E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > OEM Panic alarm not working after activated through coding
Reply
      03-14-2011, 01:55 PM   #1
335TWNTURBO
54
Drives: 07 335i
What issues can I trouble shoot to rectify this issue? My coder doesn't know what to do to resolve the panic button not working.
The coding he did was:
Activate the alarm
windows up
park light delete
Digital Speedo
Power folding mirrors with remote
Any advise would be appreciated.
      03-14-2011, 01:58 PM   #2
outie
92
Drives: 2022 Porsche Taycan GTS
Activate the alarm
windows up
park light delete
Digital Speedo
Was the alarm retrofitted?
      03-14-2011, 02:12 PM   #3
335TWNTURBO
54
Drives: 07 335i
I installed the OEM alarm in 2010 and never got it activated. I had the alarm activated by a local coder 2 weeks ago and he said he doesn't know why the panic function doesn't work.
      03-14-2011, 02:22 PM   #4
onebadmofo
onebadmofo's Avatar
346
Drives: 2008 E90 M3
There's separate option for the panic button
      03-14-2011, 03:46 PM   #5
335TWNTURBO
54
Drives: 07 335i
He said that he activated it but it still isnt working. Any suggestions would be great.
      03-14-2011, 05:30 PM   #6
outie
92
I saw this in the DWA, just to confirm that he has it activated:
Code:
    PANIK_ALARM
        nicht_aktiv                 not active
*       aktiv                       active
      03-14-2011, 07:09 PM   #7
txusa03
552
Drives: TS330iPPSP6MT
Code:
    PANIK_ALARM
*       aktiv                       active
yup +1
under construction!
      03-17-2011, 02:18 PM   #8
335TWNTURBO
54
Drives: 07 335i
Does activating the alarm via coding change anything in the stalk options? Everything looks the same to me but I could be mistaken......
      03-17-2011, 03:22 PM   #9
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
When you code the alarm, you can then specify in the cluster setting, if you want to sound the alarm and flash the lights when the car is locked or just have the lights flash etc.
I wonder if you also have to FA write to the kombie module as well
      03-19-2011, 09:10 AM   #10
DESI4life10
201
The trunk button is the only button that enables the panic mode. Hold it down for 5 seconds or more
      03-24-2011, 02:09 PM   #11
335TWNTURBO
54
Drives: 07 335i
I did this and it doesn't work. Other than this, everything else seems to work properly with the alarm.
      03-24-2011, 02:51 PM   #12
Dracon
555
Drives: 2013 F10 M5
2013 BMW M5  [0.00]
How did your coder code the alarm? Did he just change the settings manually in the various modules? Did he add $302 to your VO and recode the whole car? Or did he add +K302 to your VO and recode the whole car?
Ideally, he should have added +K302 (it's the official VO code for a retrofitted alarm, $302 is if the car came with the alarm) to the VO and recode the whole car with a blank .MAN file. That will guarantee that all the settings were set to properly to the BMW defaults for the alarm in all required modules.
      03-24-2011, 03:46 PM   #13
ERIK430i
ERIK430i's Avatar
Drives: 2018 340i xDrive w/ M Sport
I recently installed the alarm retrofit kit into my 2010 E90 LCI and was having the same problem getting all parts of the alarm to work, including the panic option. I added $302 to the VO at first and it didn't work so I tried +K302 and recoded the car. Voila the alarm works. All of the other modules reflect the proper alarm options.
      03-24-2011, 07:29 PM   #14
dav_lph
Drives: BMW G30 540iX
When you say "recode the whole car with a blank .MAN file", you mean to select "PROCESS CAR" in NCSExpert, right?
      03-24-2011, 07:33 PM   #15
Dracon
555
Drives: 2013 F10 M5
2013 BMW M5  [0.00]
Correct, add +K302 to the VO, and process car with a blank man file.
      04-24-2011, 12:26 AM   #16
anthoj
Indonesia
43
Drives: 2011 E92 335i AW
I think on top of all the other DWAS modules that you have to configure, you also have to configure the SONDERTASTE_PANIKALARM in the CAS module. Change value from "nicht_aktiv" to "panikalarm". SONDERTASTE it means special key (I assume this would activate our special-hold-down-trunk-button-for-5-seconds-key).
      04-24-2011, 06:27 PM   #17
CasperSYTFU
SYTFU Crew
CasperSYTFU's Avatar
36
Drives: 2010 Toyota FJ
^just recode with blank .man file and everything will write itself
      04-24-2011, 06:30 PM   #18
anthoj
Indonesia
43
If I recode with blank .man file, will I lose other coding such as digital speedometer, corner delete etc?
      04-25-2011, 01:34 AM   #19
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
Yes, you will be restoring all BMW defaults.
That's why you always add to the V.O. BEFORE doing any seperate item coding....
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      04-25-2011, 12:23 PM   #20
CasperSYTFU
SYTFU Crew
36
exactly. sorry didnt see the question or I would have answered that earlier.
      05-12-2011, 03:56 AM   #21
anthoj
Indonesia
43
I did this already, added VO, tried to code blank MAN file and got an error on 6BMOT submodule. Can't get around it. Everything on my dash was reset although memory for radio stations, locations, and addressbook + history on idrive was not.
I still don't think my alarm is not fully activated. Alarm doesn't go off when I do the following:
1. windows rolled down, car locked (clown nose blinking), reach from outside and popped the hood.
2. car locked (clown nose blinking), windows up, rocked the rear part of the car by pulling up on the rear wheel-well area.
What am I doing wrong? Or is the alarm not supposed to go off when I did those things?
Thanks
      08-01-2011, 11:09 PM   #22
Neutrino45
Neutrino45's Avatar
62
Drives: XXX
anthoj, did you ever resolve your alarm issue?
Reply
e90post
