BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Spare tire (when you have non run flat tires)
      08-11-2018, 10:38 PM   #45
DrPeteF48
Drives: 2017 F48, Jet Black
Originally Posted by E90Fleet View Post
F48 Jack and storage parts
1 Ablage Notrad 71106857380
2 Lifting jack storage partition 71106878508
only in conjunction with
-- Velcro fastener 71106878510
4 LIFTING JACK 71126885765
-- Set of felt strips SET 51452353024
05 Wheel-nut wrench 71126779731
06 Chock 71121507292
07 Actuating ratchet for vehicle jack 71126769151
08 Bracket 36106857382
09 Cover 36106857383
10 Hex bolt with washer M6X20 07119904527
11 Wing screw M8X68 1 07119908728
12 Hex bolt M8X20- 8.8-ZNS3 07119906119
Don't know how much it matters but the jack does vary based on X vs S Drive and date of manufacture.
      08-13-2018, 12:45 PM   #46
spitpilot
64
Drives: 2023 230iX, 2017 X1 M sp X
[QUOTE=
That said, I have invested in a spare wheel kit simply because in Australia and with the driving I do, there's a higher risk I may be somewhere remote when I have a puncture. Or have to rely on driving maybe 100 km or more on the punctured RFT.[/QUOTE]
Exactly!...the dirty little secret on RFT's is that the tire makers all say "DO NOT travel more than 50 miles (80.47 Km) without air pressure in the tire!"
That's great if you're retired to a tropical island where you're never far from your garage...not so good if you are 150-200 miles from home on a Sunday afternoon! I bought a spare/jack kit for my 328 just instantly on reading that warning...and believe it or not...got a puncture up in the Sierra foothills on a Sunday afternoon on our very first out of town trip! Hit the "BMW Assist" button and they called me by name and gave me my exact location....told me they could "arrange a tow to the nearest BMW dealer....who would fix my problem tomorrow morning"....I laughed and told em wife and I had to be at work a 3 hour drive away and that I had my spare on already! Drove down to "civilization" and found a tire shop open. The other "feature" of RFT's is that if you run on em...they won't patch em since there's no way to know if you've gone over the 50 range....Since I had a spare on...tire was patched and rebalanced and we drove home...for $20 and a 1/2 wait.
      08-15-2018, 07:48 AM   #47
landrumdh
Drives: F48
I just ordered the spare + jack kit from bimmerzone and it should be here today. My runflats are scheduled to be removed on Monday. I can't wait to be back on traditional tires. I was hoping to go for a full sized spare but I couldn't find anywhere to sell me a steel rim, and all of my RF's are trashed, and I didn't have time to measure out fitting a full sized spare + my roadside kit I carry ...
The spare wasn't cheap, but I figure the OTC puts me at about the same price as replacing the current tires with RF's so I'll be ahead next time and I should no longer have so many issues getting tires patched and service done on them.
      08-22-2018, 10:41 AM   #48
landrumdh
Drives: F48
The spare from bimmerzone showed up almost immediately. The jack doesn't have any sort or storage for it, so I just left it wrapped in the bubble wrap and threw it in the trunk for now. The wheel fits perfectly on the left side of the tire storage in the trunk without any changes / tiedown.
I'm only 2 days into the new tires however they are much quieter and less harsh then the runflats. I've had these on other cars before so I'm hoping they hold up just as well with the X1. I loaded the Bridgestone Potenza RE980's.
      08-22-2018, 06:27 PM   #49
ttimbo
ttimbo's Avatar
282
You should tie them down
Peugeot T9 308 GTi 270
      08-23-2018, 05:16 PM   #50
Beemerbuster
15
Drives: X1 2.5D
On the subject of Jacks - I made enquiries at my local dealership and was informed the jack would be in tne order of £120 plus.
I therefore purchased a secondhand X3 E83 jack on ebay for £35 and it does the job perfectly. This jack has the correct size shoe to fit into the plastic lifting points on the chassis and more importantly the shoe is orientated 90degrees to the jack winding point.
I have noted many non OEM Jacks listed on eBay have the shoe aligned to the winding point which to me would mean some awkward winding required?
MJE60678.00
      09-09-2018, 07:08 PM   #51
bimmerdriver2
bimmerdriver2's Avatar
180
Drives: 2020 M2C DCT
Originally Posted by DrPeteF48 View Post
Purchased from my local dealer, but they ship too...
https://parts.bmwnorthwest.com/a/BMW...1_0828.html#01
I ordered the actual wheel from Bimmerzone because they ship a pre-mounted wheel/tire combo.
In terms of the install, all it took was removing the little tool holder in the front of the storage compartment and replacing it with the little metal L-bracket that holds the spare down. This requires cutting a little slit in the liner but isn't tough.
I got the separate foam block for the jack as well, though it looks like there may be a spot for the jack in the tray that goes inside the wheel too.
Thank you for posting this link. It looks like the jack and crank were upgraded as of 11/2017. (Items 4, 7 and 13.) Which parts did you order? Please post a list and a photo. I'm considering ordering a jack and I'd like to know what I will be getting.
      09-09-2018, 11:30 PM   #52
spitpilot
64
Originally Posted by ttimbo View Post
The claim that RFTs puncture more easily than non-RFTs is an urban myth. There's no evidence to support the claims, other than simple, " bad luck" anecdotes. The weight difference is pretty minimal, eg, for the Pirelli P7 fitted to many X1s, the RFT is c.13kg, and the non-RFT is a tad less than 12kg. Other brands are similar.
According to the tire mfgs technical info here (might be more conservative due to high rate of litigation?)...you can only run a RFT with no air for 50 miles!...That's not gonna do you much if you're way out in the boonies on a Sunday afternoon...even BMW Assist isn't gonna save your bacon...you'll wait hours for a tow to nearest dealer (we have whole states with NO BMW dealers!) and then you'll sit in a motel till Monday to get the problem resolved. When I read about the 50 mile restriction..bought a jack and compact spare for my 328 within weeks of buying the car! Best $350 i ever spent...got a puncture up in the mountains about 75+ miles to nearest city and 160 miles or so from home...on a Sunday afternoon...sure glad I had the spare to run down to nearest tire shop open...since I hadn't driven on the tire (they won't fix RFT's that have been driven flat due to the 50 mile restriction from the mfgs...liability issues)..I got the tire fixed and rebalanced in about 20 min or so..for $20 and drove on home!
      09-11-2018, 10:30 AM   #53
landrumdh
Drives: F48
Runflat's and compact spares have the same restriction typically. 50 for 50.
      09-11-2018, 05:17 PM   #54
ttimbo
ttimbo's Avatar
282
Speed limitation, yes —- but there's no distance limitation marked on mine. That said, you'd obviously change it as soon as you can.
      09-24-2018, 09:47 AM   #55
mikeyb74
mikeyb74's Avatar
113
Drives: G20 330ix M Sport
I picked up a 19" 5x112 spare out of a junk Audi B8 A4.
      11-27-2018, 10:21 AM   #56
RichGrim
Drives: 2018 BMW X1 xDrive28i
How are you all attaching the velcro strap that holds down the jack?
      11-27-2018, 02:10 PM   #57
Millie
Millie's Avatar
120
Drives: a bmw.
I've been using something like this for years and no issue.
Throw that in the back with a set of pliers and a portable tire inflation that you plug into the 12V jack and you are set.
edit: sorry for the massive pic.
2022 Nissan Armada (big couch)
2017 Camaro SS 1LE - Gone
2008 SSII E90 6MT - Gone
2009 SG E92 DCT - Gone
MJE60678.00
      02-23-2019, 02:27 PM   #58
X1604M
X1604M's Avatar
57
Drives: 2018, F48 28i
2018 BMW X1 F48  [0.00]
I am thinking of carrying a spare tire. I see number 3 which looks like articulated jack and can fit well in the foam storage also. Any idea if I can buy one jack like that and put in that space instead of scissor jack which I will have to keep beside the spare. I want to maximize the extra storage beside the spare. thanks.
      02-23-2019, 06:01 PM   #59
MJE60
MJE60's Avatar
Originally Posted by brissim View Post
Keep in mind that a spare tyre is useful even if you have runflat tyres. There will be those times that when you get a flat with a runflat that it may pay to be able to stop and change over to the spare. As long as you have not driven on your runflat in a dead flat condition for any distance (generally more than 5-10km), you can repair the runflat subject to the same rules that apply to a puncture in a conventional tyre. Could save you the cost of replacing a runflat when you have a puncture.
Tony
Interesting, I posted a thread asking people on their experiences getting run flat tyres repaired. I have only had a couple of replies so far (thanks ttimbo) but I have now asked all the main tyre repair companies in my area (as well as phoning national chains).
My conclusion from their replies is that, in the U.K., nearly all refuse point blank to repair a runflat regardless of whether it has been driven on or not. Only one national chain said they would repair dependent on manufacturer recommendation (e.g. no if Pirelli, once if Michelin) and type and location of damage.
In brief, imho, it is almost pointless to have a spare if you use run-flats in the U.K. Precisely because you will not save money by quickly removing it to reduce damage. In Australia, where you could be miles out in the bush, yes, it could save your life. In the U.K.( or most of Western Europe) you are rarely more than 20 miles from a garage.
I have instead of a spare tyre in the boot, got; a rubber/string tyre repair kit, pair of pliers to remove culprit, an electric tyre inflator and some tyre sealant. if the tyre does develop a puncture and I have some distance to drive it should help keep the tyre to correct pressure. If I am lucky and the patch holds (assuming it is in middle of tread), I will save money by continuing to use the tyre. Possibly reckless? maybe but I check my tyres very regularly for pressure, damage and wear. When the runflats need replacing I will go for ordinary tyres and a skimpy spare. The hart4bmw set-up will do nicely, and thanks to others for bag & mat recommendations.
      02-23-2019, 06:18 PM   #60
MJE60
MJE60's Avatar
Nice kit, where can I get one? I have assembled something similar from loose parts and not such good quality.
      03-11-2019, 01:33 PM   #61
Skyline2.0
For those that have a spare wheel (but not full BMW kit), is it possible to secure the spare down with just the wing screw (part # 07119908728), cover (part # 36106857383) and bracket (part # 36106857382) without the styrofoam insert?
I have the spare wheel, tire and jack already.
Can anyone confirm that the cover, wing screw and bracket can lock down the wheel without the styrofoam insert piece?
Much appreciated.
      03-19-2019, 09:31 AM   #62
JB426
Drives: 2018 BMW X1 XDrive28i
Much appreciated.
I would think it would work. The nut underneath the liner is there and lines up approximately in the center of the wheel hub. The issue you could have is there is a limited amount the wing bolt can screw in, maybe 3/4 - 1 inch, so you need something that will secure the bolt from the washer just slightly below the middle of the hub. The cover may go down too far without the foam insert. I made my own bracket but I might get this since it will work with a small spacer or additional washers underneath the wing bolt. I tested it with one from an M3.
https://www.pelicanparts.com/cgi-bin...on=71151180625
On another note, my X1 did not have the nut under the liner for the bolt that would secure the jack, to the left of the spare tire. The wing bolt nut and bracket nuts are there.
      03-19-2019, 04:19 PM   #63
oakey46
159
Much appreciated.
Assuming the Stateside temporary spare wheel is the same as on my UK spec car, I'm not so sure. The cover part, when tied down with the wing screw, sits within an inner recessed circumference of the styrofoam insert and I wonder whether that affords additional 'pressure' (for want of a better word) on the wheel, thus spreading the retention area across the boot/trunk floor. It might just work without it, but it could be that the cover and bolt alone may not be enough. I have nothing in the styrofoam part, all the jacking kit being within the separate styrofoam 'block' that sits to the left side of the spare wheel. I wonder whether BMW would bother to provide the styrofoam insert if it wasn't really needed.
      04-03-2019, 06:48 AM   #64
Skyline2.0
JB426 and oakey46, thanks for looking at your setup. I'm going to get those parts and rig up a DIY spacer to fill the gap to ensure a snug fit. The styrofoam piece wont be useful for me and will just take up space.
      04-05-2019, 01:25 PM   #65
JimD
JimD's Avatar
368
Drives: 128i convertible
That plugging kit looks like this one:
https://www.amazon.com/ARB-10000011-...gateway&sr=8-3[url]
Link is to Amazon in the U. S., not sure if that will work for you guys in Europe. I have that plugging kit but haven't used it on a BMW. I did use it on my Suzuki SUV and it worked well. I don't carry the case, I took the pieces out and put them in the bag of my Viair 70P compressor (12V). Even with a spare, a compressor could be very handy since they require a really high pressure and most of us do not check it real often. I have yet to have a spare in well over 40 years driving that I could not limp home on using a compressor - they have all been slow leaks. If I get a X1 or X2, however, it will have a spare. I would not expect to need it but especially on a trip, it could really save the day.
I am not a run flat fan. I believe their main purpose is to help people avoid messing with a flat. You don't have to get dirty, you can drive to the tire replace and spend a lot of money.
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09
      04-08-2019, 11:02 AM   #66
karma_police
Drives: BMW 435i xDrive GC
Hello everyone.. I'm contemplating switching to non run flats on my new (to me) '16 X1. I just checked the under floor compartment where the spare tire kit would be secured but there is no hole in the liner. Now I'm not sure if there is actually a nut under there for the wing bolt to secure the kit to the floor. I'm not willing to slit open the liner to find out
Has anyone encountered this before? I'd really like to secure the kit down with the wing bolt and not bother with tie downs, etc.
