BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) 13mm Wheel Spacers on X2
      01-08-2022, 11:42 AM   #1
Rich807
66
Drives: X2
Just slapped 2 sets of Burger 13mm wheel spacers on my X2 running OEM 225/50R18s on OEM 7.5" wheels.
https://burgertuning.com/products/g-...b06615de&_ss=r
Pics don't do the change for the better justice. I wanted to stay with a 'square' setup & didn't want to overstep so I went 13mm. In hindsight one could go 15mm square with zero problems at all IMO. I will eventually be going to about an inch wider 18 tire so still have plenty of room for that.
The kit seems super good quality. Everything fit like a glove. In about 20 min I had all 4 wheels done. Longest time was applying anti-seize on the pieces. I ordered the parts 1 late afternoon & they were at my house less than 24hrs later. Pretty amazing.
‘22 X2 S-Drive. Running 13mm Wheel Spacers & 255-wide 'go-flat' tires.
Former Owner '11 X5 35d w/Sport Package
Former Owner '86 528
Appreciate 2
adriang63.50
      04-05-2022, 08:17 PM   #2
marticztn
marticztn's Avatar
66
Drives: 2017 X1 xDrive28i
Looks awesome! Do you think 15mm would be too much? I'm still deciding if I should get the 13mm or the 15mm one for my X1.
      04-06-2022, 06:39 AM   #3
Rich807
66
Drives: X2
IMO you could go with 15mm spacers without issue, especially if you're not planning on going to a bigger tire on the same OEM wheels later on.
I took a guess on what size to get, partially decided to go with 13's due to knowing I was later planning on running bigger tires (at least wider ones).
      04-06-2022, 08:35 AM   #4
marticztn
marticztn's Avatar
66
I'm also considering lower my X1 for about 30mm, is that going to be fine with 15mm as well?
      04-06-2022, 11:42 AM   #5
tedgelee
Drives: BMX X2
I have 13 in the front and 15 in the rear and I think it’s perfect.
Sorry for the dirty car 😬
Rich80766.00
      04-06-2022, 11:48 AM   #6
Rich807
66
Drives: X2
Looks good. I decided I wanted to stay with a 'square' vs 'staggered' setup hence the 13mm front & back.
      04-06-2022, 11:50 AM   #7
marticztn
marticztn's Avatar
66
Haha no worries! Why 15mm rear and 13mm front? Is there a reason to do it with different sizes? I'm not familiar with adding spacers to cars so I'm very curious.
      04-06-2022, 01:22 PM   #8
tedgelee
Drives: BMX X2
I wanted the more aggressive look.
      04-06-2022, 01:25 PM   #9
marticztn
marticztn's Avatar
66
Gotcha! It looks pretty good on yours! I ended up bought 15mm x4
      04-14-2022, 11:31 AM   #10
RedmanX2
Drives: X2
Question
any pics? I'm trying to decide if should I go 15 mm rear and 13 mm front or 15 mm x4.
      04-14-2022, 11:35 AM   #11
marticztn
marticztn's Avatar
66
I'm still trying to find a shop in my area so I can put them on, I'm living in a small town so finding someone to do this kind of stuff is pretty hard lol, I'll post pics once I installed them!
      04-16-2022, 09:38 AM   #12
Rich807
66
Drives: X2
Guessing you don’t have a jack & lug nut wrench or socket set to spin off the nuts?
Neighbor help do it for you if you’re physically not able?
This is arguably the easiest thing you can do on your car.
      04-16-2022, 10:48 AM   #13
marticztn
marticztn's Avatar
66
Guessing you don't have a jack & lug nut wrench or socket set to spin off the nuts?
Neighbor help do it for you if you're physically not able?
Yeah, I don't have the tool. Spacers are easy to put on, but I also have lowering springs to put on, that is something I don't feel confident to do by myself :
Anyway, I found a reputable shop that can help me to install everything, it's gonna cost me for around $810 to install everything (Springs + spacers + alignment), it's a bit pricey but that's my only option for now, lol
      04-16-2022, 12:03 PM   #14
Rich807
66
Drives: X2
Gotcha. Didn’t register you were doing springs as well. Good luck
      10-09-2022, 12:18 PM   #15
Ratpack
Drives: 2016 BMW X1
Burger 15mm wheel spacer install
Just installed Burger 15mm all around on my stock 225/45/19. Fills the wheel well perfect. I was thinking of going with a wider tire once I replaced the runflats….not so sure anymore. An unexpected plus is the handling & steering feel….more responsive. I’ve also added an AFE CAI and did the exhaust flap mod and in sport mode the car feels completely different than before!
      10-17-2022, 12:52 PM   #16
Rich807
66
Drives: X2
Looks absolutely amazing!
