03-07-2019, 07:21 AM | #23 |
678
Rep 910
Plenty more, unfortunately these are without plastic “fitting surround” but you can modify existing ones.
https://www.ebay.com/itm/Bmw-Genuine...UAAOSwckZcTY35 Speakers part numbers which fit 65139364956, 65139210452 Last edited by MJE60; 03-07-2019 at 07:29 AM.. |
03-07-2019, 12:07 PM | #24 | |
80
Rep 241
03-08-2019, 11:16 AM | #25 |
678
Rep 910
Your penance for such poor behaviour is to go and read at least 5 of my posts and guides. Parts get lost in transit and You know what might happen to your retrofit if you don’t?
03-11-2019, 07:17 AM | #27 |
13
Rep 28
BMW factory-audio-explained
helpful link :
https://musicarnw.com/bmw-factory-audio-explained/ Last edited by kitesurferro; 03-11-2019 at 10:52 AM.. |
MJE60678.00 |
03-12-2019, 08:18 AM | #28 |
13
Rep 28
Retrofitting the Harman Kardon system into my new (X1) F48
My X1 F48 came with standard HIFI sound system and I cannot stand it especially when used or coming from a better sound sys.
My pal just upgraded his "sled' with BavSound STAGE ONE SPEAKERs kit and I am sold. I am about to do the same and will update with the outcome. https://www.bavsound.com/Product/bsd...-x1-base-audio Last edited by kitesurferro; 03-12-2019 at 09:45 AM.. |
03-12-2019, 09:07 AM | #29 | |
Rep 69
05-04-2019, 05:10 AM | #31 |
678
Rep 910
Here - 2 step process, outer and inner panels
https://www.newtis.info/tisv2/a/en/f...nit/1VnYX8ir4E https://www.newtis.info/tisv2/a/en/f...nit/1VnYWEpyPn Last edited by MJE60; 05-04-2019 at 09:00 AM.. |
05-06-2019, 07:01 AM | #33 |
678
Rep 910
Just a note, there is a coding option for HK amp to be recognised, not sure what actual additional functionality you would get (if any). If I can remember correctly it is in expert mode in HU Ecu. From memory it is in 3000, with possible ref to HIGH_END or HK
05-08-2019, 10:34 AM | #35 |
678
Rep 910
You could do worse than starting by looking at a few YouTube videos with Bimmercode in the title. There are also a number of Bimmercode threads including on this forum. Bimmercode is basically an iOS/android app which you can use to connect to your car Ecus via an obd dongle using Bluetooth or wireless.
05-08-2019, 09:58 PM | #37 |
47
Rep 231
I'm buying the Pioneer Dome Tweeters. Their range is exceptional, from mids to highs. Running the wires from the door speakers. They mount in the same spot as the HK tweeters only these are better and much less expensive. They even have their own built in cross-overs too. Install is tomorrow morning and I will report back.
05-08-2019, 10:03 PM | #38 |
47
Rep 231
I forgot to mention 2 things: You do not need to upgrade the bass speakers under the seats. The amount of bass is actually more than you need. Also changing the small door speakers front and back will not change anything either as they're too small to be of any consequence. The main difference is the dome tweeters. They will elevate the quality of the sound reproduction.
05-09-2019, 02:55 AM | #39 | |
678
Rep 910
Bimmercode is the coding app which you can use to code your BMW Ecu. Bimmertech supply retrofit parts for BMW (although they do also do some coding). Two different things but for US owners I would say Bimmertech is worth knowing. |
05-09-2019, 03:00 AM | #40 | |
678
Rep 910
05-09-2019, 12:41 PM | #41 |
47
Rep 231
Update on Pioneer tweeter install: The installation was clean and flawless. I'll post pictures soon. The small but clean and powerful dome tweeters come with a cross-over and are mounted (with small screws) to the corner of the door on the plastic and are flush. They are pointed towards the inside of the cabin. They sound absolutely fantastic. Rather than replacing the woofers located under the seats with the expensive and hefty Focals, I would recommend a 12 inch woofer from Kenwood with a sealed enclosure in the trunk (Boot) with spring loaded connectors for easy removal if you need the extra space. But this woofer lies flat and the new magnet design allows for a larger and heavier magnet as it is assembled inside the speaker. This way the speaker itself is shallow and allows for a compact enclosure. I will add to that an amp with a cross-over. That's basically all you need. This amp and bass speaker can be equalized and adjusted so that you get the maximum amount of bass and therefore use the speakers located under the seats as mid-bass speakers thus drawing less power and giving an overall better sound without overdriving the amp in the head-unit. The end result will be a better smoother more immersive sound overall. More power to the highs, mids and lows. You can google images of the Pioneer tweeters and the Kenwood bass with the enclosure and this will give you a good idea how they look. The overall cost is minimal too. The sub enclosure lies flat with all four corners raised and the speaker facing down and is held in place with velcro. In that way you can lie stuff on top of the speaker if needed. As I said if you have the upgraded stereo but not the HK system there's no need to change the mids....they're too small to be of any significance. The improvement is amazing.
MJE60678.00 |
05-13-2019, 10:18 AM | #42 |
13
Rep 28
few pics after the install
few pics after the install, pretty pleased with the sound.
05-16-2019, 12:36 AM | #43 |
47
Rep 153
[QUOTE=kitesurferro;24780012]few pics after the install, pretty pleased with the sound.
do you know what those model numbers stand for ? I've found some Bavsound Speakers on eBay for reasonable price but some say bavsound bsd.mb100.f or bavsound bsd.mb100.o? |
10-23-2019, 04:12 AM | #44 |
Rep 27
Hey, I have upgraded with the HK tweeters and HK front speakers plus the center speaker, but I have a hissing noise in the tweeters and I don't understand why. I can hear it only if I'm close enough to the tweeter.
The noise is present with the Idrive on mute and with it on volume and it is there no-matter the source of sound. I have a Hi-FI OEM system so I have the non-HK amplifier. Does any of you encountered this problem with the hissing noise? Sorry for my spelling errors, but I hope I made my self clear. Thanks in advance for your interest. |
