05-30-2020, 11:34 AM | #1 |
Rep 16
Low Lighthouse and Angel Eye in 100% brightness
Hello, does anyone know how to make the bimmercode with the angel eye stay with the maximum power when turning on the beacon? When I turn on the angel eye it gets weaker, I would like to keep it at 100% brightness. Thank you
05-30-2020, 03:19 PM | #3 | |
Rep 16
Hello ejw2011, I think it must be somewhere in the expert mode to keep the angel eyes at 100% with the low beam, because in the nomal mode in the program this Angel eyes brightness low beam is 100%, but when I turn on the low beam the angel eyes reduces the brightness to about 50%. |
05-30-2020, 05:39 PM | #5 |
94
Rep 287
There are two code settings for angel eyes I used and have no problems. But then again I have angel eyes to dim 80% when turn signals invoked. There is also daytime light intensity setting. Try but I don't remember I needed to set.
05-31-2020, 11:46 AM | #6 | |
Rep 16
I've tried everything, but even so when I put the low beam on, the angel eyes reduces the light even though everything is 100%. Another thing that I was unable to do at all and wanted very much, is to make the fog light turn on with the headlight control being at 0, in the position where the red arrow is. My BMW is the X1 F48 25i 2019. |
05-31-2020, 06:41 PM | #7 |
94
Rep 287
Did you try coding the daytime running lights to 100%?
As far as the front fog lights to be on at position 0, you can't code afaik. You probably need to rewire. |
05-31-2020, 08:06 PM | #8 | |
Rep 16
It is a pity that there is no way to turn on the fog light in position 0. Yes, I put everything at 100%, but when I put it in the low light position that is shown in the image, the angel eyes halves the luminosity. Something is crashing and not letting it stay at 100% even though the Bimmercode informs that they are 100%. |
