BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) 2018 Brake Squeal is Design Problem
      02-09-2024, 07:06 AM   #1
Eric Engineer
Drives: BMW X1 2018
I am convinced BMW has improperly designed the Brake System & that faulty design is why most X1 brakes squeal like you are running over babies.
The squeal is grating & distracting. I believe the Brake Rotors have natural harmonics inherent in their design and those harmonics are the root cause of the horrible & distracting noise. I support lighter vehicles were it makes sense.
Are there any heavier, better designed, rotors available for the X1 ? I am ready to get rid of this thing.
BTW: I am a Mechanical Engineer with 20 + years aerospace experience. I have tried every trick I know to stop the squeak. Not possible with this design.
      02-09-2024, 07:32 AM   #2
mDrive2
Drives: x1
Does this happen in the morning or after the brakes have warm up? The original pads may contain metal parts that oxidize in a damp/wet environment, after washing the car or even after or even after spending the night.
Have you tried changing the brake pads?
I use carbon-fiber ceramic one and no squeaky sound whatsoever.
Cheers.
      02-10-2024, 10:33 AM   #3
Eric Engineer
Drives: BMW X1 2018
From 5K miles after new brakes began to squeal. Louder & more obnoxious as they heat up. I replaced them with BMW best Ceramic Pads (w beveled leading edge) and best new Rotors. I dial indicated the rotors at less than 0.0002", both sides (expected for ground surface). Brakes squeal 2K miles later. I took it apart to see that the "Anti-Squeal" material on the piston side had worn completely through in 6 small spots exactly where the piston made contact. Rotors were re-indicated and still flat. This is a classic signature of a Harmonics Design Problem (think Tacoma Narrows Bridge Disaster).
I am having a hard time believing I'm the only one on the planet who is unhappy with this.
      02-10-2024, 12:52 PM   #4
mrpingu
181
Would adtermarket discs fix this?
I try to understand What exactly is the problem? Mine squeek sometimes but not always.
      02-10-2024, 11:42 PM   #5
allwheelsdriven
#onelesssubaru
allwheelsdriven's Avatar
112
Drives: 16 BSM X1 MSport
I have no squeak. Running akebono pads
      02-11-2024, 08:19 AM   #6
BrianJ
25
Drives: BMW F48 X1 xDrive20i Sport B48
Never had a squeak on ours. Only 17k miles since new, but still on original pads and discs (rotors).
