04-19-2024, 11:27 AM | #1 |
Rep 28
Keeping stock DP but going stage 2+ (HPFP, BM3 tune)
Hi everyone.
I have the HPFP installed and BM3 (currently flashed to Stage 1), car is otherwise stock outside of xHP trans tune. I was planning on going with a catted DP but after trying a two, I just don't like the fuel smell and raspy sound. The OEM DP sounds the best for me and mitigates smell the most. Can I reliably run the BM3 Stage 2+ tune WITH the OEM DP? I understand I wouldn't maximize the power of this tune, but surely it will be miles better than Stage 1. Is there any risk of this? Alternatively, has anyone went with a catted DP then installed a downstream 200 CEL cat in the place of the resonator or something to reduce fuel smell? |
04-19-2024, 12:25 PM | #2 |
1660
Rep 4,904
No you cannot run the OEM on Stage 2 or Stage 2+. What DP's did you buy? The VRSF one sounded horrible on my 340.
I'm running the ER high flow one now. It sounds great, smell is minimal. Last edited by Wires; 04-19-2024 at 07:56 PM.. |
04-19-2024, 12:55 PM | #3 |
Rep 28
04-19-2024, 01:28 PM | #4 |
94
Rep 218
Your EGT's gotta be through the rough running Stage 2+ with oem DP. Bad idea, don't do it.
A 200/300 cel dp really shouldn't smell that much ?
M140i - MHD Stage 2+ E40 - XHP Stage 3 - Catless DP - TU HPFP - MP LSD - MP Exhaust - Endless ME20 brakepads w/ Castrol SRF fluid - Bilstein B12 - Millway solid rear subframe bushings - Goodyear Eagle F1 SuperSport
04-19-2024, 02:57 PM | #5 |
BimmerPost Supporting Vendor
24348
Rep 191,145
you should not run stage 2 on stock downpipe, i recommend you get a high flow catted downpipe instead. CTS & MAD are the top 2 options with our customers
04-19-2024, 03:17 PM | #6 |
1968
Rep 5,019
How did you try the two? What two did you test?
04-19-2024, 07:57 PM | #8 |
1660
Rep 4,904
04-20-2024, 05:20 PM | #9 |
51
Rep 392
For me the difference between stock and stage 1 on bm3 was maybe 2x the noticible difference over going from stage 1 to 2. So if no DP then i recommend staying at stage 1 and tey to convince yourself your really not missing all THAT much, and your saving the planet in the process.
I had catted high flow Cobb DP on my last n54 and hinestly can't really tell a difference sound/smell between that catted one and a vrsf catless, besides the catted costing like x3 more and me feeling like i was somehow not destroying the planet nearly as much as these catless heathens running around
04-22-2024, 10:34 AM | #10 | |
46
Rep 85
04-22-2024, 10:37 PM | #11 |
Check out my Youtube @n55david!
1297
Rep 3,536
Drives: 2017 m240i, 2015 X3 x35i
Horrible idea, it's very bad for the cat and the turbo.
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
