BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Burger Motorsports F48 B46 Intake
      08-21-2018, 03:56 PM   #23
F48_Driver
37
Drives: BMW X1
Anyone have a video of this thing in action?
      09-02-2018, 11:51 AM   #24
exwon
14
Drives: 2017 BMW X1
Now that you've had the intake for a little while, any complaints? did you have to disconnect the batter for the install? was it simple?
I installed a BMS intake on my 335 and i love the turbo sound. i never expected much if any power from it. and never liked the idea of converting my stock intake from a cold air setup to a hot air one, but sound was worth it to me.
so after opening the right exhaust valve mod, i'm looking at improving the sound up front...
then maybe a muffler exhaust... saw Supersprint one. for that money i wish bmw would offer a performance one for the x1. i wonder if a cheap magnaflow would work well on the x1...
      09-03-2018, 11:42 AM   #25
bimmerdriver2
bimmerdriver2's Avatar
180
Drives: 2020 M2C DCT
The problem with aftermarket exhaust systems on European cars is that they are usually very expensive. Maybe magnaflow will eventually come out with one, but they are pretty poor quality.
      02-12-2019, 11:15 AM   #26
ventjock
65
Drives: 2020 M340i
What tools are actually needed for this install?
      02-12-2019, 07:14 PM   #27
Proper
Proper's Avatar
98
Drives: X1 M-Sport
Basic tools, 10mm socket etc. There’s a PDF on their website in the instructions. I love the sound it makes after the intake was installed.
      02-16-2019, 03:23 PM   #28
ventjock
65
Drives: 2020 M340i
Maybe I’m missing something but I can’t seem to install the sensor into the BMS intake. I think they might’ve sent me the wrong part
      02-16-2019, 05:53 PM   #29
ventjock
65
Drives: 2020 M340i
Found out that I had the wrong housing for the MAF sensor. I'll leave the pics up as a FYI for anyone wishing to order the intake. Please make sure to select the option with "OVAL MAF hole".
      02-19-2019, 08:39 AM   #30
Proper
Proper's Avatar
98
Drives: X1 M-Sport
Ugh pain. Yea there’s a option for oval MAF sensor when ordering it. When you get it together you’ll love the sound though.
      03-12-2019, 02:26 PM   #31
ventjock
65
Drives: 2020 M340i
installed the intake and love the TUTUTUTU and the full PSHHHH (as per the OP) Can't wait for warmer weather so I can drive with the windows down.
Code:
https://youtu.be/YkbV6uKRnlI
      03-13-2019, 08:08 AM   #32
Proper
Proper's Avatar
98
Drives: X1 M-Sport
I agree, my most favorite mod so far!
      03-15-2019, 12:40 PM   #33
f1rst 1
f1rst 1's Avatar
28
Drives: '18 x1 & '09 Cayman S
all this talk of the awesome sounds and still no video/sound clip from anyone yet?
Current: 2018 MSport x1 & 2009 Cayman S
Former:
2013 BMW 335i XDrive M Sport 6spd
Cobb Tuned '09 135i
      03-15-2019, 08:36 PM   #34
ventjock
65
Drives: 2020 M340i
Look at the link on my previous post. You have to manually paste the address into your browser.
      03-15-2019, 08:39 PM   #35
f1rst 1
f1rst 1's Avatar
28
whoops, missed that! sounds pretty good
Former:
Cobb Tuned '09 135i
      08-20-2019, 10:11 PM   #36
Xorbitman
47
Drives: 2018 BMW X1
I have one of these. I know a tuner that has software and a ECU/ODBII connector on a laptop. He tuned my car's engine for less than the aftermarket ECU tuners. The BMS intake is top quality and it does everything it should. Engine, sounds, etc...I love it. Thanks!
      10-21-2019, 05:51 PM   #37
ventjock
65
Drives: 2020 M340i
Originally Posted by oreoOozZz View Post
I haven't had any problems, knock on wood. A CEL early on for a lean condition but that went away in time as I believe the DME had to adjust for more air coming in.
just to follow up on this thread, I've made several mods to my F48.
Started with the BMS intake, then added a catted DP, then the JB4, upgraded the CP, a Wagner IC, and then finally a flash tune.
I initially got CELs (P2196) after I got the DP so I fixed that with a mini cat spacer.
After the tune I was getting a P0171 (lean) CEL caused by a long term fuel trim running around 25-30%. Talked to the tuner, they never see this. So I flashed back to stock. CEL is still there. Do a smoke test, no leak (I was suspecting a vacuum leak).
So I take it to the dealer, they keep it for a week (and now I'm getting nervous b/c they can probably see that I've flashed the ECU a few times)... and they tell me that the car is running lean and at times rich b/c of the after market air intake. This made no sense to me. The intake never caused a CEL in the past. So I clean the filter and put it back on, fuel trim is still lean around 25%. So I say what the heck and put the stock intake on this morning. CEL is gone and the LTFT is down to 3% after driving it around most of the afternoon. **I use OBD AutoDoctor to read data**
Guess I'm going back to stock for now. And time to flash the tune back in.
2016 F48 X1 -> 2020 G20 M340i
      10-21-2019, 06:46 PM   #38
Proper
Proper's Avatar
98
Drives: X1 M-Sport
I initially had CEL. Cleared it and never came back.
      11-05-2019, 06:25 AM   #39
paulosportz
15
Drives: MY16 F48 BMW X1
Hello.
Just wondering if anyone above with the BMS intake experienced the Check Engine Light coming on? Fault Code P0171 - System too lean (Bank 1)
Thanks
      11-06-2019, 12:19 AM   #40
ventjock
65
Drives: 2020 M340i
Read my post on this thread from 10/21
      04-06-2021, 09:59 AM   #41
kingofqueenz
Matt
Drives: M3
Curious if you have any updates on all your mods with what is working best for you now? Getting an X1 soon and I'd like to do bolt-ons. Also, any idea what your 0-60 and 1/4 mile is?
      06-02-2021, 02:15 PM   #42
Reefy
Reefy's Avatar
38
Drives: 2012 128i BMW, 2017 X1 BMW 28i
Do aftermarket intakes typically give CELs for the F48?
For the people that have this already installed, have you experienced any?
      06-02-2021, 04:17 PM   #43
jrveron
jrveron's Avatar
Argentina
265
Drives: 2023 X3 m40i
I have a K&N model 69-2026TTK (https://www.amazon.com/gp/product/B017J19RJ2/) for the last 18 months and no CELs so far.
The sound is excellent! However, since it's an open filter (like many others, including the burger one), it's sucking hot air from the engine, and as you know, that's a bad thing. I also read here in the forums that some users get a CEL with burger intake (air too lean).
That's why I'm considering changing to aFe (https://afepower.com/afe-power-54-12...-intake-system) with the additional cover (https://afepower.com/afe-power-54-12...e-system-cover). This way, you get much more airflow than stock, and since it's completely closed (like the OEM intake), it won't suck hot air from the engine.
There's another one from Dinan (https://www.dinancars.com/products/i...arts/D760-0051), but it has an open window, so I will stick to the aFe.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD
      06-03-2021, 03:56 AM   #44
808X1
80
Drives: F48 X1 M-Sport
I have the Dinan intake for ~2 yrs now. No CEL. Nice whoosh sound off-throttle, and better partial throttle response. Mind you, I also have a Downpipe and Flash Tune.
