11-04-2012, 02:16 PM | #45 | |
72
Rep 592
Failing that our product liability insurance kicks in and before you ask I'm more than prepared to scan a copy of our policy as I have nothing to hide. what remappers telling customers that a dealer won't see a remap and that cracking open your ecu won't affect your warranty? If your that concerned about tuning your car then leave it standard. At least I'm sitting here being honest Last edited by Andrew@DTUK; 11-04-2012 at 02:21 PM.. |
11-04-2012, 02:17 PM | #46 |
3533
Rep 11,292
I bought a tuning box from Andrew, going back - 4-5 years ago when I had a Vectra 3.0 CDTi. The box didnt work too well on the Vectra and Andrew refund me no problems whatsoever, seemed a friendly chap, but this was going back a few years now.
11-04-2012, 02:23 PM | #47 |
72
Rep 592
Stuart received a refund minus a small fee, I can't remember the amount but it wasn't a lot
11-04-2012, 03:01 PM | #48 | |
3489
Rep 9,709
Extract from your own site: No wires to cut, simply plug in and drive keeping your vehicles warranty intact. Surely if 'sitting here and being honest ' you would include that your OE warranty would most likely be void on any drivetrain issues if found out to have been fitted with one of your tuning boxes.....No? |
11-05-2012, 02:48 AM | #49 |
2812
Rep 4,935
Drives: 340i MPPSK
I'm curious, I've heard suggestions in these forums that the F30 logs changes to the system such as those introduced by remaps, thus even if you remove a piggyback style remap device, the changes it made while attached will have been recorded and can be checked by the dealer and/or BMW, or that the car even proactively reports the change?
Is there any truth in this? I had a previous BMW remapped (went for a custom tuning job rather than a bolt-on box as I figured it was worth the extra expense), and was very pleased indeed with the results; better performance and slightly improved economy. The car went into the dealer for routine servicing on a couple of occasions without any problems at all, but I'm wondering if 'smarter' cars mean the end of the road for these types of mods?
Life is a state of mind |
11-05-2012, 05:46 AM | #50 | |
Live for today tomorrow never comes
1989
Rep 9,498
I do not want BMW dumping my warrantee.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
11-05-2012, 08:53 AM | #51 | |
36
Rep 221
I meant the various driver modes on the car. Eco-Pro Comfort Sport Thanks
Current: 2017 F10 530D, M Sport Plus, Graphite Grey, 19", HK, ProNav, HUD, Digital Dash
Previous: 2014 F10 525D, M Sport Plus, Carbon Black, 19's, ProNav, HK 2013 F31 320D MSport, 2013 F30 320D MSport, E91 320D MSport, 2002 E46 320i Vert, 1998 Lotus Elise 111S |
11-05-2012, 12:23 PM | #52 | |
3489
Rep 9,709
If you had your car re-mapped, even if BMW noticed this during a service, they wouldn't say a thing about it. If your engine or turbo or something that they could even remotely pin to the re-map failed, they would just inform you that your warranty was void. They would 100% know the ECU was re-flashed, even if reversed again. Many modern ECU's do have data logging facilities with history, I'd astounded if F30 didn't. These piggy back devices aren't re-maps as is common belief. All they do is intercept the signal between sensor and ECU, fooling the ECU to control certain functions differently. For example, the boost pressure sensor (MAP) might send back an anologue reading between 0-5Volts, 5Volts being maximum. Lets say your ECU is set to control the boost pressure at 1 bar, and this equates to 3 volts on your MAP sensor. Your ECU controls the wastegate/turbo vanes to achieve a 3 volt reading on the MAP input signal. All these tuning box do is read the input signal (3V in this example) and outputs a lower value (lets say 2.5 volts) to the ECU. Result is the ECU turns up the boost until it happily reads 3V, which could be 3.5Volts reduced to 3V by the tuning box. This tricks the system to giving you a corresponding increase in boost pressure. The tuning box is adjustable to what sort of gain to apply to the signal, so is a step up from just putting a resistor across the MAP signal. (Also many ECU's are self calibrating so soon learn the static resistor reading and self compensate) But not that clever as many don't even know basic info like RPM readings. The same trick is applied to the fuel rail pressure sensor in order to fool the ECU into upping the pressure, and therefore amount of fuel injected. Pretty crude. Some ECU's won't know they are being fooled, others take more readings to cross reference, and may log these anomalies, or go into LIMP. The above describes simple plug in devices (one's that just intercept the two sensors I mentioned), more elaborate tunable ones take control of the injectors and read more engine operating parameters, do a more complete job, but are much more costly. A re-map is the most complete solution provided it is mapped by a pro. |
11-06-2012, 02:28 AM | #53 |
2812
Rep 4,935
Drives: 340i MPPSK
Thanks NISFAN, all makes sense. Think if I ever do decide to tweak this car it'll be along the lines of the M Performance exhaust, brake upgrade etc. P-Torque did a fantastic job last time, but the returns on petrol engines are smaller and I think keeping on the right side of the BMW warranty will play on my mind a lot more this time round
06-16-2013, 04:54 AM | #55 |
36
Rep 398
only thing i will add is bmw have the biggest budget for development on their own engine
f31 330d mineral grey/black interior with extra stuff fitted
06-16-2013, 08:22 AM | #56 |
163
Rep 641
I would be very concerned by the insurance implications. Do people declare these modifications ? I may be wrong but I suspect not in many cases. If it is discovered after a claim (like Nisfan says for warranty these things tend to come out only if substantial claim justifies in depth enquiry) not only could the insurance be invalid but I assume the insured open to action for attempted fraud.
I had a claim for a bump in my M3 a couple of years ago and got a subsequent substantial personal injury claim, I suspect dodgy but cleverly done so difficult to disprove. I was very glad to know that it was for the insurance company to contest and not me. |
06-16-2013, 09:58 AM | #57 | |
307
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
06-16-2013, 11:43 AM | #59 | |
1989
Rep 9,498
06-16-2013, 12:57 PM | #60 |
2812
Rep 4,935
Drives: 340i MPPSK
Got to get the thing working properly first
Actually I'd be interested in the BMWP exhaust (not least cos I'd have shiny new exhaust tips) thing is I expect it'd be a lot of money for probably very little performance gain. Would probably sound nicer tho...
06-16-2013, 01:48 PM | #61 | |
2472
Rep 4,653
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
06-16-2013, 05:10 PM | #63 | |
307
Rep 2,612
I'd like a shiny new pair of exhaust tips too - the 28i just destroys them for fun doesn't it... BMW Perf exhaust would be great but not got that cash to spend on a lease car unfortunately. Especially as there's only 2 years left now! And as you say, no real performance gain.
