BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Aftermarket intake options
      03-13-2019, 09:36 PM   #1
Xtiano87
Drives: BMW X1
Was wondering what options are out there for aftermarket intakes and if anyone has experience with the ones listed below. It seems like the BMS one is pretty popular, but haven't seen anyone mention the AEM.
Burger Motorsports: http://www.burgertuning.com/B58_340i...ce_intake.html
AEM:
https://www.carid.com/2018-bmw-x1-ai...parentsubmodel[]=ENGINE|2.0L
Thoughts?
      03-14-2019, 11:21 AM   #2
Proper
Proper's Avatar
98
Drives: X1 M-Sport
BMS. Love mine. Great customer service also.
      03-14-2019, 11:43 AM   #3
Mushy007
56
Drives: X3 2D MH M Sport 2021
Only a panel filter from K & N for the diesels, with a kit for the petrol version https://www.knfilters.co.uk/search/a...0i&engine=2.0L
      03-16-2019, 09:32 AM   #4
mikeyb74
mikeyb74's Avatar
113
Drives: G20 330ix M Sport
Any intakes for a F series MINI Cooper S will bolt right on to the F48 or F39 with the B46 engine.
Mishimoto
https://www.mishimoto.com/mini-coope...take-2014.html
Cravenspeed
https://www.cravenspeed.com/cold-air...f55-2015-2019/
NM-ENG
http://www.nm-eng.com/371/0/0/3113/n...ntake-kit.html
AWE
https://www.awe-tuning.com/mini-cooper-f5x-sflo-intake
I have this installed on mine.
https://afepower.com/afe-power-54-12...-intake-system
      03-19-2019, 10:19 PM   #5
ventjock
65
Drives: 2020 M340i
Are the above options really worth double the cost of a BMS intake?
      03-20-2019, 02:13 PM   #6
Proper
Proper's Avatar
98
Drives: X1 M-Sport
Nope they are all essentially the same thing +/- the heat shroud. Not worth the extra price IMO.
      03-21-2019, 09:48 AM   #7
Xtiano87
Drives: BMW X1
I wouldn't rule the heat shield out entirely, I think it may be worth it. inherently in allows the engine to intake the coldest possibly air, which should increase performance a bit more than a hot air intake.
It would be nice to see side by side dyno comparisons for heat shield vs BMS intakes.
      03-21-2019, 10:25 AM   #8
Proper
Proper's Avatar
98
Drives: X1 M-Sport
The BMS retains the lower portion of the intake box, thus acting like a "heat shield". Essentially, this style intake (short ram) is a hot air intake. This mod is solely for noise. And that in itself is worth it IMO. If the heat shield justifies the almost double price tag for you than go for it!
      07-30-2019, 06:48 PM   #9
skunkd
skunkd's Avatar
18
Drives: 2004 STI 2008 BMW M5 2004 530i
How about the drop in Filters for Mini Cooper S? Will those fit too?
      07-31-2019, 06:47 PM   #10
skunkd
skunkd's Avatar
18
Well I went ahead and ordered the 2014+ Mini Cooper S AFE Dry drop in replacement filter even though it doesn’t list x1 fitment and it worked fine just Incase anyone was wondering.
aFe Power 31-10256
aFe Power 31-10256 Magnum FLOW Performance Air Filter (Dry, 3-Layer)
That stock filter is CRAZY restrictive.
808X179.50
      07-31-2019, 08:56 PM   #11
808X1
80
Drives: F48 X1 M-Sport
Originally Posted by skunkd View Post
Well I went ahead and ordered the 2014+ Mini Cooper S AFE Dry drop in replacement filter even though it doesn't list x1 fitment and it worked fine just Incase anyone was wondering.
aFe Power 31-10256
Good to know. I have the K&N version and it fits just fine as well. Agreed with how restrictive the stock filter appears to be.
      08-01-2019, 06:40 PM   #12
skunkd
skunkd's Avatar
18
I'm not a fan of oiled filters which is what led me to test if the AFE Dry filter fit
      08-02-2019, 05:09 AM   #13
billnchristy
1604
Drives: 2022 M440xi GC
Y’all are lucky to have options. The x2 m35i has a unique filter so I just sit here and wait.
How is the dry filter doing?
      10-24-2019, 07:06 PM   #14
skunkd
skunkd's Avatar
18
Funny you ask. It was doing great but when my wife brought the car in for an oil change at the dealership they fucking replaced it with an OEM filter
I just noticed a month later because a check engine light came on for evap system leak and first thing I checked was the airbox was on good and found that the dummy's at BMW through my lifetime filter away...
      10-28-2019, 02:42 AM   #15
lonegun
Drives: BMW X1 F48
I got the K&N air intake system recently and running it with the Dinan Sport set at Race Mode (+3PSI). The sound is a lot more noticeable, the engine idles better, and it runs smoother with a bit more power at higher end. But compared to the panel K&N panel filter I was running before, felt like there’s some loss of power at the lower end. (Might be because with the OEM intake box, the air is funnel through the enclosed box instead of the open air setup of the pod filter.) ECU is reset after each swap.
To be honest, I don’t really enjoy the sound of this engine and the turbo. I’d probably go for the AEM setup for a quieter, enclosed setup if I were to choose again.
      10-28-2019, 10:10 AM   #16
ventjock
65
Drives: 2020 M340i
Whats the purpose of resetting the ECU after changing intake setup?
2016 F48 X1 -> 2020 G20 M340i
      10-28-2019, 06:50 PM   #17
lonegun
Drives: BMW X1 F48
Just to make sure everything runs smoothly as it adapts to the new setup. I just use step on the gas pedal method with engine off, power on. This is just based on my experience with the chip and intake changes I had in the past. Seems like the computers learns slightly differently each time. Sometime the engine idles more roughly overtime, sometime doesn’t. Other factor like octane level seems to affect this too. I just reset it if I don’t like what the engine is doing.
      10-30-2019, 09:06 PM   #18
Pyrat 2
Pyrat 2's Avatar
1418
Drives: Rapidly from A to B
Bought a BMW Performance intake for my E90 some years back. It shipped with a K&N oiled filter. Not saying better or worse than dry. Simply saying that BMW was shipping it from the factory for their performance intake at the time. For me at least, that ended any concern about oil film mucking up sensors and the like. Just sold the car last week at 133K miles. No issues related to the intake over the 14 years I had the car. Replaced the filter a few times with another K&N (too lazy to clean so just bought a new one).
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      12-06-2019, 03:02 PM   #19
Chemacrema
Drives: 2016 bmw x1 xdrive28
I come from a wrx where every bolt on required a tune. Is that the case with this intake on our vehicles?
      12-08-2019, 12:26 AM   #20
lonegun
Drives: BMW X1 F48
AEM and K&N posted the Torque and HP graphs without a tune. But the gain you get in combination of a chip or tune is very noticeable especially with less back pressure.
      12-10-2019, 02:08 PM   #21
BFetter
Drives: BMW X1
I used a K&N intake for years in my Ford F150 with no problems. Would love to hear or find someone who has used or is using the AEM intake and how it is.
      12-13-2019, 09:11 PM   #22
Akachi
Drives: F48 X1
Anyone have dinans new intake?
