12-26-2019, 12:27 PM | #1 |
49
Rep 69
Traffic Jam Assist (5AR & Quidzel HOD Emulator)
Hello.
"Quidzel HOD Emulator" was imported from the United States, "5AR" was added to "FA", and "VO coding" was done. And we realized "Traffic Jam Assist" without touching the steering wheel. I'm happy.
BMW 320d xDrive Touring M Sport(G21) Production Plant: Munich, Production Date: 2021-02-25 |
12-26-2019, 01:25 PM | #4 |
49
Rep 69
My "F39" had optional "5AT" and "5DF", so implementation was easy.
URL https://bmwi.bimmerpost.com/forums/s....php?t=1486265 https://quidzel.com/
tom @ eas8310.00 |
12-27-2019, 10:12 AM | #6 |
303
Rep 1,089
Very cool! I opted for my heated steering wheel.. so I fear I may not be able to implement this. I am not sure what hardware I may be missing. From what I understand the system is camera based.. but my steering wheel is not the correct one I'm sure, as it was not optional to have both together (which bummed me out)
12-27-2019, 08:32 PM | #7 | |
49
Rep 69
P.S. The hardware missing from the car was sent by Franklin via USUP. It took two weeks to arrive in Japan.
01-09-2020, 11:42 AM | #8 |
49
Rep 69
This is the FDL item reflected after the VO of 5AR addition.
Hi,
Additional information. This is the FDL item reflected after the VO of 5AR addition. SAS LDM_Stauassistent_vorhanden Left: false = 00 Right: true = 01 EPS C_ADAS_IF Left: C_ADAS_INACTIVE = 00 Right: C_ADAS_ACTIVE = 01 BDC_BODY ComAdapterPdu_31C_Anzeige_Fahrerassistenzsystem Left: nicht_aktiv = 00 Right: aktiv = 01 LRE_VERBAUT ... Reverted to "nicht_aktiv". Left: nicht_aktiv = 00 Right: aktiv = 01 HOD_VERBAUT Left: nicht_aktiv = 00 Right: aktiv = 01 LIN_VARIANTE_MFL Left: ACC_Sports_SLD_EINSTUFIG = 27 Right: ACC_Sports_STA_SLD_EINSTUFIG = 2B LIN_VARIANTE_LRE ... Reverted to "nicht_aktiv". Left: nicht_aktiv = FF Right: lre_lhz = 02 PERSONEN_WARNUNG_STA Left: nicht_aktiv = 00 Right: aktiv = 01 KOMBI2 3000_18_18_8(KL_PREDRIVE_F17_STA) Left: nicht_aktiv = 00 Right: aktiv = 01 3003_4_4_64(HUD_STA_ENABLE) Left: nicht_aktiv = 00 Right: aktiv = 01 3003_7_7_32(STA_ENABLE) Left: nicht_aktiv = 00 Right: aktiv = 01 3004_14_14_8(SU_SW_DRDY_2_TIMEOUT) Left: nicht_aktiv = 00 Right: aktiv = 01 3004_14_14_16(SU_SW_DRDY_2_APPL) Left: nicht_aktiv = 00 Right: aktiv = 01 3004_14_14_32(ANG_ACPD_TIMEOUT) Left: nicht_aktiv = 00 Right: aktiv = 01 3004_14_14_64(ANG_ACPD_APPL) Left: nicht_aktiv = 00 Right: aktiv = 01 3004_14_14_128(ST_STAB_DSC_TIMEOUT) Left: nicht_aktiv = 00 Right: aktiv = 01 3004_15_15_1(ST_STAB_DSC_APPL) Left: nicht_aktiv = 00 Right: aktiv = 01 3004_15_15_2(DISP_COSA_HYB_TIMEOUT) Left: nicht_aktiv = 00 Right: aktiv = 01 P.S. My F39 doesn't have a warm steering wheel ... "LRE_VERBAUT" and "LIN_VARIANTE_LRE" have changed their settings back to "nicht_aktiv".
BMW 320d xDrive Touring M Sport(G21) Production Plant: Munich, Production Date: 2021-02-25 Last edited by Takabo; 01-22-2020 at 04:06 PM.. |
01-20-2020, 11:13 PM | #9 |
338
Rep 1,646
what is the difference between ACC Stop and Go and Traffic Jam Assist?
Is it that the Traffic Jam Assist also steers the car automatically? And does that Quidzel device have to stay attached like that permanently? thanks
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K Previous: 2009 335i LCI, Bluewater |
01-20-2020, 11:56 PM | #10 | |
49
Rep 69
ACC Stop and Go: Traffic Jam Assist: "Traffic Jam Assist (TJA)" is not a self-driving car, just an assist in a traffic jam. With the "Quidzel HOD Emulator", TJA can be realized without changing the steering wheel. Moreover, TJA can be realized even if you release your hand. The "Quidzel HOD Emulator" should be left in place of a handle with a touch sensor.
BMW 320d xDrive Touring M Sport(G21) Production Plant: Munich, Production Date: 2021-02-25 Last edited by Takabo; 01-21-2020 at 12:04 AM.. |
01-21-2020, 03:27 PM | #11 |
338
Rep 1,646
Thank you Takabo. I have the ACC, so was wondering whether it's worth getting the traffic jam assistant...
01-22-2020, 04:15 AM | #12 |
49
Rep 69
And here we are doing additional FDL.
Changed the maximum speed of traffic jam support from 60 km/h to 99 km/h ECUs → SAS → 3000 FAS, FC → LDM_QalcgRel_v_Tacho_aktiv_kmh = Werte = 63 (Default: Werte = 3C ) Effective minimum traffic congestion support speed from 35km/h ECUs → SAS → 3000 FAS, FC → LDM_QalcgRel_v_Tacho_aktiv_low_kmh = 35(Default: 55) P.S. The following settings are required when testing on public roads. Remove restrictions to allow congestion support on all roads ECUs → SAS → 3000 FAS, FC → LDM_STA_Einschraenkung = keine Einschraenkung (Default: nur auf Autobahn und Landstrassen_mit_baulicher_Trennung)
02-10-2020, 04:32 AM | #13 |
49
Rep 69
Hi,
I retrofitted Traffic Jam Assist at F39. At that time, I thought 5AT was essential. . . My friend F45 is a 5AS equipped car that is not a 5AT. We recently implemented a 5DF retrofit. Today we are retrofitting Traffic Jam Assist (5AR & Quidzel HOD Emulator). 5AR (Quidzel HOD Emulator) can operate on a car equipped with 5AS + 5DF. P.S. "5AS + 5DF" is almost the same as 5AT.
02-18-2020, 03:24 PM | #15 |
General
8310
Rep 18,878
Drives: BMW
We've installed a bunch of TJAs on i3s and X5s. Looks like we will need to try this out on the X2 next.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
Takabo49.00 |
03-19-2020, 07:12 AM | #16 |
49
Rep 69
automatic start
Hi everyone,
After the first 3 seconds of stopping, the RES button will extend the automatic start to 30 seconds. It is very convenient.
06-20-2020, 03:21 AM | #17 |
49
Rep 69
Hello everyone,
How to create a DIY HOD Emulator for Traffic Congestion Assistant (TJA) has been released. It is unknown if it works with X2 (F39). https://www.bimmerfest.com/threads/d...t-tja.1382749/
BMW 320d xDrive Touring M Sport(G21) Production Plant: Munich, Production Date: 2021-02-25 Last edited by Takabo; 06-30-2021 at 10:32 AM.. |
06-24-2020, 03:33 PM | #18 |
49
Rep 69
Hi everyone,
I made DIY HOD Emulator. I will test it on the weekend.
06-26-2020, 11:25 AM | #19 |
49
Rep 69
DIY HOD Emulator
Hi everyone,
The DIY HOD Emulator worked. Success.
07-24-2020, 04:44 PM | #20 |
64
Rep 750
Well I placed an order for this and I'm waiting on the emulator. In the meantime I figured I'd get myself acquainted with esys. Quick question, with F39 I chose both separately of the F056 without the _DIRECT on the connection list (out of the 4 options) and I am able to read FA but not SVT. Instead I can read ECU. I read that for some F15's you have to read ecu instead of svt. Is it the same for F39's for anyone who has tried?
There is an error if I choose Read SVT |
07-25-2020, 07:25 AM | #21 | |
49
Rep 69
Select “Read (ECU)” for F39. Please do your best!
06-30-2021, 10:44 AM | #22 |
49
Rep 69
Hello,
I remove the "DIY HOD Emulator" and switch from F39 to G21. The F39 was a very good car. Thank you, everyone.
