BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Bimmercode Adventure
      04-29-2019, 04:23 PM   #177
xlr8it
xlr8it's Avatar
30
Drives: F48 X1 20d, SLK55AMG
Just tried it in mine, works like it should with the little flag coming on in the dash, the car is a 2016 20D Xdrive
      05-07-2019, 07:44 AM   #178
Takabo
Takabo's Avatar
Japan
49
Drives: G21 320d xDrive Touring MSport
Hello everyone.
The F20 iDrive (ID4) was able to display the GPS trajectories.
However, the F39(F48) iDrive (ID6, Professional) can not display GPS trajectories.
Do you know the setting for displaying the GPS trajectories of ID6? Thank you.
      05-17-2019, 03:55 PM   #179
StefanJ
StefanJ's Avatar
68
Drives: BMW X3 G01 xDrive 20d
Hello everyone!
I want to share with you a small coding that I discovered. For me it is useful.
The coding is for "Bord computer autoreset time interval".
On my car (F48 sDrive 18d 2016), this default time interval was 4 hours and there was no option to change it.
So, here it is:
Instrument Cluster ->>
change to Expert mode ->>
3000 Anzeige_Konfiguration ->>
search for BC_AUTORESET_ZEIT ->>
press CUSTOM VALUE ->>
enter the time interval you wish, like this: 02 = 2 h; 08 = 8 h; or whatever you want.
Then choose this new added option and CODE .
The new time interval will be used from now on.
      05-26-2019, 10:54 PM   #180
StefanJ
StefanJ's Avatar
68
Hello!
I own an X1 sDrive 2016, manufactured for European market. The car came with only one central locking button, on the driver door (left) and with a blanking plate in the similar position on the right door.
I installed a central locking button on the right door, but it is not working. The only thing that it is working on the button is the illumination light. The car has already the necessary wiring, factory installed.
Maybe it is a coding that can be made/ modified, in order to make functional both door buttons.
Does anyone know?
Regards!
      05-27-2019, 02:36 AM   #181
SDriver18i
SDriver18i's Avatar
80
Drives: BMW X1 s18i 2019
Fog lights with welcome lights would be nice. Does anyone knows how to do it on the X1?
Edit: P.S: If anyone wants code their rear lights and their blinkers, go here > https://f48.bimmerpost.com/forums/sh....php?t=1618231
X1604M57.00
      05-27-2019, 12:18 PM   #182
ejw2011
ejw2011's Avatar
94
Drives: x3 F25 35i, x1 F48 28i
[QUOTE=Neworgri;24836092]Fog lights with welcome lights would be nice. Does anyone knows how to do it on the X1?
Edit: P.S: If anyone wants code their rear lights and their blinkers, go here > https://f48.bimmerpost.com/forums/sh....php?t=1618231[/QUOTE
If you have bimmercode app under FEM there is an option to select fog lights to enable with welcome lights.
      05-27-2019, 02:16 PM   #183
SDriver18i
SDriver18i's Avatar
80
Its not there. I have BDC not FEM. I tried to modify the settings from the F30 sheet in expert mode> MAPPING_NEBELSCHW_R_PART_OF > Didn't do anything at all.
      07-17-2019, 09:40 PM   #184
kavatski
147
Drives: 2023 X3 30iX
Originally Posted by celo View Post
  • Q3: : For those of you who have coded folding mirrors with Comfort locking, I have a question around timing. If I close my car from the key fob, the mirrors fold instantly, there is no need to long press the close button on the fob. If I try to close the car using Comfort locking, there is a slight delay, i.e. I have to leave my hand over the handle for about 1/2 second more or so to actually fold the mirrors even after setting the delay to 0. If I just tap the handle it closes the car...but the mirrors don't fold, I have to tap and hold for around a 1/2 - 1 second to get the mirrors folding. Are you guys seeing the same behavior?
I have to resurrect this one because mine is the exact same way, and after reading through all the coding threads I can't tell if that's just the way it is, or what. I have the delay set to zero but as above, it only works instantly from the fob. From the door handle I have to hold the ridges for about half a second and then the mirrors fold... but the sunroof cover also starts to close and the windows start to roll up, if open, even though I have the sunroof delay set to 3.5 seconds and the windows to 1.5. So that seems weird.
I've checked and double-checked and all the settings seem right, but I can't get it to fold the mirrors (and nothing else!) with just a touch of the ridges. Can anyone who's done this coding confirm how theirs actually works? If I'm trying to do something that isn't possible it'd be nice to know.
      07-20-2019, 07:30 AM   #185
xlr8it
xlr8it's Avatar
30
I have coded mine for zero as well and it works just as you described, instant with the fob only
      07-20-2019, 11:05 AM   #186
kavatski
147
Thanks, much appreciated. The description in Bimmercode makes it sound like locking via fob or handle should work the same, but since it doesn't, I wanted to check.
      07-20-2019, 02:15 PM   #187
CliveL
163
I'm not sure if it's the same with Bimmercode, but when I set the delay to zero in eSys, I lost the ability to lock the car and disable the interior sensors (pushing the lock button on the fob a second time within a couple of seconds of the first press). I need this for the odd occasion when we leave the dogs in the car to run to the shops or whatever. This might be worth checking if it's a feature you use, otherwise you might not know until your alarm goes off when you think the interior movement sensors are disabled, and they're not...
      07-22-2019, 11:58 AM   #188
kavatski
147
Thanks for pointing that out. Disabling the interior sensors isn't something I'll likely need to do, but it never hurts to be aware of unexpected side effects of coding changes!
      07-23-2019, 03:25 PM   #189
halcyon026
Drives: 2011 E70 35i
Does anyone know if it's possible to get enable a gear indicator? I'm using Carly to code and there are options to enable it, but even with it enabled nothing shows.
It doesn't even seem like the cluster has a space to display the gear. Not even D, N, R.
      07-24-2019, 12:48 AM   #190
xlr8it
xlr8it's Avatar
30
Mine shows the gear in the tacho section
      08-04-2019, 04:12 PM   #191
pandauk
28
Mine does also - though it is the newer black instrument panel.
      08-04-2019, 07:56 PM   #192
ejw2011
ejw2011's Avatar
94
I too do not have the gear indication on dash either.
Not sure if it's MY, country specific, car options, ...?
      08-12-2019, 11:31 AM   #193
ccIndianRider
ccIndianRider's Avatar
France
Drives: X1 F48 xDrive 20i xLine 2018
I think there is a gear indicator only when you use the sport position with manual operating (automatic gear lever on the left position)...
BMW X1 F48 xDrive 20i xLine 06/2018
Indian Motorcycle Chief Vintage 03/2014
      08-12-2019, 11:43 AM   #194
ccIndianRider
France
Since about 3 weeks, I have 5 instead of 3 flashes on the turn indicators without doing anything new.
I don't understand why, because I did a coding change for that in september of 2018 that done no change (always 3 flashes).
I'm using my car since 2018/06/30 and there was only 3 flashes for a year and one day there was 5 flashes...
I don't understand why or how the change came, but I'm very happy with this !
      08-12-2019, 04:24 PM   #195
ejw2011
ejw2011's Avatar
94
Even in sport manual shifting there is no gear indication. It shows no gear change indicator in either m/s or normal gear shifts.
Bringing to dealer to diagnose.
      08-12-2019, 05:08 PM   #196
Skyline2.0
Drives: 2018 BMW X1 xDrive
I noticed this same exact change about 2 months ago and had the same coding difficulties back then. I suspect BMW did an over the air update to add this option as part of the car's stock functionality.
No complaints here either!
      08-12-2019, 05:46 PM   #197
kavatski
147
Interesting. Just checked our 03/19 build 2019 and the choices are 1 and 3 flashes, no option for 5. I prefer 3 so I'm not complaining, but I wonder if I coded it for 5 now, the option for 5 would appear.
      08-13-2019, 08:28 AM   #198
DARKMTTR
DARKMTTR's Avatar
229
Drives: '20 M2 Competition & '18 X1
Has anyone successfully coded trunk closing with the key fob? I activated the option on Bimmercode but it doesn't seem to work.
