01-31-2019, 08:47 PM | #1 |
Joint Chiefs of Staff
24083
Rep 190,614
Evolution Racewerks Competition Series 4" Catless Downpipe For B46 Bmw X1/x2
Introducing our new Competition Series 4" Downpipes for your BMW B46 four cylinder turbo engine! Fits all 2016+ X1/X2, Mini Cooper S, Clubman, Cabrio and Countryman. The B46 engine is found in all U.S. spec cars. The downpipe is different than the B48 found in the EU / Asia spec cars. You must get the correct downpipe for your car as they are not interchangeable. Key Features:
Restrictions in the exhaust system robs horsepower and torque especially on turbocharged cars. Thus, removing as much exhaust flow restrictions will increase horsepower and torque significantly. The factory catalytic converter found in the factory downpipe is a big culprit of this and is a major exhaust flow restriction. The factory catalytic converter is made up of catalyst material formed into "honeycomb" weaves. Exhaust gas must pass through these tiny "honeycomb" weaves on their way to the exhaust system thus causing a major exhaust flow restriction. It also causes turbulence after the catalytic converter which causes the exhaust flow to slow down (which increases restriction). By replacing the factory downpipe/catalytic converter with our Competition Series 4" Catless Downpipe, more power is unleashed! Our dyno testing has shown around 14-16whp average peak gains and upwards of 24wtq peak gains! While peak horsepower is nice to look at on dyno charts, what's more important is the power curve. If you look at the dyno charts, torque hits MUCH earlier and harder. The torque curve is BROADER throughout the RPM band. More usable power. You have more time spent in the RPM band with higher horsepower and torque. This equates to faster turbo spool up (less turbocharger lag) and better throttle response. Bottom line, faster. You will feel the difference instantly. Our Competition Series Catless Downpipes is constructed out of 100% 304 grade stainless steel and utilize mandrel bent piping. They are 100% TIG welded by our in house fabricators and built in the USA. The factory turbocharger turbine housing utilizes a 4" V-Band flange which we have duplicated and CNC machined cut out of billet 304 stainless steel. Stainless Steel CNC machined O2 sensor and laser cut brackets are TIG welded using stainless steel rods. The O2 sensor is positioned at the factory location. The factory turbocharger outlet is 4". Many of our competitors machine a 4" outlet v-band to match the factory, but have a 3" opening at the flange so that they could use 3" piping to save money on manufacturing. This causes a "step" at the worst place possible, at the turbocharger outlet. Our downpipe features a 4" inlet on the downpipe and 4" piping. We reduce it further away from the turbocharger outlet. This results in less exhaust turbulence and backpressure which again improves throttle response and increase turbocharger spool times (less turbocharger lag). The factory downpipe utilizes a flex bellow section that allows the exhaust system to move. This eliminates undue stress on the exhaust components like the exhaust system, downpipe, turbocharger and exhaust manifold. Many of our competitors do not feel it is important to keep this. While you do not see any adverse affects right away, over time, the stresses caused by not having a flex section and having a rigid exhaust system will cause premature wear and tear. Any stress failures like cracks will form quicker than usual on exhaust manifolds and exhaust components. Also, without a flex section, the exhaust system cannot properly deflect impact. Especially on lowered cars, whenever the exhaust system contacts the ground, the entire system gets pushed up. Without a flex, you can imagine how much stress is put into exhaust components like the exhaust manifold when the exhaust is pushed upwards. We fully understand that durability of our products is important. Thus, like BMW, we incorporate a flex section into our downpipe. Our flex sections are 100% stainless steel (cheap flex sections only have stainless steel center braids and steel caps) to ensure corrosion resistance. OPTIONS Ceramic Thermal Coating - The purpose of ceramic coating downpipes is to keep heat from the exhaust gases inside the downpipe from radiating out. This keeps underhood temperatures lower and less heat absortion by nearby parts/surfaces. Another added benefit is that by keeping in heat (energy) in the exhaust gases inside the downpipe, exhaust flow velocities stay up, resulting in lower backpressure. The ceramic coating also adds additonal corrosion resistance. We utilize the best ceramic coating possible. Our thermal coating can resist up to 2000F of heat. It is available in black only (all the other colors cannot withstand heat that high). Additional O2 Sensor Bung - An additional O2 sensor bung can be added so that you can easily add a wideband o2 sensor and gauges so that you can monitor air/fuel ratios. The additional O2 sensor bung will come pre-installed with a plug so that you do not need to run the o2 sensor right away. Optional EGT (Exhaust Gas Temperature) Bung - An additional 1/8" NPT bung can be added so that you can easily add a EGT sensor and gauge. The optional EGT sensor bung will come pre-installed with a plug so that you do not need to run the EGT sensor right away.
03-09-2019, 10:36 AM | #6 | |
80
Rep 241
03-09-2019, 10:37 AM | #7 | |
80
Rep 241
03-09-2019, 11:42 AM | #8 | |
180
Rep 375
Drives: 2020 M2C DCT
I'm calling BS on this:
03-09-2019, 01:54 PM | #9 | ||
80
Rep 241
04-26-2019, 11:44 PM | #11 |
80
Rep 241
04-27-2019, 04:27 AM | #12 |
Rep 5
05-03-2019, 12:26 PM | #15 | |
80
Rep 241
I believe you can remove the CEL with the JB4+ program. |
05-03-2019, 02:51 PM | #16 | |
98
Rep 266
You are getting CEL even with the catted setup? Interesting, I would think that since its catted you should be fine no? |
05-04-2019, 07:38 AM | #17 | ||
Rep 5
05-09-2019, 11:30 AM | #18 | |
65
Rep 244
I’ve removed the CEL with the JB4 but they reappear. Shows the car is running lean. I’m going to have the car looked at for any potential leaks, but I haven’t noticed many changes. |
05-09-2019, 11:32 AM | #19 |
65
Rep 244
I checked around and even with a hi-flow cat CELs are fairly common.
05-09-2019, 01:29 PM | #20 |
80
Rep 241
Contact JB4. They can disable the CAT CEL, but if it says you're running lean, then I would agree that you should check for leaks and make sure you're running the correct Octane for the Tune.
05-12-2019, 09:30 AM | #21 | |
98
Rep 266
