07-17-2022, 08:11 PM | #1 |
512
Rep 357
Best cold weather dry surface tires?
Although it's still warm, I've picked up an extra set of wheels as my M2 is a 4 season daily driver and I'll need an alternative to summer-only tires soon. But there's a catch.
Discussions of cold tolerant tires often turn to snow/wet traction capabilities and rightly so in most cases. My needs are a little different, however. What I need isn't a winter (snowflake) tire per se as I won't take the M2 out if there is any appreciable chance of snow. And probably similar for rain. What I really need is the tire that can grip dry pavement the best in low temperatures to below freezing (say as low as -10° C but with most days in around 0-5° C). Most of my daily driving never elevates the tire temperature much (short trips). I've run Pilot All Season 4s and have been happy with them. The Continental DWS06 read like they are as good, maybe better. That said, reviews incorporate a variety of criteria that are less important to may particular interests (e.g. wet handling, light snow). So, if anyone has an opinion on a best or better option for a cold weather dry pavement tire that grips well, please advise. |
07-17-2022, 08:25 PM | #2 |
6453
Rep 3,009
I had a set of the previous gen DWS, they were absolutely amazing new but as they wore, even a little, snow and really cold weather performance fell off a cliff. But for your needs, i cannot think of a better 4 season tyre given i imagine the newer gen to be better than the ones I had.
07-17-2022, 08:29 PM | #3 | |
2015
Rep 2,659
Believe it or not I was passing jeeps that were slipping and many other suvs with my rwd e90. |
H2O_Doc511.50 |
07-17-2022, 08:47 PM | #4 |
6453
Rep 3,009
He's running them 4 seasons though, the Blizzack will turn to cheese in mid summer. I have had 3 sets of "performance" winter rubber and again when new, all good, by 50% wear they were damn near useless in the snow or ice.
H2O_Doc511.50 |
07-18-2022, 10:26 AM | #5 |
4462
Rep 9,160
Agreed, AS4 are about as good as it gets if you need cold weather capabilities.
H2O_Doc511.50 DougNBodie27.00 |
07-18-2022, 10:45 AM | #6 | |
6453
Rep 3,009
Tyres, tyres.... tyres. |
07-18-2022, 11:06 AM | #7 | ||
4462
Rep 9,160
07-18-2022, 11:14 AM | #8 | |
1542
Rep 1,076
Drives: 2009 E92 M3 Dakar Yellow II
As he was pulling my 4Runner out of an icy ditch... |
07-18-2022, 11:19 AM | #9 | ||
2015
Rep 2,659
folks don't take physics and chem classes, and mandatory driving education is non existent. A dude in CT4 with all seasons could not go up the hill. I stopped and asked if he needed a ride. He said I bought this goddamn car with awd and it won't go up. Then he said he had all seasons and when I looked they had 2-3 mm tread in 2 inches of snow covered roads. I asked him do you put your sneakers on when walking thru snow? Then the car stared to slide backwards. He got anxious and waited for tow truck. For me there is no all season tire that is good in 4 seasons period! They are different compounds. Boots in the winter and running shoes in the summer! |
540iSUP703.00 |
07-18-2022, 11:27 AM | #10 | |||
2015
Rep 2,659
when I lived in Buffalo most of the time cars that ended up in a ditch were f150, Tahoe and similar. I had Nissan Sentra and never had issues as long as it was driven appropriately for conditions and maintained distance. An interesting test btw rr and gti would be going down the hill from 40mph to zero on snow covered road. |
07-18-2022, 11:56 AM | #11 | ||
2015
Rep 2,659
spammysammich1541.50 |
07-18-2022, 12:25 PM | #12 | |
2872
Rep 3,445
07-18-2022, 12:32 PM | #13 |
1542
Rep 1,076
A really bad habit AWD/4WD drivers have in snow, slippery conditions is utter disregard for weight transfer. "My car has AWD, why did it spin when I let off the gas mid turn?"
WolfGTI688.50 |
07-18-2022, 01:13 PM | #14 |
2870
Rep 1,758
A winter tire tread by design has deeper knobby treads and the benefits would be lost in ONLY dry weather. Their compounds are also softer which necessarily don't help for typical "responsibly fun" driving... All season would fit your use-case better, as recommended above the AS4 or DWS6 seem to be the top two. I don't know your climate but if -10C is your lowest, all seasons should perform more than fine.
07-18-2022, 01:37 PM | #15 |
Weirdo
431
Rep 182
Check out Nokian, some of the best winter tires made. Ran two sets of Hakkapeliitta's, probably a bit more snow focused, but there's other balanced options. The WR is an all weather tire, with good balance of cold/snow and dry performance.
07-18-2022, 01:44 PM | #16 |
6453
Rep 3,009
YEah as much as i am an advocate for winter rubber, the OP clearly doesn't need a dedicated winter set. All seasons with a winter consideration will be the way to go.
07-18-2022, 07:50 PM | #18 | ||
2015
Rep 2,659
so why are snows mandatory in Europe and Canada? why dies bmw offer winter wheel packages? anyway snows for me I know I know TR hopes to increase sales … |
Th3Walrus327.00 Pauldunlop13417.50 |
07-18-2022, 08:04 PM | #19 | |||
512
Rep 357
Mavus2014.50 |
07-19-2022, 12:10 AM | #20 |
5139
Rep 3,235
Been running a set of Michelin Cross Climate 2's for a couple of years. Absolutely love these tires. They're all seasons but are winter tire rated. I've driven through all manners of conditions from hot summers to cold winters with snow on the ground. It's performed in all of these conditions.
07-19-2022, 07:49 AM | #21 |
6453
Rep 3,009
WHy are people not listening... HE DOESN'T NEED A WINTER SET.
07-19-2022, 08:10 AM | #22 |
BMW Owner Since 1971
2236
Rep 1,393
Drives: 1964 700 Sport Cabriolet
I've used DWS for years and currently have the 06 on my 128i Msport 6-speed on 18-inch Apex wheels as year-round tires. My driveway is a quarter-mile-long undulating terrain and I don't expect the Contis to get me there when snow and ice are on the ground but otherwise they've been fantastic tires. Snow is actually not so bad but around here it quickly turns to packed ice. I'm sure the AS4 would perform at least as well but the Contis have been great for me. I also have them on two E28s and an E39. I have a dedicated set of snows on wheels but haven't had to put them on in years around here.
When I first put the latest set on my 128i I thought I'd screwed up everything I loved about that car. The feeling lasted maybe 300-miles. Don't know yet if I got used to them over my track tires, or if they just had to break-in, but the confidence and precision of the handling hasn't disturbed me for well over a year now. Just saying that in case you go with the Contis and initially feel you may have made a mistake! |
