BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Brake Pads Replacement
      05-30-2020, 05:46 AM   #1
rameer
Drives: 2016 BMW X1
Hi Everyone,
My 2016 X1 has about 110000 KMs and showing a warning for front brake pad replacement. I took it to my local mechanic and he said there is still quite a bit life left on the them. But my car says keeps on showing the warning. Not sure who should I go with.
Anyone has similar experience? Your input is greatly appreciated.
Thanks
      05-30-2020, 08:59 AM   #2
Beagler
75
Drives: Sept 2019 Facelift X1 MSPORT
You may have three choices,
1 Ignore the warning but frequently check pads
2 Disconnect the wire On the pads and hope the warning goes but frequently check pads.
3 Renew brake pads.
Everthing goes to Entropy in this Age.
rameer5.00
      05-31-2020, 05:15 PM   #3
rameer
Drives: 2016 BMW X1
3 Renew brake pads.
Thanks for your reply. Now the warning light turned red and it's annoying as it's status for the whole drive. I don't notice any difference in braking at all, not even a small sound. But I am thinking to replace them soon.
      05-31-2020, 10:01 PM   #4
rice_rocket88
No_Country
298
Drives: E60 F48 F39
So unless it's for brake SERVICE which means it's simply time to look at it and/or reset the reminder. If it is literally for low brakes, there's a sensor inside the pads that once it hits metal/the sensor it goes nuts. In that case maybe the mechanic was lazy and just looked at the outside of the visible pad, and the inside is worn down to the metal. I'd get a second opinion on that.... Brakes are a relatively cheap option to change, especially pads. Unless you're totally certain that's the issue I would just go ahead and change them along with getting a new sensor that should be pretty cheap.
      06-01-2020, 01:19 AM   #5
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
There is also a tool used by dealers that they insert into the calipers that measure the thickness of the pad left. The mechanic should have used that.
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      06-02-2020, 07:16 PM   #6
mr_lab_rat
mr_lab_rat's Avatar
565
Drives: 2017 M2, 2018 X1
Originally Posted by rameer View Post
Hi Everyone,
Thanks
There are 4 pads in the front, only one has the sensor. I got unlucky and the one with the sensor wore out first, the other three were still good
Anyway, you should just change them, over 100k is very good.
      06-05-2020, 05:48 AM   #7
rameer
Drives: 2016 BMW X1
Hi Everyone,
Thanks
So I took the car to couple other guys, not an actual BMW service Center and they all told the pads and rotors have to be replaced. One guy took the wheel out and showed me the sensor. It is touching the pad and he said it's almost time to change. Surprisingly one said rotors are in a worse shape and there also quite a bit pad left. But the other guy said the pads needs to be changed but the rotors are okay. Not sure whose advice to follow. But it costs the only a little bit more change the rotors along with pads, not including the price of rotors. So I decided to change them all. Thanks for your advice everyone who responded.
      06-05-2020, 05:30 PM   #8
lonegun
Drives: BMW X1 F48
You can get a set of rotors and pads on Amazon cheap. Then bring those to your mechanics or dealer ship.
      06-06-2020, 08:17 AM   #9
rameer
Drives: 2016 BMW X1
The problem is most mechanics wants to get the parts from their source and don't like if I get them. I have asked many places and pretty much everybody is same
      06-06-2020, 11:02 AM   #10
Millie
Millie's Avatar
120
Drives: a bmw.
That's because they make money off their own parts.
It's very easy to replace the pads and sensors if you have access to tools. Everything is on Youtube these days.
2022 Nissan Armada (big couch)
2017 Camaro SS 1LE - Gone
2008 SSII E90 6MT - Gone
2009 SG E92 DCT - Gone
      06-07-2020, 02:38 AM   #11
Feddersen
Feddersen's Avatar
Denmark
451
Drives: X1 xDrive25i
An easy way to do it yourself is to use unbraco keys. They can be slid between the brake disc and the pad metal part. The thickest you can slide in between is about the thickness of the remaining brake pad. When the pad gets too thin there is a risk of disintegration for the remaining pad during heavy breaking so I wouldn’t go much below 2 mm.
