Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > DIY - Register new battery
      10-23-2011, 03:09 AM   #23
tibra1
No_Country
127
Drives: 2011 ZCP M3 - 2007 335i crashd
Get a BT tool..
Engine Module, Commands, Battery Replacement Adaption, Click Send Button..DONE
      10-23-2011, 01:33 PM   #24
tavher
Drives: 530D
Will it work with my INPA cable?
      11-04-2011, 07:51 AM   #25
Steveo
Steveo's Avatar
152
Drives: M4
Did you solve this, have same battery in my M5 and now get high battery discharge rate warning, I need to code and register it me thinks
How do I do it?
Originally Posted by tavher View Post
I have replaced my 90Ah AGM battery with new BOSCH S5 110Ah and tried to register it:
- in NCS Expert I changed the value KLASSE_BATTERIE in CAS module to 110Ah (if I read the module again the new value is set and correct)
- in Toolset 32 I opened MSD80 and executed jub steuern_batterietausch_registri and the status was OK (I also tried with MSV70 and MSV80)
But when I check the PM Field 2 in INPA there is still 91Ah as it was before. I also tried B TAUSCH in INPA and also repeated the process.
I dont know why it is 91Ah when it was 90Ah battery installed, but shouldnt I see 110Ah now?
I have E61 2006. Is the procedure different? Or where could be the problem?
Thank you for your suggestions!
      11-12-2011, 06:34 PM   #26
silvermist99
Drives: 335i 6MT & X5D 6AT
2007 BMW 323I  [0.00]
2007 BMW 335I  [0.00]
Originally Posted by CasperSYTFU View Post
hmm doesnt INPA not work with newer Bimmers for Battery Registration? Power Module won't exist.
In that case you open up Toolset 32 (under EDIABAS folder):
1. Open MSD80.prg
2. Look up steuern_batterietausch_registri. (near bottom of job list)
3. Go to Jobs menu
4. Select Run Job
(May alternatively be under MSV70 or MSV80.prg)
Also, and this is important:
THIS IS ONLY FOR REGISTERING AN OEM BATTERY FROM BMW! Alternate replacements will need additional coding to match voltage etc differences
I found the job, then selected job-select job once only then it gave me a bunch of lines. Is that it?? I installed a new oem battery
this is what i got
apiJob("MSD80","steuern_batterietausch_registriere n","","")
Satz : 0
OBJECT = msd80
SAETZE = 1
JOBNAME = steuern_batterietausch_registrieren
VARIANTE = MSD80
JOBSTATUS =
UBATTCURRENT = 1
UBATTHISTORY = 1
IGNITIONCURRENT = 1
IGNITIONHISTORY = 1
Satz : 1
JOB_STATUS = OKAY
_TEL_AUFTRAG = 8 Bytes
000 : 85 12 F1 31 30 00 10 00 ….ñ10...
_TEL_ANTWORT = 5 Bytes
000 : 71 30 00 10 00 q0...
      11-12-2011, 09:36 PM   #27
fdriller9
253
Drives: '06 AW 330xi
2006 330xi  [6.44]
There is no profile for a 110Ah battery. Largest is 90Ah.
      11-12-2011, 10:24 PM   #28
rambalu80
rambalu80's Avatar
78
Drives: 2016 BMW 340i
2016 BMW 340i  [0.00]
Am I all set now?
Yesterday morning with the temperature at 37 degrees, my car took a few extra seconds to start. Went to work and got back home without a hitch yesterday. After letting the car sit overnight, I checked the battery voltage and it read 11.8x volts but car started up just fine (and quicker than yesterday). Anyway, I replaced the battery with an in-kind OEM replacement and registered it using Tool 32. I got errors a couple of times trying to run MSV80 but realized I hadn't turned the ignition on. Final attempt with ignition on showed "JOB_STATUS = OKAY". Below is a screen shot. Am I all set now?
2016 BMW 340i
688 | LCL5 | 4FT | ZMT | ZTP | ZDA | ZLP | 494
Formula One Pinnacle 30 Tint | Brushed Aluminum Pedals
      11-16-2011, 05:01 PM   #29
silvermist99
we got the same results. reading post #2, i think thats it? I notice no difference to the car after running the job
      11-19-2011, 11:38 PM   #30
ZZZZ
50
Drives: Z4 3.0i winterbeater
Hi everyone. I picked up my 06 325i on Wednesday and noticed it cranked over slowly, especially when cold. I just swapped out the battery for an aftermarket one I had in my e46 for a month. (Newly purchased a month ago). Group 48, 850CCA, 690CA, Reserve Min 110. Google tells me that I should multiply the Reserve Min by 0.6 to get the AH. (battery capacity). 110 x 0.6 = 66. So that puts me on the 70ah profile. (Stock?)
I have EDIABAS and INPA working on my car already. Just want to make sure I can follow the directions in post #2 (Except using the MSV70 profile since it's a 325i), and I should be good?
side note: still notice the car cranking over slowly when cold. wonder if my starter is dying.
      11-24-2011, 09:11 AM   #31
Goathog02
Goathog02's Avatar
Drives: 06 330i E90 /Premium/Sport
this is what i got
Satz : 0
OBJECT = msd80
SAETZE = 1
VARIANTE = MSD80
JOBSTATUS =
UBATTCURRENT = 1
UBATTHISTORY = 1
IGNITIONCURRENT = 1
IGNITIONHISTORY = 1
Satz : 1
JOB_STATUS = OKAY
Can anyone confirm this?
      11-24-2011, 09:53 AM   #32
rambalu80
rambalu80's Avatar
78
I can. See post #28.
2016 BMW 340i
      11-24-2011, 10:17 AM   #33
ZZZZ
50
can anyone give me some insight on this? would really like to register my battery without messing anything up..
      11-25-2011, 12:33 AM   #34
Goathog02
Goathog02's Avatar
Thx.
Since it ended w/a question, I thought you were unsure.
      11-28-2011, 02:23 PM   #35
Advance501
Drives: 2007 e90 335i
I am having a bit of a problem registering a new 80ah AGM battery to my E90 (02/2007 manufactured date). I read this thread and others regarding battery coding and registration many times, and it appears that changing the VO is the proper method to use when replacing the stock battery (90ah wet cell in my case) with a different type or rating. The problem I am having is after changing the VO for the new AGM battery and registering the battery with tool32, INPA is still telling me that I have a 90ah battery installed (Sparky66 procedure in post #17 of this thread). When I read the KLASSE_BATTERIE line in my CAS it still reads 90ah. Is there a step that I am missing between writing the new –A080 code to VO and registering the battery with tool32? Below is the exact step by step procedure I used:
Changing VO:
1. Open NCSEXPERT
2. File > Load profile > Select Expertmode > Click OK
3. Press F1 (VIN/ZCS/FA)
4. Press F3 (CS/FA f. EC) > Select E89 > Click OK > Select CAS > Click OK
5. Press F6 (Back)
6. Press F1 (VIN/ZCS/FA)
7. Press F2 (Enter FA) > Select E89 > Click OK
8. A window labeled “Eneter VIN” appears with your vehicles VIN number filled in > Click OK
9. A window labeled Enter FA appears > scroll to find VO for old battery (-B090) > highlight –B090 and press delete on keyboard
10. Enter –A080 is “Attribute” box > Click Add > Click OK
11. Press F6 (Back)
12. Press F4 (Process ECU) > Select CAS > Click OK
13. Press F2 (Change Job) > Select FA_Write > Click OK
14. Press F3 (Execute Job)
15. Verify that the write is complete “Job Ended”
16. Press F1 (Change ECU) > Select FRM > Click OK
17. Verify lines : get coded, FRM, JOBNAME = FA_Write
18. Press F3 (Execute Job)
19. Verify that the write is complete “Job Ended”
20. Press F6 (Back) > Exit NCSEXPERT
Register Battery:
1. Open Tool32
2. Datei > SGBD, Gruppendatei Laded > Select MSD80.PRG > Click Open
3. Highlight steuern_batterietausch_registri
4. Job > Job Einmal Ausfuhren (run job once)
5. The job runs pretty quickly and the results say Job_status = okay. The results are exactly like that of post #26 in this thread.
I have gone back and looked at the VO codes in both CAS and FRM modules using steps 1 – 8 in my above procedure. I have confirmed that the original VO “-B090” is not in the list anymore and “-A080” has been added to the list.
Any help would be greatly appreciated!
      11-28-2011, 04:48 PM   #36
Elliott@DetailAddict
300
Drives: E90
Changing VO:
1. Open NCSEXPERT
5. Press F6 (Back)
11. Press F6 (Back)
Register Battery:
1. Open Tool32
Yes, all you did was modify your vehicle order. Now you need to code the whole car in expert mode for changes to take place.
      11-28-2011, 05:38 PM   #37
ctuna
1911
Drives: 325xi 06 wagon MT
Stock battery 90ah
The closest Interstate is 84 ah .
Do you register or recode?
Also isn't processing the car a not recommended here.
      11-28-2011, 05:43 PM   #38
300
Drives: E90
If it isnt a match to your original, you recode.
Processing the car is fine as long as you do it the right way... expert mode, not a blank man. Don't know where you've heard that.
      11-28-2011, 07:03 PM   #39
ctuna
1911
Maybe I'm confusing it with reprogramming?
Maybe I'm confusing processing with reprogramming or updating?
I thought it was mentioned that only modules should be coded.
But it you are say adding the Alarm the VO had to be updated in the two
modules that the VO list is in then the car had to be processed .
Isn't processing the car same as reprogramming all modules?
The trouble with battery is the coding value for the battery profiles are in increments of 10 the list says 70 ,80 , 90ah etc
does 80 make more sense for in between or does 90 if the value for the battery
is 84ah.
      11-28-2011, 07:07 PM   #40
Advance501
Ok I got an error while coding the car. First of all the method I used to code the car was:
1. Open NCSEXPERT
5. Press F6 (Back)
6. Press F3 (Process Car)
7. Press F1 (Code Car)
The Error messeage I got while coding is:
Error CABD! Look at CABI.ERR and ERROR.LOG
COAPI-2000: EDIABAS or SGBD error
SYS-0008: JOB NOT FOUND
Any clues? I am using version 3.1.0 of NCSEXPERT and whatever Daten files that come with it in the .zip file located in the BMW Coding Sucess thread.
Should I try the so called empty .MAN file vehicle coding method?
Thanks
      11-28-2011, 07:17 PM   #41
300
Drives: E90
That error wont tell you anything. When it pops up close it the under View go to Error Log.
You may just need to code each module one by one in expert mode. That's the equivalent.
NO the empty MAN file is the worst way. Do it the right way.
      11-28-2011, 09:16 PM   #42
Advance501
Ok I left my car on a trickle charger since my last coding session had it down to 12.3V. I tried to process the car again, just to see the error log and which module it got hung up on. The message from the error log is as follows:
ERROR! Modul: LFCDHDIA.CPP (A_CASK.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000
>>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNR: 06, ErrorNR: 2000
SG_CODIEREN
The module NCS was coding when I recieved the error was CTUNE.
I havent tried coding each module one by one yet, I am waiting for a near full battery. I have a feeling it will more than likely just get hung up again on the CTUNE module.
Any Ideas?
      11-29-2011, 01:00 PM   #43
Advance501
Ok, I processed the modules one by one is expertmode and two modules gave me errors. Below are the modules and their respective error logs:
Module: CGATE
Error:
SG_CODIEREN
Module: CAUDI
Error:
ERROR! Modul: LFCDHDIA.CPP (A_CGW.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000
SG_CODIEREN
I have checked the CAS module and it is now reporting the proper battery (80ah_agm). Inpa is also showing a 81ah battery is installed
Any ideas into how to resolve these errors? Do I even need to have the CGATE and CAUDI modules reset for my new battery VO (-A080)?
BTW, I am running version 6.4.7 of EDIABAS
      11-30-2011, 10:10 AM   #44
rambalu80
rambalu80's Avatar
78
Thx.
Yes, I was unsure until silvermist99 confirmed that he got the same results.
2016 BMW 340i
