BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > DIY - Register new battery
      09-18-2013, 04:38 PM   #89
derukey
Drives: 2007 BMW 335xi
I measured the voltage while the engine was running using the on-board hidden menu, it was fluctuating around 14V. I did not measure it using my multimeter yet; can't do this now as the battery is presently disconnected. I've got the oscilloscope diagnostic procedure for the alternator but I took a quick look under the hood and cannot see the voltage terminal on the alternator. (I guess I have to start taking things apart to find it).
The battery has been disconnected and on the external charger since last night and it finally registered as fully charged when I checked it a few minutes ago (according to the charger - one of those "intelligent" multi-stage ones). It never actually reached this stage when I last charged it (while fully connected to the vehicle), but it was overnight similar to this time - I just figured I didn't let it charge long enough.
Now I still don't now. Need to wait a few hours and check the voltage again (now it's at 13.12V). Battery? Alternator? Parasitic draw? I think I might have wasted a perfectly good BMW battery, even though it was over 6 years old...
Any more ideas would be appreciated, like how I can test the alternator without taking apart the engine...
      09-18-2013, 10:14 PM   #90
derukey
I reconnected the battery and came back a few hours later, the voltage was at 12.58. Seems a little low considering I haven't even started the car once after a full charge...
Now I just started it and took measurements while running: 14.4V at the jumpstart post, 14.3V at the battery. 0.1V drop, is that normal?
I also scoped the AC-coupled waveform at the jumpstart post (since I couldn't get near the BAT+ terminal of the alternator.) It looks almost textbook with about 0.4V peak-to-peak. (I'm using a x10 probe):
http://66.212.224.123/20130918_scope_at_jumpstart.jpg
I think I will need to monitor the voltage more closely over the next few days.
      09-18-2013, 11:35 PM   #91
emmm_three
Drives: 325i
how long do our batteries usually last? My 2006 just conked out on me today and had to call AAA for a jump.
      09-30-2013, 10:03 AM   #92
fishfun83
Drives: 2007 BMW 328i Sedan
Make absolutely certain you connect the vent tube to the battery!!! From experience, I know that if your alternator regulator goes bad and puts out too much voltage, not only do you get hydrogen gas in your trunk if you don't have the tube installed, but you also get battery acid in your trunk. Not a good thing.
      09-30-2013, 10:06 AM   #93
Augster
Master Gunner
77
Drives: 2008 335i Sport
I am assuming you are referring to non-AGM batteries...
      09-30-2013, 09:11 PM   #94
fishfun83
All batteries, AGM and non-AGM batteries should be vented. AGM batteries rely on a slight positive pressure to combine oxygen and hydrogen to form water so they never have to be serviced, however, in an overcharge situation, higher pressures within the battery will result and unless the battery vents, it will be damaged.
Last edited by fishfun83; 09-30-2013 at 09:22 PM.. Reason: Added additional information
      10-01-2013, 12:04 AM   #95
Augster
Master Gunner
77
There is no vent connector on my BMW AGM battery. AGM batteries, in general, are of such a construction as to prevent any acid spillage regardless of installation orientation, nor vent anywhere near what a non-AGM battery does.
The situation you are referring to of overcharging is a worst case scenario that is handled by a safety pressure relief valve. But again, my brand new BMW battery does not have any vent connection that would normally be required of a non-AGM battery than vents "normally" (frequently) as a result of its cycle of operation.
      10-01-2013, 06:28 AM   #96
fishfun83
I tend to agree with you Augster but I am really not that familiar with the "newer" BMW's. My 2007 328i has a vent tube and when I replaced my bulged battery, I did so with a non-AGM battery and reattached the tube. (I also cleaned up the battery acid that leaked out of the vent tube to the garage floor).
Battery manufacturers will tell you to not place an AGM battery in a closed container. Specifically, there are a lot of boaters that want to enclose the AGM battery(s) to prevent salt water from getting to the batteries and electronics, causing electrical corrosion etc, etc. The battery manufacturers specifically say not to put the batteries in a closed container because in an overcharge situation, the internal relief valve will open to protect the battery.
That being said, I am certain the engineers from BMW have figured out that it is OK in the newer BMW's to not require a vent tube to the AGM battery. Perhaps the trunk volume is large enough or not sealed to the point where it is considered a closed container? Maybe there are electronics that prevent the alternator from overcharging the battery?
      02-01-2014, 02:11 PM   #97
Rubiks
Rubiks's Avatar
Drives: 318d se
Originally Posted by tavher View Post
I have replaced my 90Ah AGM battery with new BOSCH S5 110Ah and tried to register it:
- in NCS Expert I changed the value KLASSE_BATTERIE in CAS module to 110Ah (if I read the module again the new value is set and correct)
- in Toolset 32 I opened MSD80 and executed jub steuern_batterietausch_registri and the status was OK (I also tried with MSV70 and MSV80)
But when I check the PM Field 2 in INPA there is still 91Ah as it was before. I also tried B TAUSCH in INPA and also repeated the process.
I dont know why it is 91Ah when it was 90Ah battery installed, but shouldnt I see 110Ah now?
I have E61 2006. Is the procedure different? Or where could be the problem?
Thank you for your suggestions!
hi. just a quick question n ncs expert, how do you get to klasse batterie as I do not have a clue how to get to it. I got a e91 lci 2009.
thank you for your help
      02-03-2014, 07:12 AM   #98
dwells
ಠ_ಠ
dwells's Avatar
74
Drives: Monaco Blue 335i coupe
Originally Posted by smooth1 View Post
It's vehicle older than 03/2007 that are denying any requests for battery registration, even from the factory tools. We're thinking these may not require the registration.
Is there any update on this/can anyone else confirm? I have an 11/06 E92 I need to do, does this mean that INPA, ISTA/D, Toolset32, and BMW Logger will all be unable to register the battery?
What's the suggestion for the vehicles then if registration is not possible? Only replace the battery with an OEM-spec replacement and don't upgrade to AGM? Or is it safe to switch to a different battery type and just code the VO/CAS but not register?
| 335i coupe | Monaco Blue | JB4 G5 ISO | Style 313M | Huper 40% tint | Aero lip | CSL trunk spoiler | M3 sideskirts
| Paint-matched grilles | Painted reflectors | GP Thunder II angel eyes | Smoked LED sidemarkers | Self-coded |
      02-04-2014, 06:10 AM   #99
Supreme214
Supreme214's Avatar
43
Drives: e90 335i
Originally Posted by Joe- View Post
Never mind figured it out, changed the VO in CAS and FRM, from there I recoded the entire car took about 1-2 mins now the AH in the status on INPA shows correctly.
Now to learn how to code other things but that's for another day.
what do you mean code entire car? I thought after changing vo just write under cas and frm??
      03-19-2014, 07:13 PM   #100
datbimmer
Wastegate Rattle
113
Drives: 335i m6t nav sport
Hi guys, when I open MSD80, I don't get any jobs in the list. Any ideas ? I have NCS Expert running and also INPA, no problems.
      03-20-2014, 10:45 AM   #101
datbimmer
Wastegate Rattle
113
Anyone ?
      03-20-2014, 11:17 AM   #102
Augster
Master Gunner
77
My replacement battery was an exact-same spec BMW battery, so I didn't have to bother with changing charging parameters (the main reason why I chose OEM); thus, I have no experience with the MSD80 job, sorry.
2008 335i Alpine White Sport Sedan AT | Avant Garde M364 Staggered 19"
      03-20-2014, 11:34 AM   #103
datbimmer
Wastegate Rattle
113
It is for an exact-same spec as the original BMW battery. It even is one from BMW. I am however not able to get the Jobs list when I open MSD80. Did you use an other way to register it ?
      03-20-2014, 11:54 AM   #104
Augster
Master Gunner
77
It's been almost eight months now and it was such a quick process, I don't even remember what I did since I've performed many other coding projects after that.
That's the problem I see with "casual" coding: you only perform certain procedures once or periodically but with years in-between, so the steps quickly fade from memory (at least in my old brain!).
      03-20-2014, 11:57 AM   #105
datbimmer
Wastegate Rattle
113
That's ok. So anyone know of an other way to register the battery ?
      03-20-2014, 02:23 PM   #106
montr
157
Drives: 2010 335d, 2018 430i G-Coupe
If you already have the cable and your new battery is same capacity and type as previous one, you can try BMWLogger
http://**************.com/battery-and-adaptations
      03-20-2014, 02:29 PM   #107
datbimmer
Wastegate Rattle
113
Your link is not working. Can you send by PM ?
      03-20-2014, 03:25 PM   #108
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
The link is not working because the forum moderators have blocked it - it won't work thru PM either - he will need to email it to you...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      03-20-2014, 03:43 PM   #109
datbimmer
Wastegate Rattle
113
I finally figured out why it wasn't working. Thanks anyway.
      03-21-2014, 07:26 AM   #110
montr
157
Right. The link is blocked. Alternate way is to Google "bmwlogger battery registration"
