BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Burger Tuning JB4 install on B48 X2 m35i
      07-28-2021, 06:29 PM   #529
xcelir8bmw
xcelir8bmw's Avatar
402
Drives: 2022 BMW M240ix
comparable to JB4, temp changes with humidity totally affect boost.
      07-29-2021, 06:31 AM   #530
OZM135iXdrive
Drives: M135i Xdrive
Originally Posted by xcelir8bmw View Post
here you go
That looks pretty epic!
      07-29-2021, 06:33 AM   #531
OZM135iXdrive
Originally Posted by 21M235IXGC View Post
It should . As long as when u look in the file and from 0- 64mph you were at 100% wot the whole time from launch it does it . I have numerous 0-60 runs on the JB4 mobile . If I let off befor the ib4 reads up to 61mph it won't or if I roll off the line and don't keep it at 100% it won't either but if you look I. Your log it should let you know if something was missed .
It took me a few times to get it rite . If your not completely stopped and at 100% to 64mph it won't do it .
Did you manage a 0-60 of 3.9 on Map 0? thats carzy good!
How does that work? isnt it stock 4.8?
Also, if you were looking to measure a launch with launch control would you still do it with Map1 or Map 0 only?
      07-29-2021, 07:43 AM   #532
xcelir8bmw
xcelir8bmw's Avatar
402
dwp 0 and v17 in 86F temp on map 1 i get plus 3 psi over 22.8 stock yielding really about 25.5 to 26 psi
cooler temps a little more
map 2 is truly about 1 psi more to about 26 to 26.5
max boost never exceeds 30 but bounces below or at edge on map 1 and in map 2 is at or slightly higher than 30 in .xx digits
      07-29-2021, 09:05 AM   #533
xcelir8bmw
xcelir8bmw's Avatar
402
Unplug the battery, let it sit, plug it back in, start up vehicle.
Did you also check within the JB4 app if there are any 'codes' outstanding? If so, check it, see what it says, and/or clear them.
      07-29-2021, 09:07 AM   #534
xcelir8bmw
xcelir8bmw's Avatar
402
Shit I get your map 1 boost levels on map 0 ,
Don't know what the fuck is up … that is why I get a 0-60 in 3.9 seconds stock with JB4 off
As my stock boost is 25psi . Eventually I'll try and figure out what's up but I'm thinking my EWG may be bad
Oh! Are you back to stock or with midpipe still? If midpipe it all makes sense as I think I saw that it was equiv to about a PSIish of boost.
      07-29-2021, 09:16 AM   #535
xcelir8bmw
xcelir8bmw's Avatar
402
hmmm, let me explain what happens to me
my car 'rarely' settles to 'constant' boost by way of looking at JB4 but moreso aftermarket AEM. it's really 'hard' to get it to be 'consistent' to the numbers I've explained to you and rather all over the place numbers without exceeding 30.
me thinks that you are OKAY.
unplug the battery, wait, plug it back in. drive a bit and then see.
the logging with JB4 is good, but the AEM is well, 'better/alternate/convenient' as you are tapping the manifold direct. and as long as your eyeballs and foot align, then you know what is what. that is why I did it.
      07-29-2021, 11:36 AM   #536
xcelir8bmw
xcelir8bmw's Avatar
402
good luck mad man. my vehicle is fine. prolly cause I don't drive it much and didn't have many cylcles with the dwp and v19 as you have in road time versus non-drive time.
      07-29-2021, 12:01 PM   #537
xcelir8bmw
xcelir8bmw's Avatar
402
yup, being 49, catching up to me as well. sounds stupid, I rather BUY it than BUILD it now a days, ie since I bought this car in 2019. a little bit of tinkering is always OK, but still, I'm too old for that shit. thats my excuse for now.
      07-30-2021, 06:32 AM   #538
OZM135iXdrive
Come on now! you guys cant quit just yet. What are we gonna do without you pioneers!
      07-30-2021, 10:30 AM   #539
rice_rocket88
No_Country
298
Drives: E60 F48 F39
I'm still surprised that the BMW intake doesn't set off the MAF.. might be the velocity stack which I didn't even see in any of the original pictures online. Maybe you can show a picture of it some day. I agree, the pipercross didn't seem to do a lot for sound or performance, but I just left mine in for now. I'm not sure if you DWP is funky, but I'm still running map2 year round and it is perfectly fine. I don't tend to really "beat" the car.. ie repeated heavy throttle, plus I'm mostly on the highway commuting so I'm sure the car is happier moving at those speeds.
I'm itching for the mid pipe... might be on my next list.. hehe..
      07-30-2021, 12:17 PM   #540
xcelir8bmw
xcelir8bmw's Avatar
402
It happened. About 1000lbs of additional weight in the car and the 'surprise' to the guests while logging JB4.
Yielded 0-60 readout on JB4 log page. Definitely not 3.9.
      07-31-2021, 10:15 AM   #541
xcelir8bmw
xcelir8bmw's Avatar
402
here
let me know what you want me to filter on
      07-31-2021, 12:27 PM   #542
xcelir8bmw
xcelir8bmw's Avatar
402
I'll try to drive a little bit today and try it out.Furthermore I do have a pedal controller that could be part of the culprit because boost doesn't build for a bit. And that is a hard launch but yeah there was a delay.
Plus there's also four people and other gear which is about 1000 pounds heavier so that's part of it.
      08-01-2021, 09:58 AM   #543
xcelir8bmw
xcelir8bmw's Avatar
402
Here is where I am at with things...
No matter what I do off the line in non launch mode with what I have added into the under trunk of the vehicle and my fat ass I get above 5 second results 0-60 via JB4 readout. However, once boost builds off the line which is quite shitty the vehicle is fast AF. And since I have no issues I honestly feel there is no apples to apples comparison I can give at this point. I have tried damn near everything and stop to go initial boost build is the problem in any or non map with or without pedal box.
Same engine, different variables, done with the science project.
      08-03-2021, 04:36 PM   #544
rice_rocket88
No_Country
298
Drives: E60 F48 F39
I actually haven't tried "launching" it since I got the car.. I do wonder if the pedal box changes that... One of these days I might have a flat stretch of road to try the 0-60 launch.. just don't really care right now to do it (nor the opportunity)
      09-04-2021, 10:07 AM   #545
OZM135iXdrive
I am curious about this too. I am still running V17. What is everyone running is V20 safe? At the moment I am not having any issues with V17 and am wondering if it is worth moving to V20.
      09-04-2021, 04:26 PM   #546
xcelir8bmw
xcelir8bmw's Avatar
402
Staying on v17 myself!!!
Had a very pleasant drive today in 75F weather!
      09-05-2021, 10:04 AM   #547
OZM135iXdrive
      09-06-2021, 05:48 PM   #548
xcelir8bmw
xcelir8bmw's Avatar
402
Long story short, entered empty nester stage, might get a new vehicle to replace this one or have wife drive this one and we replace the minivan and I get something new. Or two new cars, or not at some point.
With that being said the JB4 is off the car and iPhone app removed. No issues with it, just life changes.
JB4 is For Sale, asking $500 shipped OBO.
      09-18-2021, 08:59 AM   #549
xcelir8bmw
xcelir8bmw's Avatar
402
bump
      09-19-2021, 10:15 AM   #550
xcelir8bmw
xcelir8bmw's Avatar
402
So I have been driving aggressively without the JB4 for two weeks now. Retaining the BMS pedal tuner on orange setting, I can honestly tell the stock tune is so much better making the car feel faster than the JB4 most of the time, not all of the time, but where it counts. Sometimes I forget that I don't have the JB4. Peak boost is down 1.5 PSI via AEM but rarely do I go as low if at all to 22.5, mainly in 25 to 27 sweet spot just like JB4. I have a whole new appreciation for the stock tune and brings the excitement back of driving this vehicle. Less laggy actually!
