BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos 2025 Aston Martin VANTAGE: 665hp! [Finally New Tech]
      02-12-2024, 02:03 AM   #1
TXSTYLE
"Salud"
TXSTYLE's Avatar
13851
Drives: F01 & F15 / Mineral White
Lightbulb 2025 Aston Martin VANTAGE: 665hp! [Finally New Tech]
One of the knocks on Aston has been it's archaic interface and infotainment system. One thing it has never lacked: Sex appeal and curbside appeal. Now it is going squarely up against the mighty 911 TT, according to the manufacture. While it may not be just as quick, it is certainly a worthy option, better looking IMO and even less expensive.
Aston Martin has been making the Vantage for 74 years. The current generation of the two-door GT car has been on sale since 2018, and after six years on the market, it's receiving a massive update. Think of it like a regular mid-cycle facelift, but full of mechanical stuff you actually care about. New camshafts, revised gearing, chassis alterations, that sort of thing. It also looks way better.
The end result of these changes is naturally impressive. The Mercedes-sourced 4.0-liter V8 engine in the Vantage now produces a massive 656 horsepower (665PS), 153 horses over the old car. This isn't the result of just a couple more pounds of boost, but of the aforementioned cams, bigger turbos, and an altered compression ratio. A total of three new heat exchangers have been added to manage both coolant and charge air temperature. The oil cooler is also bigger. Seems like there's a lot of heat going on here.
NEWS
REVIEWS
SHOP CARS
2025 Aston Martin Vantage Gets 656 HP And A Much-Needed Facelift
A huge boost in power, a revised chassis, and other significant alterations make the new Vantage a very appealing package.
2025 Aston Martin Vantage 1
Feb 11, 2024 at 7:01pm ET
Peter Holderith
By: Peter Holderith
2025 Aston Martin Vantage 27
2025 Aston Martin Vantage 16
2025 Aston Martin Vantage 14
The AMG V8 is backed up by the tried-and-true 8-speed ZF automatic transmission, which sends power to the rear wheels via an electronic limited-slip differential. The final drive on the diff has been shortened to 3.083:1 to enable quicker acceleration, but it hasn't affected the Vantage's long-legged top speed. The new Aston can not only sprint to 60 mph in just 3.4 seconds, but reach a top speed of 202 mph.
The new Vantage, like the old car, is glued together. In the automotive world, they call this bonding. The nature of the process allows for some flexibility in the chassis construction, which Aston has decided to take advantage of. The new car has received a revised underbody that adds torsional rigidity. The company has also repositioned one of the primary front cross-members, which it says increases the stiffness of the suspension mounting points and improves steering feel. The strut brace is lighter and stiffer, too. Who doesn't like a lighter and stiffer strut brace?
Chassis rigidity has likewise been improved out back with a variety of changes, which enable the car's new Bilstein DTX adaptive dampers to perform even better. It's hard to quantify on paper what all of this adds up to, but Aston insists that behind the wheel there are tangible differences between the new and old setups.
Software enables all of these hardware changes. Aston says the car's various traction-managing modes, launch control system, and electronic power steering have all been retuned to deliver more performance and driver engagement. The company went on at length concerning how all these systems gather data and operate, but the true test will be how it all adds up on a twisty road.
Bringing all of this technology to a stop is a braking system consisting of front 400mm steel rotors with six-piston calipers and rear 360mm rotors with four-piston calipers. A set of carbon ceramics is also optional, which sheds nearly 60 pounds of unsprung weight.
There's more changes going on here than can reasonably be listed outside of a spreadsheet, but the bottom line is, just look at the thing. It's over an inch wider than the outgoing car and the body panels have been resurfaced considerably. It's a two-door GT car with the engine up front and drive to the rear wheels. The proportions can only go so wrong. We've also already seen most of this car at Daytona, which nobody seemed to notice.
Deliveries of the new Vantage will begin in Q2 2024, with pricing likely to be announced around that time as well.
https://i.imgur.com/QAMZNzQ.jpg
Appreciate 2
M5Rick60091.50
jesm207.50
      02-12-2024, 05:36 AM   #2
chassis
chassis's Avatar
6560
Drives: 9Y0 Cayenne S
Nice console layout. Whose infotainment screen are they using? Looks like a VAG-sourced item? Or is it MBUX?
      02-12-2024, 05:55 AM   #3
Ugly Kar
415
Drives: E92 to C43 Cab to G42
Beautiful car and beautiful interior. I love the integration of the screen. One of few co's that haven't gone cheapo and put in a long ipad in place of an integrated screen.
jesm207.50
      02-12-2024, 08:29 AM   #4
BlkGS
BlkGS's Avatar
1166
Drives: BMW X5 M50i
Honestly, I quit caring about Astons when they stopped having their own motors. I would buy a Mercedes if I wanted a Mercedes.
It would be one thing if it was like, a derivative, where it has a different displacement and head sand revs higher, maybe it's single vs twin turbo or something... But when it's literally just the Mercedes 4.0t plucked out of a Mercedes box and then dropped in... No thanks. I'll buy a 911 instead.
      02-12-2024, 11:06 AM   #5
gonzo
gonzo's Avatar
10202
Drives: as many as possible
"The new Vantage's engine shares its layout, capacity, and Mercedes-AMG bloodline with its predecessor: a 4.0-liter twin-turbo V-8. But as with the DB12, it has been given numerous internal upgrades to boost performance, with new turbos and a heavily revised top end, as well as much better cooling"
Crazy Diamond
      02-12-2024, 11:28 AM   #6
Humdizzle
6071
Drives: GT3 + M2c
650hp in a front engine rear drive car. that should go well...
probably wont compete with a 911 turbo on dynamics. But sounds like an absolute autobahn rocket. the front end is an improvement as well.
current vantage prices should fall to the $70k range for a low miles 2019 example once this is out.
2018 Porsche GT3 6MT
2021 M2C DCT
Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS
      02-12-2024, 11:28 AM   #7
BlkGS
BlkGS's Avatar
1166
Drives: BMW X5 M50i
Yeah, that's just not enough for me at that price point. Good news for them is I'm not spending that kind of money on a car so my opinion doesn't matter, lol.
      02-12-2024, 11:57 AM   #8
dgoldenz
1882
Drives: Vanquish, FF, 392 Wrangler
These will be sweet when they’re $75k in 4 years. The new infotainment setup looks great. Much improved overall.
Appreciate 2
xander_g1009.00
      02-12-2024, 12:19 PM   #9
TXSTYLE
"Salud"
TXSTYLE's Avatar
13851
This x Infinity!!!
It still annoys me to this day, the tacky, afterthought looks of these "tablets sticking out of the Dash".
xander_g1009.00
      02-12-2024, 01:03 PM   #10
baron95
baron95's Avatar
1704
Drives: BMW G87 M2
Gasoline cars are simply too complex for independent boutique marques to offer a proper, well rounded product.
Lotus, AM make great products, but the ownership experience is miserable these days. All that tech never works. They are only good to drive in a 50 mile radius around your town that has a dealer/service center. They are just not reliable to take anywhere.
Gorgeous cars though. Not sure why everyone else has such a hard time producing designs even half as beautiful.
G87 M2 BSM On Order
      02-12-2024, 08:56 PM   #11
Davil
Davil's Avatar
Australia
6525
Drives: M2 CS, 18 Vantage AMR, 00 WRX
It’s all their own this time. Massive project. I love that it has buttons and knobs instead of a giant bolted on TV screen for everything.
      02-12-2024, 09:00 PM   #12
Davil
Davil's Avatar
Australia
6525
Previous model was a plug and play AMG. This one is very different with a lot of internal Aston Martin development and you won’t find it in any AMG models.
      02-12-2024, 09:02 PM   #13
Davil
Davil's Avatar
Australia
6525
So you’ve owned one then?
      02-12-2024, 09:38 PM   #14
NickyC
NickyC's Avatar
17485
Drives: M4 CS. Former G82, x2 F82, F80
Gorgeous car, but the super wide rear fenders have me flinching while thinking of the rocks they catch!
Reminds me of a 177.
      02-12-2024, 10:41 PM   #15
baron95
baron95's Avatar
1704
Drives: BMW G87 M2
Made my British ownership mistakes with 3 Jaguars
G87 M2 BSM On Order
      02-12-2024, 11:53 PM   #16
FrostyDC4
77
Drives: C63S Sedan|350Z
2007 Nissan 350Z  [0.00]
2012 BMW 135i  [4.50]
I thought the engines on the new AM were placed behind the front axle?
C63S Sedan: Long Live The V8
350Z: The Very Poorman's 981 GT4
      02-13-2024, 12:52 AM   #17
x622
Forced Induction Connoisseur
x622's Avatar
962
Drives: 23 X5MC / 23 720s
2024 G87 M2  [0.00]
2023 Mclaren 720s  [0.00]
2005 Honda S2000  [0.00]
2008 BMW M3  [0.00]
2023 BMW X5MC  [0.00]
1964 Ford Mustang  [0.00]
1968 Pontiac GTO  [0.00]
I hope this is what they put in the DBX707 next. Supposedly '25 MY refresh...
Oy vey, look at all these shekels
      02-13-2024, 09:36 AM   #18
Humdizzle
6071
Drives: GT3 + M2c
thats true. but front-mid is still not as good as MR or RR for many reasons. which is why GM dumped that platform for a mid engine c8.
2021 M2C DCT
      02-13-2024, 10:40 AM   #19
Germanauto
Germanauto's Avatar
9704
Drives: Alfa Romeo Giulia, Rosso
Buddy picked up a 2019 for like $120k...and they've depreciated even more.
Great car to get 4-5 yrs used. Ballin on a budget
Former
-2008 E90 328 black/brown
-2012 Lexus IS250 black/black
Appreciate 2
Humdizzle6070.50
///MPhatic13862.50
      02-13-2024, 11:19 AM   #20
Minacious
The Dovahkiin
Minacious's Avatar
312
Drives: LCI M6 GC, other stuff.
It looks significantly better than the last gen. That front clip makes all of the difference. The front clip on the last gen looked very much like an MX-5 (Miata).
Ed
CG Artist, Set Painter and Sci-Fi Nerd.
“The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence.” - Charles Bukowski
Appreciate 2
Humdizzle6070.50
jesm207.50
      02-13-2024, 11:53 AM   #21
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Drives: OG M2 • Exige
Spot on. If I didn't look 12 for my age I'd have a Vantage V8. Always loved them.
      02-13-2024, 05:47 PM   #22
Germanauto
Germanauto's Avatar
9704
We drove up to Monterey car week a few months ago and his BRG Vantage got a ton of attention. More than you'd expect given the price he got it for.
Former
