Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > DIY - Register new battery
      09-20-2012, 11:16 AM   #67
JimVR4
JimVR4's Avatar
338
Drives: 21 X5 M50i M-Sport
Originally Posted by ytulip View Post
Installed the same OEM battery and trying to register it, opened up Toolset 32 fine, but when I tried to open MSD80.prg, it's taking forever and I had to kill it.
Other files MSV80.prg, MSV70.prg not working either. What's wrong with my setup? Am I missing any files? Tried two INPA RAR files that I found in this forum with the same results.
INPA seems to be working fine for me though. Appreciate any help...
Can't help with your specific question but if you already have the D+CAN cable then check this thread:
http://www.e90post.com/forums/showthread.php?t=727091
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50
      09-20-2012, 12:13 PM   #68
ytulip
Drives: 2007 e90 328i
Reading through the thread, I got an impression that some earlier e90 production have issues with registering the battery using this software and/or INPA? I believe my car was built in May 2007, not sure if that matters.
I will give this a try to find out for myself.
Thanks for the reply!
      09-22-2012, 05:13 PM   #69
ytulip
It worked for me, thanks so much!
      09-22-2012, 07:40 PM   #70
smooth1
Drives: E90
It's vehicle older than 03/2007 that are denying any requests for battery registration, even from the factory tools. We're thinking these may not require the registration.
      09-22-2012, 07:58 PM   #71
ytulip
Thanks for the clarifications! nice software you have there, keep up the good work.
      09-23-2012, 09:07 AM   #72
smooth1
Drives: E90
Thanks.
      09-27-2012, 02:08 PM   #73
makkan00
makkan00's Avatar
886
Drives: F83 and F36
Hi Guys.
My local indy told me that if you are replacing your battery with aftermarket but all the attributes of new battery (amperage) is same as OEM battery, you do not need to do anything.
Just change the battery and that is it.
Is that correct?
If yes, then why do we need to register the battery.
I guess registering the new battery is must if amperage is different.
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      09-27-2012, 04:21 PM   #74
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
Battery registration is definitely a must if you are replacing with different type of battery (AGM, etc) or different amperage.
I'm fairly certain that registration of the battery, even if replaced by same exact type & amperage, is recommended.
The BMW 'semi' intelligent battery charging system takes many variables into account when sending charging current to the battery; such as Condition of battery, Temperature, Load, etc. If your original battery was weak & on it's last legs - the charging program was/is much different than what will be needed with a new fresh/strong battery - hence your new battery will be charged under the old charging program which may lead to troubles.
Gone are the good ole days when the alternator just sent out max amperage it could output @ a given RPM and regulate it thru a Voltage Regulator - now that system is replaced with a 'smart' system that uses computer algorithms. Any time you replace a proven mechanical/electrical way of doing things with a computer controlled system - you're in to much more complication & higher costs.
Registration sort of 'resets' the charging program and introduces the new battery characteristics to the car so that it will charge correctly.
Some say they have replaced batteries & not registered and all was fine - others start having all sorts of electrical gremlins begin to happen, & end up registering the battery to fix the problems. So it's kind of a crap shoot I guess - you may get lucky, you may not...
Battery registration is not such a big deal, especially since there are at least (3) avenues to follow - either free INPA with appropriate cable, or the BavTech Tool, or using free software at this link:
Yes, you will have to lay out some $$ for any (personally I have all 3), but it's still less than what the dealer wants to register just 1X, & if you go the INPA route with coding cable, there are a ton of other little cool things you can code/program the car to do
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      11-08-2012, 09:42 AM   #75
ugknite
Drives: 2006 BMW 330xi
What is INPA? If I get the appropriate cable, can I use the software mentioned in the link?
      11-25-2012, 09:39 AM   #76
facoppo
Drives: 328 xi
E90 / E90 Battery Replacement and Procedures
Time for a Battery replacements I have an E90 07 328XI built 12/2006. I'm planning on using an Autozone 94G-DLG.. it is rated at 84AH. In reading the post, looks like the car needs to be re-coded and battery registered. A couple of questions:
1) Since battery re-coding is in increments of 10s... 70, 80 and 90... What value should I use for a 84AH battery... 80 or 90?
2) What are the exact steps required for specific the coding
3) what are the exact steps required to register the new battery
4) When coding and registering, is the car on or off?
5) I'm planning on getting the Cable & SW off Ebay. Is this what I need http://www.ebay.co.uk/itm/BMW-Diagno...:X:AAQ:GB:1123 or can you suggest something else since it doesn't have CAN support.
TKs Frank
      12-18-2012, 02:24 AM   #77
spacemonkey1112
spacemonkey1112's Avatar
64
Drives: E90 325i AW
Okay, so my battery died today and I had the car jump by AAA, unfortunately I was then introduce to this whole mindF*#(&$ experience that our car gives us when dealing with installing a new battery...
I ended up going to pepboys and picking up this battery & and them install it; I thought I'd try to register the battery myself.
http://www.pepboys.com/product/detai...ive_batteries/
however I can't seem to find out what value i'm suppose to change the KLASSE_BATTERIE in the CAS module to.... any tips?
2006 E90 325i | Sports Package | 6MT | 3IM | PE | AA |
      12-18-2012, 03:04 AM   #78
crashoverride
178
Drives: na
It's a bit odd but you divide the reserve capacity in half and then add sixteen
So a reserve capacity of 100 would be 66 (then round to closest on the battery menu)
      12-18-2012, 09:29 AM   #79
spacemonkey1112
64
Drives: E90 325i AW
Thank you! I checked my CAS and currently the battery is at 90aH... according to pepboys it should be 80aH. I'll go ahead and code that in right now. Anything else I need to keep in mind?
      03-19-2013, 02:11 PM   #80
eno
Drives: 08 328i E90
fyi,
my ebay cable/software does not include MSD80.prg, MSV70 or MSV80.prg with method 2.
so I instead used smooth1's software in this forum to register a similar speced. battery for 2008 328i.
      05-11-2013, 12:58 AM   #81
tinkerman
tinkerman's Avatar
South Korea
57
Drives: '07 320i (E90)
Originally Posted by ********* View Post
Also:
DDE6 = 318d, 320d, 325d, 330d, 335d (03/2005 - 09/2007)
DDE7 = 318d, 320d, 325d, 330d, 335d (09/2007 -)
MV946 = 316i, 318i, 320i, 320si
MSV70 = 325i, 330i
MSV80 = 328i
MSD80/MSD81 = 325i (N53), 335i
MSS60 = M3
My '07 320i (E90) has a DME model MV1746, and the associated EDIABAS\Ecu file is MEV17N46.PRG.
      08-01-2013, 06:38 PM   #82
Casca
41
Drives: E90 6MT
Originally Posted by CasperSYTFU View Post
hmm doesnt INPA not work with newer Bimmers for Battery Registration? Power Module won't exist.
In that case you open up Toolset 32 (under EDIABAS folder):
1. Open MSD80.prg
2. Look up steuern_batterietausch_registri. (near bottom of job list)
3. Go to Jobs menu
4. Select Run Job
(May alternatively be under MSV70 or MSV80.prg)
Also, and this is important:
THIS IS ONLY FOR REGISTERING AN OEM BATTERY FROM BMW! Alternate replacements will need additional coding to match voltage etc differences
Not sure if it was already pointed out, but there was a language option to change things to english. Also, just double clicking on "steuern_batterietausch_registri" seemed to cause it to run the job. I just double clicked and got the pop up that everyone seems to believe indicates the battery was reset and registered. I point this out since I didn't realize you can switch to english and I didn't really see what was "run job"
      08-01-2013, 10:29 PM   #83
nate5ks
33
1. Open MSD80.prg
3. Go to Jobs menu
4. Select Run Job
How do you change it to English? I was under the impression the .prg files needed to be individually translated and is a tedious process.
      08-02-2013, 07:34 AM   #84
cn555ic
cn555ic's Avatar
441
Drives: 335i
I think he is referring to the menus on Tool32.
      08-02-2013, 04:05 PM   #85
nate5ks
33
Oh ok I thought he was talking about the jobs. It would be great to have them in English, tool32 is fast.
      09-11-2013, 11:00 AM   #86
Augster
Master Gunner
77
Drives: 2008 335i Sport
Thanks for this thread!
Just when I got my '08 335i, I started having electrical problems and eventually replaced the battery as part of the whole resolution. Finally got my cable, found a good working source for INPA, started under Win7 but eventually switched to a dedicated laptop with WinXP and followed the outline of steps presented here to determine that my new OEM BMW battery matched the original charge rate of 90Ah so I only had to register the new battery via Tool32 (post #2).
My first "coding" experience if you will (though really I just ran a batch script).
Now to install GT1/DIS to get a diagnostic system in place...
      09-17-2013, 06:17 PM   #87
derukey
Drives: 2007 BMW 335xi
Hi,
I recently changed the battery myself on my 2007 335xi but now I have some concerns because it looks like the new battery isn't fully charging.
Basically, it's been measuring about 12.1-12.2 with my voltmeter since the last two weeks when I did the change. And I charged the battery with an external charger overnight (the day of the replacement) and I've been driving the car a lot.
My orginal battery was 90Ah and the new one is 80Ah. I'm pretty sure I did everything correctly (code new battery capacity, register new battery).
Here are some screenshots from INPA. Does anybody know what all these numbers mean and how come some of them are zero?
http://66.212.224.123/20130916_pminfo1.png
http://66.212.224.123/20130916_pminfo2.png
PM field 1
What is "chargerange hours xx - yy" ?
PM field 2
What is "% actual charge status" and "% charge status 1 day ago" and why isn't is close to 100%
What is "% actual start capacity" and "% start capacity 1/2/3/4/5 day ago"?
Although I googled SOC (State-Of-Charge), I'm not sure what "Ah Q SOC" or "SOC-fit" mean.
I also googled SOH (State-of-Health) and I would expect it to be close to 100, so I wonder why it is at 0.
      09-18-2013, 03:51 PM   #88
nate5ks
33
What is your voltage at the jump terminals and the battery terminals with the car running?
