06-24-2020, 12:55 PM | #1 |
Rep 21
FS: Like new Genuine BMW car cover for F30 / F32...
This is a slightly used like new F30 or F32 cover with storage bag... I will ship if buyer pays shipping. Turner Motorsports description... Get a car cover that is custom fit for your BMW, not some generic one size fits all available from other suppliers. This Genuine BMW car cover is custom fit specifically for the F30 3 series Sedans. It features the BMW lettering on the front. NOAH barrier fabric actually stops water, yet it "breathes" to allow any trapped moisture, seam seepage or condensation to easily evaporate. The unique construction process (patent pending) results in a cover with maximum all-weather protection…highly water resistant, dust resistant, UV resistant and breathable to make sure moisture and/or heat don't stay under the cover. Made in the U.S. the fabric weighs only 4.75 oz./sq. yd., so it's easy to handle and fold. Protective Outer Layers - A bi-component spunbond, using sheath-core technology. The inner core is polypropylene for strength, with a polyethylene wrap for softness. A silver-gray color was selected because of its heat-resistant properties. The fabric is also treated with UV inhibitors for extended outdoor use. Micro-Porous Middle Layer - The barrier layer is breathable film, a proprietary stretch-film technology. The film is stretched and subjected to a chemical process that creates microscopic holes smaller than droplets of water or dust, yet large enough to allow moisture vapor to escape. Soft, Paint-Protecting Inner Layer - A bi-component fabric made with polyethylene and nylon. This combination results in an exceptionally high strength-to-weight ratio, with the "soft touch" necessary for today's water-based paint finishes. This item fits the following BMWs: 2012+ F30 BMW 320i 320i xDrive 328d 328d xDrive 328i 328i xDrive 335i 335i xDrive - Sedan 2013+ F32 BMW 428i 428i xDrive 435i 435i xDrive - Coupe
Brenden Selvig
-Alpine White 2015 BMW 320i Sport Package -1988 BMW 325 (spec e30) |
06-26-2020, 06:30 PM | #2 |
No 55mph
1623
Rep 8,479
Interested, but curious as to how a cover for sedan would fit a coupe correctly?
Most of the covers I see have different p/n for coupe and sedan You have the link to this in Turner site or a P/n?
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
