BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Burger Tuning JB4 install on B48 X2 m35i
      02-08-2021, 01:44 PM   #397
rice_rocket88
No_Country
298
Drives: E60 F48 F39
I also had that idea in my head, but just decided to leave it. I know at least one person locally with an X1 that did the straight pipe in the same location.. I believe he also ended up deleting the mufflers eventually.
      03-04-2021, 03:25 PM   #398
rice_rocket88
No_Country
298
Drives: E60 F48 F39
Hmm very interesting.. although I'm used to the way it drives.. I might like to hear a bit more how that adjustment affects the car before I muck with it. Did you ever go blasting around on map2 with the JB4 intake yet? Ever get it to go to failsafe mode? I realize it may be super cold and inconvenient to try.
      03-04-2021, 06:25 PM   #399
djetok
djetok's Avatar
Drives: m2
Originally Posted by 21M235IXGC View Post
I will probably just do the straight pipe in place of the mid cat and resonator and have to quad tips welded in . It already sounds good stock so with just that little blockage released and some nice dual tips on each side I'll be good .
Found these online for like $170 buck for the set . I won't clamp them on but have the oval part on the oem pipe cut to where it's circular and then weld in these and be done
Any update on the exhaust? Would love a bit more sound and that has me missing my v8
      03-05-2021, 07:47 AM   #400
xcelir8bmw
xcelir8bmw's Avatar
402
Drives: 2022 BMW M240ix
We are on beta. Is this solid or not firmware?
      03-05-2021, 10:43 PM   #401
xcelir8bmw
xcelir8bmw's Avatar
402
I will also try this tomorrow!
      03-06-2021, 02:42 PM   #402
rice_rocket88
No_Country
298
Drives: E60 F48 F39
I think mine goes all the way down to 4 degrees of timing in map2 .. whoop loaded a bunch of mine and it even went down to 0/1 a few times. I haven't taken a log lately, I just turned on the jb4 app and looked through the last few runs.
      03-06-2021, 03:49 PM   #403
xcelir8bmw
xcelir8bmw's Avatar
402
Installed the latest firmware and set DWP to 70. The drive seemed pleasant with no issues in the errands and distance I drove today.
chowser512025.00
      03-09-2021, 06:08 AM   #404
BlownLSX
BlownLSX's Avatar
No_Country
213
Drives: C6Z, X3MC
Yeah sometimes I like map 1 better , I know map 2 is a little faster but these Aisin tranys are only rated for like 355ftlb/480nm ftlb torque so not sure how much over that we can go befor 1 of 2 things happen . Ecu automatically limits the powers to the tranny there by pulling timing ( which may already be happening ) or by premature wearing the torque converter out ... thoughts
Tremec rated the t56 at only 500tq and a ton of us have been sending 900+ at them for years in corvettes and other cars with the same trans. Keeping the fluid clean and cool is key. I highly doubt this trans will break at these power levels. Look how much power people are sending though the zf in the Supra without changing anything.
      03-09-2021, 05:40 PM   #405
BlownLSX
BlownLSX's Avatar
No_Country
213
Drives: C6Z, X3MC
I know the ZF transmission is strong and has proven itself , but I haven't seen much data to say that the
Aisin transmission is this car the " 8G45AW"
Can handle above it's rated 480nm torque .
Blown do you info from the dealer on this tranny as to what it can be pushed .
They don't give us any technical information. BMW doesn't believe in rebuilding transmissions. We go as far as the valve body assembly. After that. Replace with new unit and send back. If it's anything like most bmw drivetrain stuff it will handle at least 50% more than rated for.
      03-09-2021, 06:13 PM   #406
//TMT
//TMT's Avatar
129
Seems to me, if Launch Mode is factory-standard in the X2 M35i, it certainly seems like BMW has confidence in the trans.
      03-09-2021, 08:56 PM   #407
billnchristy
1604
Drives: 2022 M440xi GC
Aisin released an even higher torque model recently. Kinda says that they didn’t think so to me.
      03-10-2021, 08:38 AM   #408
xcelir8bmw
xcelir8bmw's Avatar
402
I have always wondered about the ASIN myself and using the JB4 was always a chance.
If we actually got real numbers on max threshold and if I had to remove the JB4 I would do so.
I just hope it goes to our favor with JB4 increased power and torque because it is wonderful on map 2.
      03-10-2021, 01:19 PM   #409
billnchristy
1604
It would be a bad design if it couldn't handle 20% over
      03-14-2021, 07:00 PM   #410
xcelir8bmw
xcelir8bmw's Avatar
402
Drove extensively today on new firmware and updated settings. 45 degree F.
Car runs soooo good at all RPMs and has no lag but definitely get up and go.
      03-17-2021, 06:43 PM   #411
xcelir8bmw
xcelir8bmw's Avatar
402
What setting r u running on the part throttle waste gate ? I had mine at 70 and got tuner code
The tuner code is probably due to your intake.
      04-05-2021, 02:29 PM   #412
xcelir8bmw
xcelir8bmw's Avatar
402
FYI FWIW -
The latest firmware with the setting 70 recommended - well... let me tell you, that I've been driving the car lately and I highly doubt that it is in my head, but the car overall seems to be even more of a demon, even in vast temperature changes.
DO IT.
      04-05-2021, 04:41 PM   #413
rice_rocket88
No_Country
298
Drives: E60 F48 F39
Sounds like fun! I'm not sure what "default" settings were, nor have I seen the menu for our car. The N54 cars had a problem with the wastegates rattling as the cars got older, so there was rpm tuning to "open" or decrease that number at low speeds so the rattle would be better. I had "thought" that it was default at 80 and people were turning it down. I don't know what 70 means for this car. Certainly if the wastegate is closer to "shut" at 100 then it builds boost pretty darned fast. I'm tempted to mess around, but still a bit lazy to reflash and play around. Now a days it's just get up and go to work without much time to goof off with the car.
      04-08-2021, 01:41 PM   #414
rice_rocket88
No_Country
298
Drives: E60 F48 F39
Yes I experienced spikes before, but that will settle down pretty fast. This is pretty much what was causing the JB4 to go into failsafe mode. Please do take lots of pictures of the supersprint pipe! (and cost would be great) From what I gather the front will go on, but you'd have to chop the mid pipe and use a slip clamp. Should be easy enough DIY at home on my quickjack!
      04-08-2021, 08:03 PM   #415
xcelir8bmw
xcelir8bmw's Avatar
402
It is the intake doing it, guaranteed!!!
      04-09-2021, 08:31 AM   #416
xcelir8bmw
xcelir8bmw's Avatar
402
Wow, ok...
Too much air if you have exhaust as well.
      04-09-2021, 08:35 AM   #417
xcelir8bmw
xcelir8bmw's Avatar
402
What was DWP set to before we changed it, 100?
Go back to default and see.
      04-09-2021, 10:40 AM   #418
billnchristy
1604
Can you link the pipe you bought? Can't find it on ecs
