10-02-2020, 05:38 PM | #221 | |
106
Rep 284
do it for the x2 community's sake. ps you're the one who holy shitted in the wrong thread about not going over 3Xpsi bc of course you don't want your engine to blow up.
Alpine White BMW X2 M35i
10-02-2020, 05:47 PM | #222 |
402
Rep 1,104
you obviously not understand the testing
reread the holy shit was that TDI works, that is all is it the gauge is accurate and obdii is not what really is stock boost wot 26.5 is what I read not 22.5 obdii then do the math my 30 is really equiv to obdii plus 4 |
10-02-2020, 06:19 PM | #224 |
298
Rep 1,079
25 spike but tapering to 22.5. Sorry I'm on my phone so I can't send my screen shot. It tapers quick, and the other maps hold the higher boost for longer. I'm going to log later when I get a free chance to see if there new firmware changes things.
10-02-2020, 08:07 PM | #229 |
402
Rep 1,104
Color me impressed. USA build quality, hell yeah!
Prepping for tommorow. Want to get the lay of the land. And OBDII cable is required and reads more than just RPM. Just wish the fatty cable to the box was longer so I can truly stealth it. Easy Peasy! |
10-02-2020, 10:05 PM | #230 |
1604
Rep 1,480
Drives: 2022 M440xi GC
Every one of us has seen 22.8 with obd, I’d be surprised if that’s wrong. It also makes sense with the stock b48 making around 15. If we only make 80hp more with 10psi we’re sucking.
10-02-2020, 11:08 PM | #231 | |
550
Rep 949
10-02-2020, 11:10 PM | #232 |
550
Rep 949
The 2.5bar manifold sensor caps out around 22psi, but the pre-throttle sensor is actually 4bar. Sounds to me like the OBDII PID you're all using for boost is reading the wrong sensor.
10-03-2020, 04:49 AM | #233 |
106
Rep 284
so i woke up to an email from terry to reduce the max psi on map 2 to 27 from 31.5 where it was defaulted at after i sent in my first logged run.
i did so and that's in line with 4psi over stock at max boost as is advertised. i don't quite understand why it doesn't come out of the box that way, but in either case i changed it and am awaiting a bit more clarification.
10-03-2020, 07:45 AM | #234 | |
298
Rep 1,079
As for your comment to excilr8bmw .. He's physically tapped the sensor with an aftermarket boost gauge to read raw boost in the system, which is why he wants to compare readouts from that sensor when using the tdi box, and now with the jb4. Last edited by rice_rocket88; 10-03-2020 at 08:00 AM.. |
10-03-2020, 07:52 AM | #235 |
298
Rep 1,079
Second try after work flashed fine, and a different behavior (when I flashed in the morning, the hazards would blink every few seconds and this time it did not). Terry said my boost scaling was fine and to relog map 6. My map 6 was scrambled from the failed relay so I had to get more help from Terry to set it back to default ( missing one line that wasn't listed on his forum post for default settings). I haven't had a chance to go back outside it was raining yesterday. I don't expect much to change since the beta firmware didn't list revisions that would apply, but I can always hope!
10-03-2020, 09:19 AM | #236 | |
129
Rep 421
My understanding of the 2-sensor approach is that the engine uses them because it doesn't have a bypass or blowoff valve. It uses the difference to detect overpressure situations. Right? If so, I definitely agree that we'd need to read the other PID. |
10-03-2020, 11:23 AM | #237 | |
550
Rep 949
A higher resolution sensor is used on the manifold since it spends more time in vacuum. The pre-throttle sensor provides the higher range. The problem with OBDII is it's hard-coded to the manifold sensor. The JB4 reads both sensors and outputs both sensor values in logs. |
10-03-2020, 11:36 AM | #238 |
1604
Rep 1,480
We actually do have a bov and I can hear it now with my intake
10-03-2020, 11:47 AM | #239 |
298
Rep 1,079
We do have one, but it's routed right to the intake side of the turbo so close that you don't hear much flutter or sound. The picture you have is a little misleading.. on the new tis breakdown it shows that the "nipple" in your picture is actually an electronic plug. It's probably super efficient but it's now all built in one piece of the turbo making it more expensive I would say since it's all electronic vs mechanically controlled as in the past.
https://www.newtis.info/tisv2/a/en/f...lve/1Vnc3euAo8 |
10-03-2020, 02:54 PM | #240 | |
eM Power Me
749
Rep 698
Drives: '23 AW i4 eDrive40 M Sport
Will -
'23 Alpine White G26 ///i4 eDrive40 M Sport '23 Brooklyn Grey G20 ///330e M Sport '20 Alpine White F97 ///X3MC '20 Alpine White F39 ///X2 M Sport X |
10-03-2020, 04:14 PM | #241 | ||
129
Rep 421
I guess the sensor was chosen for its sensitivity. It is certainly an interesting difference to the other one. Quote:
10-03-2020, 04:23 PM | #242 | |
129
Rep 421
But note, it's actually a "bypass valve", it sends the boost back to the turbo instead of venting to the air as a true blowoff does. This is both more efficient, and less polluting, as the air metering is always perfectly accurate. There is nothing new about turbo-integrated compressor bypass valves. They've been around for decades. What's different here is that it's electrically controlled, as is the wastegate. In earlier designs, a vacuum line is used to actuate the CBV, and a turbo control valve is pulsed to control the wastegate. Moving these functions to direct servo control really ups the game for the engine control designer, and ups the challenge for the JB4 too. Bill, what is the sound like when you hear the valve opening? In my Volvo (vacuum actuated) it makes a kind of guttural flutter/ahem sound. It's quite subtle, actually. |
