First time paint correction on Alpine White
05-02-2022, 10:21 AM | #1 |
Rep 22
Hi all, just purchased a Rupes LHR15ES and am planning to perform my first paint correction on my Alpine White e92 I just bought. The paint is overall in pretty decent condition but I’d like to get rid of all the micro scratches and swirl marks.
From what I understand, Alpine White is a very hard paint, so I think I should start with Rupes’ DA Fine with the Yellow Wool polishing pad (I guess foam will do me no good with this paint?) If there are still scratches, I should move up to their DA Course with the Blue Wool polishing pad. Afterwards, I am planning to use a white foam pad to apply the UNO Pure for the final polishing. Is it the right move for me to just use wool instead of the foam pads given my situation? I’ll have three of each: Rupes White Foam, Blue Foam, Yellow Foam, Blue Wool and Yellow Wool. Thanks in advance. |
05-02-2022, 10:40 AM | #2 |
674
Rep 740
Foam works fine - I would avoid wool unless you're paint is really hammered.
Polish is more important than the pad. I would start with a 'finishing polish' and if that doesn't achieve the desired results, then move up to a more aggressive polish. |
05-02-2022, 12:08 PM | #3 |
Rep 22
Understood, so I should start with the UNO Pure then. Thanks for the response.
05-02-2022, 01:26 PM | #4 |
3558
Rep 3,062
As mentioned, the wool pads are more aggressive than foam so start with an orange pad and test on a panel. I started to detail my own car last summer, it's a gratifying project but it can be challenging on my BSM E92.
05-02-2022, 03:15 PM | #5 |
Rep 22
Is an orange pad equivalent to a white pad for Rupes? From the pads I have it seems from least-aggressive to most-aggressive seems to be white, yellow, then blue. It’s clear to me now I’ll stay off the wool til the very end. Is yellow wool more aggressive than blue foam?
05-02-2022, 03:25 PM | #6 |
59
Rep 217
Drives: 2007 BMW 335i E90
BMW makes a paint correction kit for our color. Comes with a base coat and the top layer. I just got mine in 2 weeks ago. Will probably put it on later this summer.
05-02-2022, 05:38 PM | #7 | |
674
Rep 740
Again, unless your car is hammered, leave the wool in the box. |
05-02-2022, 05:47 PM | #8 |
2683
Rep 6,319
That's not the same thing we're talking about here though. I believe what you got would be touch up paint?
05-02-2022, 05:54 PM | #9 | |
59
Rep 217
05-03-2022, 04:20 PM | #10 |
2685
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
Is all you're using the Rupes ultra finishing polish? Depending on depth/severity of scratches you may be better served with a true 2 stage correction doing a compound stage then polish stage after. Compound on the yellow foam may be the way to go, you should rather do that than going up to a wool pad with the same polish if you're finding you want to be more aggressive
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
05-14-2022, 11:59 PM | #11 | |
Rep 22
05-15-2022, 10:57 AM | #12 |
3558
Rep 3,062
Most of my pads are from Chemical Guys, I will attach the graphic I found on their website, it doesn't include the more aggressive wool pads that I've used on my hood.
Jaronbwall284.50 |
05-16-2022, 03:08 PM | #13 |
Rep 5
My E90 Alpine white was swirled and deeply scratched, I guess from years of auto car washes.
After trying different methods, the best results were returned with: DA Polishing machine Pass=How many time I went over the area 1st step - 2 passes Blue Wool Rupes PAD Blue Rupes Coarse Compound 2nd step - 3 to 4 passes Green Rupes Foam Pad Virtus 487 UHD Extreme Polish (Apparently it cuts, and after a 2nd pass it polishes) 3rd step - 2 Passes Yellow Rupes Foam Pad Yellow Rupes Fine Compund A lot of bigger scratches are still visible only in the sun, but the only way to dig them out was to wet sand which I did not want to do due to risk(first time doing it, and time consuming). I did a test spot>Wetsand 3000>Wetsand 6000>Blue Coarse and Blue Wool>Yellow Foam Pad and Yellow Fine compund>And it turned out like glass without any scratches, but the 3 stage killed me enough to not even think of wetsanding haha. I tip my hat off to detailing guys, polishing is extremly physical. |
