F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > DYNAMIC AUTOWERX 2024 Catalog Simplified
Extreme Powerhouse
      04-17-2024, 03:59 PM   #1
mike@x-ph.com
BimmerPost Supporting Vendor
mike@x-ph.com's Avatar
24348
Drives: 07-335/12-328/18-M4/21-M4CP
Talking DYNAMIC AUTOWERX 2024 Catalog Simplified
Name:  Screenshot 2024-04-17 132820.png
Name:  Screenshot 2024-04-17 132235.png
Name:  Screenshot 2024-04-17 at 13-22-12 DYNAMIC AUTOWERX BMW B58 GEN 1 (NEW GEN) ULTRA FLOW X.png
For 2024, Dynamic Autowerx has revamped its lineup of turbo kits, phasing out some previous models while introducing new ones and enhancing others. Our goal is to simplify the selection process, helping customers easily find the perfect turbo for their build.
Common Features Across All Models:
Upgraded High Flow Turbine Housing: Made from Ni-Resist D-5S with high nickel content (2150°F), featuring a stainless steel manifold with longer tubular runners for superior performance.
Forged Billet 'S' Shape High Flow Compressor Wheel: Designed for optimal airflow and efficiency.
Advanced Balancing Process: Each turbo undergoes a rigorous multi-step balancing process, including component, low-speed, and high-speed VSR balance, using the latest CIMAT balancing machine.
Large High Flow Aluminum Inlet: Enhances the turbo's ability to intake air, boosting performance.
Manufacturing Excellence: Each turbo is meticulously machined, welded, balanced, and assembled in the USA, ensuring unparalleled quality.
Warranty: Comes with a 6-month limited warranty, underscoring our commitment to quality and customer satisfaction.
Here's How They Differ:
HYPERCORE
Perfect for the people looking for an additional 12-14% more power capabilities without losing response like some of the others on the market.
B58 MAX V2.5+ GEN 1:
Performance: Capable of delivering 750+ HP.
Response and Spool: As good as, or better than, OEM turbos with a power band that holds flat to the redline.
Upgraded Thrust Assembly: Enhances durability and performance under high-load conditions.
Ultra Flow X:
Exhaust Manifold: Features a much larger design for instant spooling; test car achieved 35psi by 2900 RPMs.
Performance: Produces 730+ Whp with a vast power band ranging from mid 2000s to 7000 RPMs, ideal for road racing and providing a consistent power output across a broad range of RPMs.
6466:
Performance: Known for producing over 800whp while maintaining excellent drivability and a responsive spool across a broad Hp/Tq curve.
6769:
Performance: Capable of pushing 875+whp, it combines the drivability of a smaller turbo with relentless power delivery, continuing to pull past the redline. Ideal for achieving significant power figures on 93 octane pump gas or for comprehensive builds.
Each option in the revamped turbo lineup is designed to meet various high-performance demands, ensuring that every enthusiast can find a turbo that suits their specific needs for power and efficiency.
https://x-ph.com/sale/
Phone number 702-494-9435
      04-29-2024, 03:59 PM   #2
rodmag
rodmag's Avatar
Brazil
Drives: BMW M140i
Turbo recommendation
Hello Mike I am between the Pure Cast Pure800 and the DAW Ultra Flow X or 6466, which one do you recommend based on your experience with turbo reliability and results? Planning to get 600whp with D.I only. Looking for fast results in 60-130 mph.
Dorch 2.5
Chargepipe
Downpipe
Air Filter
Turbo (Daw or Pure?)
      04-30-2024, 10:14 AM   #3
mike@x-ph.com
24348
Dorch 2.5
Chargepipe
Downpipe
Air Filter
The Pure800 is the better option, as both can achieve 600 whp, but Pure, the smaller kit, will spool faster.
f30post
