BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Vibration rough acceleration
      04-27-2020, 07:17 AM   #1
NM7
NM7
NM7's Avatar
Drives: 535d F10, x1 2.5d F48, x3 3.0d
Hi all,
I got 2016 x1 2.5d when accelerating especially in 1st gear i get this vibration around 1500rpm not sure what this is. I feel like its gear box related but not sure..
Car still under warranty but wanted to see if anyone has experience this issue. Also this engine seem very loud compared to the old 2.5d sound like a tractor
Any help be much appreciated
Thanks
Neetin
      04-27-2020, 05:57 PM   #2
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
Check engine/gearbox mounts. These have been an issue on the X1
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
      05-01-2020, 05:09 AM   #3
NM7
NM7
NM7's Avatar
Thanks ttimbo the car has been in once to the dealers about this issue they keep saying they cant find anything. i go again
      05-01-2020, 06:32 AM   #4
Toddy2018
Drives: X1 f48 25d msport
I have same model and year, totally agree that the engine is so noisy, I had a problem that felt like something was grinding as I pulled away particularly worse when turning, dealers initially said there was nothing wrong, I insisted a technician came out with me, as soon as I pulled away he felt it, I thought the grinding was coming from the front but he thought it was at the rear, they replaced a rear drive shaft but this made no difference, they then replaced a hydraulic pump and ECU on the rear diff, this cured it
This would have cost a couple of grand if it wasnt under warranty, I have just done a service myself whilst I e got nothing better to do during lockdown and had a good look at the lower engine mount and there is clearly play in the Bush,
      05-01-2020, 07:16 AM   #5
NM7
NM7
NM7's Avatar
Toddy2018 thank for the update its sounds like the same issue. I have to take your notes and make sure they check all this before warranty runs out
thanks
Neetin
      05-01-2020, 08:29 AM   #6
Toddy2018
Are you in the uk
      05-01-2020, 09:51 AM   #7
NM7
NM7
NM7's Avatar
Hi Toddy2018 i am in the uk
      05-01-2020, 01:28 PM   #8
Toddy2018
If you take it to a bmw main dealer you could give my reg in and they can see what was replaced on mine
My reg is OW16 EXU
      05-01-2020, 01:45 PM   #9
NM7
NM7
NM7's Avatar
Toddy2018 thanks Mate much appreciated
      05-01-2020, 01:49 PM   #10
Toddy2018
No worries,
      05-02-2020, 07:03 PM   #11
ttimbo
ttimbo's Avatar
282
In a couple of cases, the engine mounts on early X1s have broken and required welding, so I suggest you have this inspected, too
      05-06-2020, 08:53 AM   #12
NM7
NM7
NM7's Avatar
guys thanks got tech coming today im sure they take the car in. hopefully this can be resolved
      05-07-2020, 05:20 AM   #13
NM7
NM7
NM7's Avatar
Just update from BMW they saying they cant find anything having had the car since yesterday.. I had to explain the issue to them again but due to the lockdown cannot show them as i need a technician to come out for a drive with myself with all the social distancing and everything. I am hoping they keep the car for a few more day so that they can diagnose the issue better..
      05-08-2020, 12:18 PM   #14
Toddy2018
Sounds familiar
I bet if it was out of warranty they'd be able to find the fault , i don't think they know what they're looking for unless it's got a fault.
      05-08-2020, 03:19 PM   #15
NM7
NM7
NM7's Avatar
Toddy2018 Thats it.. they said they done various test drive etc they cant find anything and in order to change or put a claim in to BMW uk for the warranty they need to find something bloody annoying i can't go for test drive with them show them exactly whats causing issue
      05-15-2020, 01:38 PM   #16
NM7
NM7
NM7's Avatar
guys got the car back they cant find anything... Shame cause i can still feel the vibration slightly when i accelerate soo frustrating
      05-16-2020, 03:23 AM   #17
ttimbo
ttimbo's Avatar
282
Perhaps try an independent specialist, if there's one close by. Pay for an inspection/test drive report
      06-10-2020, 10:28 AM   #18
NM7
NM7
NM7's Avatar
going to take car to BMW specialist they going to take a look at the issue. hopefully i get some better news and maybe get this looked into properly
      06-11-2020, 06:23 PM   #19
lonegun
Drives: BMW X1 F48
Originally Posted by hqdevelopers View Post
Hi everyone,
I am also owning a BMW X1 F48 (2017), and I have noticed during the last winter when engine was cold, that the car vibrating a lot (while standing still).
Last weekend, I have been for a drive with the car, and while going up a relatively easy hill I have noticed a very loud vibration.
What can it be?
Always use the highest grade of fuel, any grade lower than the suggested grade can cause vibration. Check to see if you need to replace air filter. Also you can try to reset the engine's ECU by pressing on the gas pedal for 10 second with the power ON engine OFF, then leave the car off for 15 mins.
      06-12-2020, 02:38 AM   #20
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Not relevant in the UK for the Original Poster's problem because we only have one grade of diesel coming out of the refineries. It is to BS EN 590:2009 standard.
I am sorry to say this is one of those "old wives tails" that has been going around forums since Pontias was a pilot. It is simply not true. Anyone saying they have noticed a difference is kidding themselves. Perhaps described as the "Placebo effect".
The correct course of action is:
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      06-12-2020, 04:32 AM   #21
lonegun
Drives: BMW X1 F48
Oh I thought he was running petrol. My bad.
As for the reset, I wouldn’t have believed it too if that had not worked for me. But that actually fixed my rough idling engine when I changed over to a higher grade fuel 2 years ago. The rough idling sound disappeared immediately.
I have to reset it once in a while now as well as my boost controller messes with the mapping of the timing and fuel injection, especially when it start throwing codes.
In my experiences, it absolutely work, and your engine will end up running slightly different every time as the ecu settle down.
But of course the best course of action is taking it to a specialist. But there’s not really a need to be on this forum anymore is there?
      06-12-2020, 06:30 AM   #22
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
You are suffering from the "Placebo effect" and with the greatest respect, you do not understand "Engine Control Units". If you are happy to believe it, then all well and good. Enjoy your fantasy!
The procedure you are countenancing was banded around recently to cure sluggish automatic gearbox issues.
As stated previously it IS an old wives tale and also recently appeared on some other manufacturers forums as a cure for turbo lag.
With regards to the fuel issue, as stated all UK diesel fuel HAS to conform to the standard I posted in my previous thread. Some fuel suppliers put in additives, but that is another topic for discussion.
