09-01-2020, 02:27 PM | #23 |
129
Rep 424
09-02-2020, 11:29 AM | #25 |
404
Rep 1,104
So I spent more than an hour yesterday, seriously analyzing a way to 'modify something' that would be 'clean' and 'convenient' for the once-a-week I need to drive/park the car and tender it.
I have come to the the conclusion that nothing meets these tenants. Therefore, I am just going to live with what I did with my 'open the hood' tendering solution. I did move the cable a little bit under a bar so it is not so noticeable - for those who notice and know this BMW engine bay. This is the first time where I actually hadn't modified something due to an idea. The only location that I feel that could work 'real well' but such as pain in the ass to modify (i.e. get out) is the drivers side bottom front vent area. You could easily put that connector there and it wouldn't be seen, but good enough protection to the elements. And it would look cool once you see it. However, I don't see the effort at this point. If I drove my car daily and wanted to do this, then yeah, I would do it. Otherwise, there ya go folks! |
09-02-2020, 12:57 PM | #26 |
129
Rep 424
Yeah you're probably right, the car is nice and tight, no gaps or wasted surfaces. Best to leave it tucked away.
Thanks for the idea though, I'm going to do the same before the snow flies here. |
09-02-2020, 02:48 PM | #27 |
303
Rep 1,084
I thought you were leaving the car longer spurts unattended.. not just a week. Honestly that's pretty overkill. If you are leaving your car for more than 3 weeks at a time I would say you should plug it in more, but once a week is just too much! The other fun suggestion would be the front grille like in Canada we plug in our cars, but fishing it out from a tucked place is just not cool. Another suggestion that isn't that great either would be to fish it in through the car and mount the plug either in some place crafty or just let it hang under the dash. But at that point I would just rather open up the hood
09-03-2020, 06:36 AM | #28 |
404
Rep 1,104
If I didn't tender, here in the Midwest when it is too Hot or too Cold after about 6 to 7 days the BMW when entering vehicle provides me a message that it shut down auxiliaries and furthermore cannot due remote venting, etc..
When I do drive it is not long and far enough for alternator to charge battery. I get home and battery is usually at 25 to 40 percent after 100 percent charge pre drive. |
09-03-2020, 08:17 AM | #29 |
129
Rep 424
Agreed, the adaptive/regenerative charging works the battery pretty hard, and short trips especially. The very first thing the shops do is to charge the battery when one comes in - it takes a lot of questions off the table.
This is one reason the car is equipped with an AGM-type cell. These are good for deep-discharge and large reserve. The charging algorithms depend on it for their efficiency. Topping it off with a proper charging unit during times of light use is a good thing IMO. |
09-03-2020, 10:26 AM | #31 | |
303
Rep 1,084
09-03-2020, 11:53 AM | #32 | |
129
Rep 424
Watch the little efficiency gauge at the lower right of the instrument - when the blue bars are showing, it's in regen mode. The system engages the torque converter and uses the car's momentum to drive the crankshaft while it re-energizes the alternator. In many other situations, it's only putting out a maintenance charge. In Eco mode, it's even more extreme. |
09-08-2020, 02:40 PM | #33 |
180
Rep 375
Drives: 2020 M2C DCT
I periodically put my X2 on a charger. It typically takes several hours to fully charge the battery, even if the car has just been driven, which demonstrates the downside of BMW's pursuit of fuel economy at all cost. Often when I initially connect the charger, the current draw can be 15 A or more for a few minutes.
I use a HP 6033A laboratory power supply to charge my cars. It's not suitable for unattended charging, but gives direct control and visibility of the charging voltage and current. I charge at 14.4 V until the charging current is 1% of the Ah rating, which is fairly widely used in the battery industry. After charging, I let the battery float at 13.6 V for several more hours, unless I need to drive the car. |
09-16-2020, 12:38 PM | #34 |
31
Rep 57
With the batteries that our M35i cars have, can I still use any generic battery tender or trickle charger or do I need something with specific power/amperage? Working from home means I don't get to use my car out everyday so I would like to connect it to a tender when it's sitting on the driveway.
TIA Yes, I called it a car
2020 Mineral Grey X2 M35i
-jay |
09-16-2020, 01:00 PM | #35 | |
129
Rep 424
Regarding power, it depends. The car will certainly draw a significant current when initially hooking it up, because of the designed-in charging parameters. However, the battery will charge just fine at lower power, if given time. Net-net, an AGM-specific maintenance charger of pretty much any power rating will work as a tender. CTek makes an excellent line, if somewhat pricey for the features you get. |
jcatral1431.00 |
10-20-2020, 10:16 AM | #37 |
31
Rep 57
Thanks for sharing! May I ask why you changed it? Was it dead or won't hold a charge anymore? What kind of driving do you do? A lot of short trips or don't use the car a lot? Thanks and sorry for the questions.
-jay |
10-20-2020, 10:20 AM | #38 |
Rep 10
I changed because you can hear that car struggling when starting. I measure voltage and when stand still 12.3V, during starts it is only 8.1V and later is going to 11.6V. When alternator starts to charge it is cca 14V. I am driving longer routes that's why I am supprised a bit...
10-20-2020, 11:28 AM | #39 | |
31
Rep 57
Thanks for your post
-jay |
10-20-2020, 12:12 PM | #40 |
129
Rep 424
This is the diesel engine X1, right? I can imagine it would show weakness sooner, but it's definitely early. Well, good to replace before the weather turns cold!
xcelir8bmw404.00 |
10-23-2020, 08:45 AM | #41 |
Rep 10
10-25-2020, 10:52 AM | #42 |
180
Rep 375
According to the parts department of the dealership where I bought my X2, they are equipped with either a 70 Ah or 80 Ah depending on the options. No idea if that's true, but I haven't heard a better explanation of why there are two battery sizes.
10-25-2020, 10:55 AM | #43 | |
180
Rep 375
mil12344.50 |
