E92 - B14 Coilover Install Help (RWD)
04-25-2024, 04:32 PM | #1 |
Rep 7
Hey guys! Been using the forum a lot since I bought my 07 335i in November 2023. Done a lot of work since then and my last project is installing brand new Bilstein b14 coilovers. I have been searching far and wide for installation pictures to confirm I have it done correctly. Can someone who has them on their car take off a front wheel (I currently am doing the passenger front) and snap some photos? The only ones I can see is xdrive and it looks a bit different.
Specifically I am wanting to make sure how far the coilover needs to go into the spindle and if the piece on the coilovers rests on top. Thank you!! Last edited by days.e92; 04-25-2024 at 04:44 PM.. |
04-26-2024, 07:25 AM | #3 |
Rep 7
I use to use imgur but it's not working anymore like it use to so had to find another web hosting site. Let me know ! This is my first time ever installing coilovers so if it's wrong don't flame me too hard but let me know what I can do to fix ! |
04-26-2024, 11:17 AM | #4 |
317
Rep 564
looks good, center up the pins in the gap slot and till it rest/touch the bracket stop like u got. also lube up the adjust collar threads and that upper spring pad -probably would have replaced but shouldnt be an issue unless it totally fall apart
04-26-2024, 11:26 AM | #5 |
Rep 7
Thank you so much! All the upper parts are brand new OEM! I wanted to make sure I wouldn't have to take it apart again to fix any old hardware.
04-26-2024, 11:47 AM | #6 |
317
Rep 564
u meant the strut mount, rubber spring pad looks crumbly. not sure if thats a redesign but mine had a locking collar unless those dimples on the collar are allen set/lock screws?
https://www.turnermotorsport.com/p-5...90-93-4wdkb14/ |
04-26-2024, 12:34 PM | #7 | |
Rep 7
04-26-2024, 01:05 PM | #8 |
317
Rep 564
never mind, guess there are 2 versions since manual give instructions for both-lock collar and lock screw
https://www.turnermotorsport.com/p-5...ilover-system/ https://productdesk.cart.bilsteinus....-Y733A00_2.pdf Last edited by 335i54n; 04-26-2024 at 01:56 PM.. |
04-26-2024, 03:10 PM | #9 | |
Rep 7
wrevilo44.50 |
