start a journal as I install all the mods I have lying around but this is good for the little things we tinker with day in and day out.
9vapors651.50
      03-15-2019, 03:28 PM   #6
Yanchii
Moldova
59
Drives: 09 BMW X5 35D
Today I'm working on getting this bad boy installed!
Appreciate 2
9vapors651.50
Nexo13.00
      03-15-2019, 03:45 PM   #7
Yanchii
Moldova
59
I used the same heat tape too, I love it!
9vapors651.50
      03-15-2019, 05:17 PM   #8
pdX5M
pdX5M's Avatar
112
Drives: E70 X5M
Is that a FMIC? Which E70 are you driving?
      03-15-2019, 08:27 PM   #9
Yanchii
Moldova
59
Yes sir! 09 X5 35d !
      03-16-2019, 06:50 AM   #10
Deftronix
170
Drives: 12 X5d & 20 X7 M50i
How did the install go? There are a couple small modifications that need to be made on the bumper bracket correct?
Need to get around to installing mine sometime soon but want to finish the catch can first so I avoid spraying the new clean ic down with oil!
      03-16-2019, 11:49 AM   #11
Yanchii
Moldova
59
It took me about 4 hours from start to finish I did have to do some trimming with a dremel, it honestly wasn't to bad, it just requires some patience lol I had my brother in law help half way through which made it much easier! They make catch cans for the M57??
      03-16-2019, 01:20 PM   #12
Yanchii
Moldova
59
      03-16-2019, 01:48 PM   #13
Deftronix
170
ATM had sent me a PDF on the modifications, it didn't look bad at all. Glad to hear it was straight forward for you. Did you end up doing their ASV elbow as well?
No kits made for the M57 but will be plumbing in a Provent 200 with a custom PCV plate to run an elbow fitting off of.
Here are the parts I have on hand so far:
MANN Provent 200 - 3931070550
MANN Provent Check Valve - 2400843621
Moroso Dry Sump/External Oil Pump Fittings - 22622
Fragola Performance Push-Lite Hose Ends - 209016-BL
Fragola Performance 16AN bulkhead nut - 492416-BL
Patrick Motorsports 24mm-ID Braided hose - 6ft - HAR 930 107 394 5M
HPS 32-37mm Stainless Steel T-Bolt Clamps x 4 - SSTC-32-37
Custom milled PCV plate
Check out this thread - 35d: adding crankcase breather oil separator
Still need to figure out what I'm going to do for the oil return. Wanted to do it in a cleaner way than a brass tee fitting JB welded into the middle of the dip stick line like was done in the thread so haven't ordered those parts yet.
      03-16-2019, 02:54 PM   #14
Yanchii
Moldova
59
Yes I got the ASV Elbow figured might as well do it too, ahhhh I will definitely look into that! Once you get around to it, if you get the chance to take pictures and any info that can help me do it to I would appreciate it! I'll probably get it done down the road as well! Not a fan of JB welding things either so I feel you lol
      03-16-2019, 04:51 PM   #15
laselvasurf
102
Drives: 13 X5M/Ford Raptor/19 BMW i3
Swapped out the original X5M rear badge for an all black one. The //M was fading, so I thought I'd try a different look.
2013 X5M
2011 X5 35D Sport Package
2002 M3
2019 i3
Appreciate 3
TTV8M125.00
      03-16-2019, 05:45 PM   #16
pdX5M
pdX5M's Avatar
112
Drives: E70 X5M
Looks good man. Going the same route soon.
      03-16-2019, 07:51 PM   #17
9vapors
652
Drives: CB X5M
Yup nice work, should have come factory that way...
I washed mine!
Appreciate 2
      03-17-2019, 12:09 AM   #18
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
I washed mine!
Love the wheels
Appreciate 2
9vapors651.50
      03-17-2019, 12:16 PM   #19
laselvasurf
102
Rear brakes on my wife's 35D and admiring the black emblem on the //M... The M3 has been a bit neglected lately, had to buy a battery tender for it yesterday as it was dead. Looking forward to some warmer days get some top down cruises in!
2013 X5M
2002 M3
2019 i3
      03-17-2019, 12:24 PM   #20
9vapors
652
Drives: CB X5M
Awesome man, looks you guys have a nice stable there!
      03-17-2019, 02:26 PM   #21
sunny_j
sunny_j's Avatar
211
Drives: 2012 X5d
Installing M roof rails on my X5d today. Took 4 hours to remove the headliner and stock roof rails
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread
https://www.xbimmers.com/forums/show....php?t=1529213
Appreciate 5
9vapors651.50
RL18276.50
      03-17-2019, 02:29 PM   #22
boneca
boneca's Avatar
2025
Drives: 2022 BMW X5
2013 BMW X5M  [10.00]
2011 BMW X5  [10.00]
nice going guys, if somebody started this thread 3-4 years ago we would be on part 7 by now
anyway I took my car to town today, had to bring my gf's sun to bus station (college break is over) Boston streets are pretty tiny and half of those streets are brick sidewalks...
I'm flying to China in couple of days so I'll probably be MIA for couple of weeks...
cheers and Happy St. Patrick's day
Appreciate 2
