10-21-2016, 08:30 PM | #155 |
1425
Rep 3,395
A gun doesnt have to be cleaned every single time you use it....particulary....ESPECIALLY if you regularly use the gun.
A handgun you use regularly or carry (ie depend on) DOES however require proper lubrication ESPECIALLY in the winter If however you're shooting corrosive ammo then you need to clean that gun more or less immediately after shooting.....I recommend windex down the barrel/in chamber to neutralize the primer salts.....if its not a bolt action gun you'll need to pull apart the entire gas system and clean it too......unless you like rust/useless guns People do more damage to guns while cleaning than doing anything else with them |
10-21-2016, 08:48 PM | #156 |
is probably out riding.
6058
Rep 2,292
I stopped cleaning every time i shoot a wile ago. Especially with blue collar guns. If i only shoot a gun every now and then, i'll full clean and putt a storage amount of lube on it. Too many gunsmiths told me that full solvent cleaning after every shoot is bad.
That said, take care of your tools and your tools will take care of you. My post shooting ritual, during a movie or football game, is jamming the mags. I keep most mags loaded so i can just grab and go to the range/farm.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
MKSixer34188.50 |
10-21-2016, 09:04 PM | #157 | |
The Cool Guy/ You're drinking' Buddy
175
Rep 107
I keep my magazines filled all the time...thank the lord for speed loaders. I enjoy doing it and am sure i will enjoy cleaning them. Similar to wrenching on the car. |
10-21-2016, 09:05 PM | #158 |
11818
Rep 23,187
I usually have some loaded and rest in boxes for down the road. This doesn't work very well with a beard.
10-21-2016, 09:42 PM | #159 |
1412
Rep 3,211
Firearms and bimmers
If you love the gun break it down and clean after each session Gotta admit gettin a bit lazy too so been seeing just the bore brush recently after each |
10-21-2016, 09:50 PM | #160 |
11818
Rep 23,187
See I don't see it as lazy, I too don't think it's a good idea to overclean a gun that's routinely used. Keep it lubed up and do it once in a while
10-21-2016, 10:16 PM | #161 |
1412
Rep 3,211
Can see yer POV but not chancing any residue corroding any part of my guns but will do breakdown cleaning and oil whenever time allows.. esp in the more humid months
10-21-2016, 10:38 PM | #162 | |
1425
Rep 3,395
Accuracy is actually BETTER on firearms with SOME fouling.....HUNDREDS of rounds of fouling will have a negative effect |
Mr Tonka6058.00 |
10-21-2016, 10:50 PM | #163 | |
1412
Rep 3,211
10-21-2016, 10:52 PM | #164 |
53
Rep 93
just my .02cents, clean it and maintain it like your life depends on it..just like pre flight checks...
"If you see the muzzle flash, your still alive....react" Me.. |
10-21-2016, 10:54 PM | #166 | |
1425
Rep 3,395
Anything comm block surplus is definately corrosive ie anything 7.62x54r, most of the Yugo 7.62x39, most of the 8mm |
10-21-2016, 11:13 PM | #170 |
6058
Rep 2,292
I doubt there is a wrong answer here. Most of us don't shoot enough where solvent cleaning after each shoot would be detrimental. And a simple bore snake and shot of lube after each shoot is generally more than enough to keep everything in good working order. You know your gear, take care of it as needed.
As Fundguy pointed out, different weapons like different treatment. You can run a glock dry as a bone for weeks. Do that with most 1911s and you're toast after a few mags.
10-21-2016, 11:19 PM | #172 |
1425
Rep 3,395
10-21-2016, 11:23 PM | #173 |
11818
Rep 23,187
Yeah I shoot steel at my outdoor range brass at indoor but only polymer coated not laquer. Seems this part of forum generates a decent amount of interest go figure we got some shooters here.
10-22-2016, 05:38 AM | #175 | |
6058
Rep 2,292
Viva la revolution! :
PeakUnicorn80.50 KE///BI7.00 |
10-22-2016, 09:11 AM | #176 |
175
Rep 107
From what I have been told and read, a lot of guns like the ones I am using (Glock, Sig, etc) can take such a fkn beating and still be ready and operate like a charm. My plan is to clean after every other range session...should be good.
Thanks for all of the info., guys. |
