02-04-2017, 02:10 PM | #265 | |
163
Rep 334
Just one to be aware of... |
jpwakan3.00 |
02-04-2017, 02:12 PM | #266 | |
119
Rep 512
Drives: 2020 Z4 M4Misano Blue
I can envision such tight squeezes that one might want to keep the mirrors folded while driving (very narrow street) or not unfold them before leaving a parking space (like that time I crawled in through the tailgate because jerks had parked too close even to open a door).
2004 E85 Z4 3.0 Sport - Sold to brother | 2004 E83 X3 xDrive3.0i - Gone | 2011 E89 Z4 35is - Gone | 2011 F25 X3 xDrive35i - Gone | 2014 E89 Z4 E89 35is - Gone | 2014 F25 X3 xDrive 30i X3 - Gone | 2017 F83 M4 Cabriolet - Gone | 2017 F25 X3 xDrive30i - Gone
2020 G29 Z4 M40i Misanoblau | 2020 G01 M40i Phytonicblau Casa Suzana, vacation rental villa in Cozumel, Mexico |
02-04-2017, 02:17 PM | #267 | |
1312
Rep 10,185
Not everyone wants them unfolding immediately. I for example often I have to move cars between tight spaces, so I need them folded all the time in the space and really dont want them unfolding when driving say 8mph between spaces as I would immediately have to have them fold again to get in the next space. I do want them unfolding when I start driving down the road.
BMW if you are reading, I need a job, Please. |
02-04-2017, 03:17 PM | #268 | |
Rep 6
02-04-2017, 04:28 PM | #269 | |
163
Rep 334
If you fold the mirrors in using the button on the door, they will not unfold as soon as you unlock the car. They will unfold when the speed threshold, adjustable through coding, is reached, or of course if you press the button on the door again. HTH |
02-05-2017, 09:18 AM | #270 | |
126
Rep 243
02-05-2017, 12:42 PM | #271 |
Rep 39
Drives: X1 F48 25i
Any chance to have the value for "sport mode" last setting memory 😀
Thanks
02-06-2017, 03:00 AM | #273 |
Rep 39
Drives: X1 F48 25i
02-06-2017, 03:24 AM | #275 | |
Rep 39
Drives: X1 F48 25i
02-06-2017, 11:21 PM | #277 |
Rep 9
Dear all
Do anyone know the default value of HU_ENTRYNAV 3001 EXBOX RDC_SAFETY? RDC? RPA? I coded but I forgot to write down and I want to code them back to default. Thank you. |
02-07-2017, 07:39 AM | #278 | |
17
Rep 45
RDC >>> aktiv RDC_SAFETY >>> aktiv RPA >>> aktiv RDC_FORTSCHRITTSANZEIGE >>> aktiv REIFENUEBERWACHUNG_RDC_RPA >>> rdc RDC_DRUCK_TEMP >>> druck_und_temperature But finally there have no any change on iDrive. I also try to code one by one, but same as result (no change). So that I want to change back RDC, RDC_safety and RPA to default. Need help please. |
02-07-2017, 01:27 PM | #279 | |
2374
Rep 8,364
02-07-2017, 09:25 PM | #280 | |
2374
Rep 8,364
Does your vehicle have option 2VB? If yes, all that is needed is RDC_SAFETY > aktiv. |
02-08-2017, 05:11 AM | #281 |
17
Rep 45
Almaretto, thank you for your information. After searching the 2VB, finally I understand what is the meaning for Run-flat indicator (my car) and the TPM (option). I don't have 2VB, so that's why I cannot show up the information. I will code back the default value to those ECUs. Need more study for my car. Thank you again.
02-08-2017, 01:58 PM | #282 | |
2374
Rep 8,364
02-23-2017, 11:16 PM | #284 |
21
Rep 50
Hi All,, need help... 2017 F48 with HUD....etc. I just try to code the Fog light to support LED.
After installed the Esys... and I success connect to the X1 with Ethernet... But am getting the following message when try to use SVT Actual - Read SVT... PSdZ Error Generate SVT_Ist failed. (C105) job failed with negative response error: Any idea what went wrong ??? appreciate all your support. |
02-24-2017, 01:55 AM | #285 | |
163
Rep 334
02-24-2017, 02:28 AM | #286 | |
2374
Rep 8,364
You would normally get the same information. The only difference is SVT pulls information from central Vehicle Configuration Management (VCM) and ECU individually pulls from each module. |
