07-19-2019, 06:39 AM | #45 | |
7484
Rep 12,305
I've actually come to the realization that those older crops of M's are the most satisfying. My cut off is essentially at the E92 M3. I'm in fact content enough with what I have that I just put down a deposit for a 2016 Tundra to use as my DD and workhorse. The saying they don't make them like they used to definitely stands. I think the golden era of cars, at least for me personally ended with cars designed in the early 2000s.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
Haywood3100.50 |
07-19-2019, 07:20 PM | #46 | |
18663
Rep 14,108
Drives: G82 M4C X-Drive
i need to see this car. Pic?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
07-26-2019, 06:53 PM | #47 | |
Schumacher
786
Rep 2,278
Drives: E30 325is,E93 M3,X7M50,F06 M6
Plus if you did your swap a while ago the prices were higher, nice build!
07-26-2019, 10:22 PM | #49 |
1876
Rep 2,397
Its a money pit.
BE prepared to replace the RTABs Early 95' builds had valve spring retainers that were "weak". Cooling system conversion/upgrade (water wetter/fan clutch delete/t-stat upgrade if you plan to actually DRIVE) the car. Engine mounts are probably shot. Check F&R upper struts.. rears for clunks and fronts for new welds. Check the guibo; for chunks missing. Pull the rear taillights and check for rust. PS pump is line is absolutely sweating or leaking. I had one. Turner stage 3 kit; cams w/injectors and headers. Evey older ///M3 has issues. I am convinced its part of their character. Sort of love hate. The game changer is when BMW converted to electric fans. |
clee1982797.50 |
