BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Switching my 225/50/R18 tires to a Low profile one, suggestions?
      05-11-2021, 10:10 PM   #1
Ivanbmw
Drives: BMW X1 xDrive28i 2018
Hi everyone,
I have 4 inflated 225/50/R18 in my X1 2018 and I would like to have something more sporty, I guess that changing my tires from these all-season tires to a low-profile performance would make it, right?
Do you know if needs to be a performance tire to low it from 50 to let's say 45 or even 35(don't know if exists or it is suitable for x1)?
Anyone has already made this? Is it worth it? What would be the lower that I could do to not affect too much the comfort?
Thanks!
      05-12-2021, 02:39 AM   #2
chowser51
chowser51's Avatar
2025
Drives: F33 430 and F39 M35i
Are you trying to change the look of your car or the performance?
If performance just get some performance tires.
If appearance, you’re going to want to jump up to 19 or 20 inch wheels to get the low profile look.
You don’t want to just drop your 18s to a smaller aspect ratio using the same width tires.
For ex. If you drop to 225/40/18, your tires will be 1.8” shorter.
If you go to 245/45/18, it will only be .2” shorter but is a good size. You won’t get a low profile look though.
      05-12-2021, 01:17 PM   #3
Ivanbmw
Hey, pretty much appearance, I thought that performance tires by the theory are built in a low profile(aka some like 225/40/R18).
So, do you think if I do something like that, without going to higher than R18 is going to look weird?
Like, I like the look of my stock 225/50/R18 wheels, but I wish that it would be a little bit lower like from 50 to 40.
I believe that changing to a higher RADIAL is too much change and expensive, right.?!
      05-17-2021, 01:28 PM   #4
jcoates
jcoates's Avatar
Drives: 2017 BMW X1
I swapped out to 245/40 on 19x8.5 wheels. This way the overall diameter was nearly the same as OEM and it gives lower profile. I ditched the run flats and went with Continental ExtremeContact DWS 06 Plus too.
      05-17-2021, 11:21 PM   #5
Ivanbmw
Nice, this is what I am looking for, and I am just curious when you set a wider wheel, does it affect the driveability or the fuel comsuption?
      05-18-2021, 08:57 AM   #6
jcoates
jcoates's Avatar
Drives: 2017 BMW X1
I haven't seen a noticeable difference in fuel economy. I feel like the drive is improved. I can notice better steering response and overall better feel of the road. The Continentals are much better than the stock Pirelli's as well. My decision was based mostly on looks. I wasn't so worried about fuel economy and the better driving experience was just an added bonus I guess.
      05-18-2021, 09:31 AM   #7
Ivanbmw
Understood!
How much on average did you spend on this mod?
      05-18-2021, 12:27 PM   #8
jcoates
jcoates's Avatar
Drives: 2017 BMW X1
I spent around $1800. I didn't want to go with super expensive wheels. They were around $220ish each. Totally changed the look of the car though. I'm glad I did it.
chowser512025.00
      05-18-2021, 08:44 PM   #9
jrveron
jrveron's Avatar
Argentina
263
Drives: 2023 X3 m40i
NICE! Looking good!
Those wheels look like TSW Pescara. What offset did you use? ET42?
Thanks,
2023 X3 m40i Brooklyn Grey
      05-18-2021, 10:18 PM   #10
jcoates
jcoates's Avatar
Drives: 2017 BMW X1
Originally Posted by jrveron View Post
NICE! Looking good!
Thanks,
Thanks! They are Drag DR77 19x8.5 et42.
      05-18-2021, 10:48 PM   #11
Ivanbmw
amazing!
      05-27-2021, 10:41 AM   #12
Ivanbmw
hey guys,
Do you think that gloss black powder coat my OEM 18'' BMW rims would be wierd?
      05-27-2021, 11:43 AM   #13
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Originally Posted by Ivanbmw View Post
hey guys,
No. One of the UK models (LCI 2020) used to have them fitted on the production line if you specified it on the Sport model. Not the M Sport!
2012 BMW 320d Sport (F31).
      05-27-2021, 10:02 PM   #14
Durag
Drives: Bmw x1
You got a link to the tires and rims? They fire
      05-28-2021, 09:52 AM   #15
jcoates
jcoates's Avatar
Drives: 2017 BMW X1
https://www.customwheeloffset.com/bu...-dr77-19x85-42
Here you go!
      05-29-2021, 09:52 PM   #16
ZZZZ
50
Drives: Z4 3.0i winterbeater
As mentioned. Do not put a low profile on your existing rims. The overall diameter will be wrong which can interfere with the wheel hitting your suspension at full lock. Plus it will lead to incorrect speedometer reading and affect the computers ability to properly adjust your awd system, ABS, and traction control.
You want a larger rim with a lower profile tire for a similar overall diameter.
A wider / heavier tire will affect acceleration and fuel economy. It can in some conditions lead to better highway fuel economy. Wider tires (and wheels that stick out more than stock) will also lead to understeer.
Staggered isn't recommended on our FWD/AWD vehicles.
I do not recommend going with 19s in runflats or ultra high performance summers. The ride and road noise is punishing. Fine for 18s though. If going with 19's then go with a high performance all season. You'll still get a sporty ride but without the compromise of fast tire wear, road noise, and comfort. There will still be a bit of sidewall flex on turn in but it'll still be far better than what you're used to now.
Stock for 19s is ET47 and only 7.5 width. ET42 will be flush at 7.5 but stick out a bit of 8" or wider rims. I have ET40 x 8" on 225 width rubber and they stick out a bit too much for my liking. I should've kept searching for ET42 at 7.5".
      05-31-2021, 12:37 AM   #17
chowser51
chowser51's Avatar
2025
What size tires?
      05-31-2021, 07:14 AM   #18
jcoates
jcoates's Avatar
Drives: 2017 BMW X1
What size tires?
245/40r19
chowser512025.00
      05-31-2021, 02:08 PM   #19
chowser51
chowser51's Avatar
2025
245/40r19
duh, reading comprehension fail on my part.
I see it earlier when you mentioned the wheel specs.
      06-01-2021, 01:26 AM   #20
jrveron
jrveron's Avatar
Argentina
263
Hi ZZZZ, how are you?
Sorry but the OEM 19" wheels are 8" wide (https://www.wheel-size.com/size/bmw/x1/2017/).
We also have a user in the forum who installed 245 tires in OEM 19" wheels (https://f48.bimmerpost.com/forums/sh...1729957&page=2).
I know it for sure because I'm also looking to replace my OEM 18" with 19" wheels, 8" or 8.5" wide. I was convinced to use P-Zero 245/40r19 run-flat tires, but now you are making me hesitate, haha. But at the same time, I want to keep using run-flat tires for safety. If I have a puncture, I don't need to stop the car to replace it. Trust me, here in Mexico is important...
      06-01-2021, 12:17 PM   #21
ZZZZ
50
Sorry, you're right. Yes stock 19's are 8" wide and most aftermarket 19's are 8.5". My stock msport 19's are 8". I replaced with 8.5's for summer wheels and wish I did go with a wider tire as I'm not a fan of the stretched look. But I think I've given up as much understeer as I can handle by going from ET47 to ET40 already. My wife noticed right away that the car didn't turn right away as she's used to.
And I totally understand the appeal of runflats and can't argue the merits. My x1 already has msport suspension and 19" wheels. With michelin runflats the ride is very choppy and loud. I sold those and put non rft Conti winters on my msport wheels and went aftermarket with michelin all season sports for the summer. The ride is pretty good now though there's quite a bit of sidewall flex on aggressive turns. I do keep a can of tire repair sealant in the trunk too. I've also had an F10 5 series which came with runflats which cracked my rims. (the stiff sidewalls are known for damaging rims) so I've had a bad experience there. E85 z4 also had a punishing ride from the factory so I ended up downsizing those wheels and going non rft which made the world of difference. That car was made when bmw was just migrating to rft tires and haven't figured out their suspension tuning yet.
      06-02-2021, 01:12 PM   #22
jrveron
jrveron's Avatar
Argentina
263
Thanks for the insight! I appreciate real-life opinions/reviews.
