BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Windscreen fogging during cold/wet days
      04-18-2021, 03:32 AM   #1
normanho23
Drives: X1 F48
Is there any way to disable the air vent at the top of the dashboard?
The cold air from the AC vent is causing lots of fogging or condensation at my front windscreen exterior.
Stay in Singapore and cold AC is on all the time. Just a matter of temp but usually between 20-22 celsius . Any temp higher will be too hot for driver and passenger.
      04-18-2021, 10:39 AM   #2
Paco II
33
Drives: BMW X1 2021
There is of course the front windshield defogger designed just for this issue.
Additionally, be sure to keep the inside of your windshield nice and clean. A dirty windshield lends itself to fogging up.
      04-18-2021, 11:07 AM   #3
dianebrat
110
The OP was saying that the outside surface fogs not the inside, and the wipers could take care of that, additionally the HVAC controls when in manual will let you direct air to middle or low without the windshied vents.
So I'm a bit unclear why the OP hasn't used either of those methods to reduce the fogging.
      04-18-2021, 09:57 PM   #4
normanho23
Drives: X1 F48
I used rain-X 2in1 cleaner to clear the windscreen exterior. This could be the reason for the fogging.
Have used cerium oxdie power to do a thorough cleaning of the windscreen and to remove the rain-x coating. Hopefully it works.
      12-22-2021, 01:38 AM   #5
lwsung1989
I just get my new car few days ago. I experienced the same problem as yours which had fogging on my windscreen exterior. May i know whether you have the problem solved?
      12-22-2021, 01:42 AM   #6
oakey46
159
I’ve found rain-x to be worthwhile on the side windows, but would never use it on the windscreen.
      12-23-2021, 10:02 AM   #7
Qsilver7
Qsilver7's Avatar
4442
Drives: F06 650ix GC / F15 X5 50i
As mentioned in previous posts…if the condensation is on the exterior…use your windshield wipers. You should have a single wipe feature by just pressing downward on the stalk.
You can also use the air direction button to direct air toward the passengers or floor vents (or both)…and NOT have it direct air toward the windshield. Unless you have a different IHKA control panel…there is a button that allows you to select which vents you want the air to blow from…defrost (windshield), dash vents, and floor vents. You can have the air directed to one, a combination of two, or a mix of all three (this info is in your owners manual…which you also have a built in owners manual in iDrive):
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      12-24-2021, 03:49 AM   #8
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Each to their own! It is made specifically for windscreens.
RAIN REPELLENT
Rain-X Rain Repellent dramatically improves wet weather driving visibility. Simply apply the treatment to exterior glass and watch the raindrops fly off your windscreen while driving along.
https://rainx.co.uk/
2012 BMW 320d Sport (F31).
      12-24-2021, 11:07 AM   #9
oakey46
159
RAIN REPELLENT
I know what it says on the bottle but, when I've used it on various car windscreens I've found that after a while it starts to streak when the wipers are activated. As a result, I've had to use a glass cleaner (Autoglym) to remove it.
As I said in my previous post, it's good on the side windows and I've also used it satisfactorily on the exterior tailgate glass, because that wiper doesn't get the same level of use as those on the front screen.
If you're happy to use it on the front screen, that's great, but not for me.
      12-24-2021, 11:25 AM   #10
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
OK. You did not say that you had used it and it gave streaky results! You said you would not use it on the windscreen without qualifying the statement. Now I understand. That was the reason for my first response.
I do not use it myself. It is praised on other forums that is why I mentioned it.
I had the exterior of my car treated with https://www.gtechniq.co.uk/ products including the glass and found it worked OK. Like many of these products they are not a final solution, they just help.
