BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Removing exhaust tip
      08-28-2018, 09:42 PM   #1
eligibleli
Drives: 2018 BMW X1 sDrive28i
I'm trying to change out the chrome tips and have been reading and people are saying that to tap the original tip from behind gently and it should slowly come off.
I'm using a rubber mallet and tried both sides for like over 30 minutes now and still couldn't get it off..
Any tips?
      08-28-2018, 11:03 PM   #2
808X1
80
Drives: F48 X1 M-Sport
Any tips?
Try spraying some WD40, then pound it out again. U have to put a little muscle into it, than just tapping it.
      08-29-2018, 01:38 AM   #3
The Beast
The Beast's Avatar
268
Drives: VW Transporter Sportline
Put a wooden block behind the edge of the tip. This will allow you to transfer a little more force and also allow the use of a heavier steel hammer without damaging the original tip...
      08-29-2018, 12:14 PM   #4
simon.
922
Drives: F48 25D mSport
What I do. Use wooden block to help tap replacement ones on as well, just wrap in a cloth to protect the tips & place square across the whole face.
      09-02-2018, 09:58 PM   #5
eligibleli
I was able to utilize both WD40 and the wood brick and it worked like a charm...
Guess my mancles wasn't there that one day!
      11-04-2018, 09:52 AM   #6
Edtheted
Edtheted
Edtheted's Avatar
17
Drives: 2017 X1 1.8 sDrive xLine auto
Why remove it?
Eddy Priest
      07-31-2019, 08:11 AM   #7
stylesx
Drives: BMW 330ci E46
Is it just me or does it seem like the right pipe is larger than the left ? The right one seems to have a butterfly flap inside
      07-31-2019, 02:24 PM   #8
808X1
80
The right does have a butterfly flap, as that will open when Full Throttle. Most of the time the flow will be directed to the left pipe.
      07-31-2019, 02:30 PM   #9
kavatski
147
Drives: 2023 X3 30iX
Or you can fix it so the valve is always open. I did, and I like the extra noise on startup, but haven't noticed any real difference when underway. Too bad they didn't make this thing sound more like the JCW Countryman with the same engine.
      07-31-2019, 02:42 PM   #10
stylesx
What about the size difference? are the pipes the same size? by eye the right one with the butterfly looks larger in diameter
      07-31-2019, 07:01 PM   #11
00max00
19
Drives: BMW X1 - option loaded
Like a popcorn machine? Nah, thanks.
      07-31-2019, 07:25 PM   #12
kavatski
147
Speak for yourself - I'll always want a little character from the exhaust on my cars, and I like the burble and popping on the overrun. The X1 with both pipes open sounds good on a cold start but it's too quiet to suit me while driving. A driver-switchable valve exhaust similar to the JCW Pro kit would be just the ticket.
      08-02-2019, 01:54 PM   #13
billnchristy
1604
Drives: 2022 M440xi GC
That’s all in the tune, you can get that without changing the exhaust. Problem is the car is so insulated you won’t hear it much. My m35i makes cool noises but it’s rare to hear them. I’m half tempted to make the actuated side a straight pipe and keep a muffler on the other. For some reason on x2 the actuator is on the drivers side unlike x1.
      08-17-2019, 04:53 AM   #14
ventjock
65
Drives: 2020 M340i
I can attest to the above. I recently posted a video of my exhaust notes after a tune was flashed in. It’s hard to hear anything other than the intake from inside the cabin. Even with all the windows down. Any ideas on how to remove some of the sound deadening on the X1? I don’t want to make the exhaust annoyingly loud, but I’d like to hear the notes.
