The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Bmw f80/82 m3/4 brakes on e90 335i swap complete
      08-28-2019, 02:48 AM   #1
Turbid
89
Drives: E90 335i
Hi
My F80/82 M3/4 FULL Brake kit swap project to our E90 stock suspension is finished and passed all tests. I designed and manufactured brackets to fit Full M3 kit (calipers and M3/4 Floated brake discs 380mm front and 370mm rear) to our E90. It is not straight swap it still involves to push caliper bushes and press new ones, cut dust shields front and back and involves a drilling,taping and grinding on rear hub which won't affect OEM caliper fitment. I already sold couple brackets to car entuasist in UK and Germany, so they passed all road test.More Pictures incoming
For more information leave comment or PM.
Thank you
      08-28-2019, 05:03 PM   #2
Turbid
89
Drives: E90 335i
More picture of setup and brackets.
      02-21-2021, 08:55 AM   #3
Stefano_335i
Drives: BMW E91 335i
can you send me PM about a adaptor kit for my bmw e91 335i ?
Regards Stefan
      04-30-2021, 02:59 PM   #4
Turillo3
Drives: Bmw 428i F36
I am interested in a brake kit, can you send me a private message?
      06-17-2021, 08:34 AM   #5
breepasquotto@gmail.com
Drives: BMW 135i E82
Hi
My name is Breno from Brazil
I have a BMW E82 135i 2011
I would like tô request Rear calipers mounting brackets for use F8X Caliper (370mm rotors).
i have already the front support installed
      06-21-2021, 01:48 PM   #6
Originally Posted by Turbid View Post
Hi
Thank you
Hi
i need theses rear brackets adapter for my 135I e82 to upgrade to F80 M3 Calipers with 370mm rotors.
How can i contact yo?
      07-02-2021, 05:59 PM   #7
How can o contact y? I sent pm
      01-11-2022, 01:55 PM   #8
Edvinioks
Lithuania
Drives: Bmw e92 335d
Hi
Thank you
I have a 335d does the m4 brakes requires me to change brake lines?
      04-22-2024, 09:18 PM   #9
Pierce Jordan
Drives: 10' BMW 335i M-Sport
Hello.
I've also been looking towards doing a F8X M3/4 Bull Brake kit swap on my E90; but since it's an LCI, there's no conversion bracket made to fit the F8X M3/4 370mm Rear Rotors onto my car, if there is, please share it to me. SLG states that in their E-Series 370mm Brake Swap their bracket isn't compatible with LCI E90's. Is there any possible way to make a full brake swap possible?
(Edit)
The only thing I need to swap out to fix my problem is to swap out the stock Spindle Assemblies to the E9X M3 ones.
e9x Rear Spindle Assembly - Left - 33302283541
e9x Rear Spindle Assembly - Right - 33302283542
Note - Tie Rods do not need to be changed.
Last edited by Pierce Jordan; 04-22-2024 at 10:32 PM.. Reason: Found out the answer.
