BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) coding for tire pressure and temperature in tpm display
      01-04-2019, 11:11 PM   #1
X1604M
X1604M's Avatar
56
Drives: 2018, F48 28i
2018 BMW X1 F48  [0.00]
hi, I have 11/2017 built 2018 f48. I tried coding to show tire pressure and temperature using Bimmercode. but only blank digit shows beside the four wheels on the display. the wheels are showing green colour before and after coding. Any help and thoughts abt how it can be done? I am not even sure if it can be coded.
      01-05-2019, 01:21 AM   #2
Douggie
142
Drives: BMW X1, X3
You have to first make sure your car has real tpms hardware installed. I believe it's the 2VB option.
X1604M55.50
      01-05-2019, 07:27 AM   #3
ejw2011
ejw2011's Avatar
94
Drives: x3 F25 35i, x1 F48 28i
Blank digits....
Tire pressure and temp not warm enough to register. Drive for awhile and check again.
Just noticed you're in Canada. If I recall Canada doesn't use TPMS but FTM and maybe explains why. Not sure?
X1604M55.50
      02-01-2019, 03:06 PM   #4
MJE60
MJE60's Avatar
Hi
Check and see if your tyre valves are metal or rubber. If they are metal then you have tpms sensors fitted (option 2vb on your car build list - you can do a vin build check online). With metal valves and tpms sensors you can adjust your coding via bimmercode to get pressure and temperature. If you have rubber valves you do not have tpms, instead your car measures rolling diameter of the tyre to give a pressure estimate and no temp reading is possible.
Be aware that if you do have tpms then after coding it will tell you to start driving, only after driving will it give you pressure and temp readings. Until you start driving (needs about mile) it will only show blank digits, the same as when you reinflate your tyres and reset the readings in the idrive menu.
X1604M55.50
      02-01-2019, 07:06 PM   #5
ramonE90-NL
Netherlands
35
Drives: bmw F30 320iA
My X1 has been in for service this week, and i think they did a sw update for the car. Because it now shows tire temp, different info for auto parking and when below 3 degrees celcius it shows a icey road under the car when you have the screen set to car info
X1604M55.50
      02-01-2019, 09:56 PM   #6
X1604M
X1604M's Avatar
56
thanks for all the replies. I found out that mine has rubber stem. that's why I don't see any pressure and temperature info on the display. Cheers.
      02-03-2019, 09:26 AM   #7
MJE60
MJE60's Avatar
Nice!, I like display. Thank you for sharing.
      02-11-2020, 09:40 PM   #8
X1604M
X1604M's Avatar
56
I found out that Canadian f48 are installed with the required hardware on DSC unit. But if the TPMS are installed on the wheels all the car needed is to code the option 2VB. But the question is how to code? I saw a post coded by Esys. Any one has and idea or know coding with Bimmercode? I appreciate any input from you all.
I installed TPMS on my wheels and made sure they are working. Following is the post I found.
https://www.bimmerfest.com/forums/sh...d.php?t=909092
      02-20-2020, 09:12 PM   #9
Douggie
142
Drives: BMW X1, X3
I found out that Canadian f48 are installed with the required hardware on DSC unit. But if the TPMS are installed on the wheels all the car needed is to code the option 2VB. But the question is how to dode? I saw a post coded by Esys. Any one has and idea or know coding with Bimmercode? I appreciate any input from you all.
I installed TPMS on my wheels andade sure they are working. Following is the post I found.
How do you know if your car has the receiver in the DSC unit?
      02-20-2020, 10:24 PM   #10
X1604M
X1604M's Avatar
56
I did look for the info online and found that later model BMWs (hard to know when it starts) have built in receiver in the DSC unit. I also looked up for F48 TPMS on newtis.info site. Now after I found the post on bimmerfest, I also have tire pressure and temperature display on my Canadian specs F48. But I also found out that Bimmercode can't perform VO coding. I used Esys without launcher. Credit to atzbmw and Shawn.
      02-21-2020, 01:56 AM   #11
Douggie
142
Drives: BMW X1, X3
Thanks. Good to hear that you got it done!
