03-30-2020, 11:33 AM | #23 | |
Rep 16
Drives: 320d '09, X1 18d '20, 318is'95
1) open the bonnet and remove the gasket (is it correct gasket?) marked with number 2 by just pulling it away https://www.realoem.com/bmw/enUS/sho...diagId=41_2579 2)Now you have to lift up a little bit the piece number 2 in this draw, as much as you can see the battery tag. If you see the pic of my battery, you understand what i mean https://www.realoem.com/bmw/enUS/sho...diagId=51_A664 Is not necessary to remove completely the pladtic, you just lift it up. You will see that you have to remove the plastic rivets number 6 in order to lift that plastic up. In order to do that, you just take a couple of flathead screwdriver and gently lift the head of the rivet. When you will able to pull it with your hands, pull it with your hands No worries about breaking the rivets, they are soft and come off preatty easily if you use 2 screwdriver to start lifting them up. 3)go backwards and close the bonnet If you have to remove the battery instead, that could be a pain in the ass |
03-30-2020, 11:43 AM | #24 | |
75
Rep 383
03-30-2020, 02:04 PM | #26 |
37
Rep 153
Not sure I understand all this tek talk. However I can confirm the battery is charged to capacity. Car now locked safely in my garage. Next to it is a relatively low tek 1955 Alvis TC21/100. It has points, and condensers and the fuel pump is glass. Simple!
03-31-2020, 06:55 AM | #27 |
75
Rep 383
Got this from Dealer.
Good morning Graham, I hope this email finds you well. Looking at your vehicle information I can confirm that the vehicle is fitted with a AGM battery. Kind regards Stewart This site gives some info https://www.racshop.co.uk/car-batter...tomatic/169666
03-31-2020, 09:36 AM | #28 | |
159
Rep 458
Giuseppean4.00 |
03-31-2020, 11:24 AM | #29 |
Rep 16
Very nice, thanks for the info. So 70ah, but agm. I don't know what's their criteria for mounting different technology, at this point.
03-31-2020, 11:37 AM | #30 |
75
Rep 383
Maybe its because,
AGM batteries are better suited to meeting the demands of higher specification vehicles that include one or more of the following technologies: Start Stop, Regenerative Braking and Passive Boost. ..... which mine has.
03-31-2020, 12:00 PM | #31 | |
159
Rep 458
Anyway, I think I've said enough on this topic! |
03-31-2020, 02:34 PM | #32 |
117
Rep 212
https://bimmercat.com/bmw/en/search/...8C/ECE/61_2815
http://www.bannerbatterien.com/en/Ba...-EFB-batteries
My BMWs
02/2017 - 10/2019: X1 F48 18i sDrive X-Line Platinum Silver with Android 10,25 Aftermarket Screen 11/2019 - Present: X1 F48 LCI 18i sDrive Connected Advanced Mineral White |
04-03-2020, 09:50 AM | #34 | |
95
Rep 268
04-03-2020, 10:09 AM | #35 | |
95
Rep 268
However, your post prompted me into action and I also ordered from Halfords as Amazon delivery date was end of April. Arrived yesterday and on the car now charging up. I also bought the 2.5m Extension Cable, the Comfort Indicator and the Bumper - all in use now. The Bumper fits around the charger and protects it from knocks. The Comfort Indicator plugs in the 12V socket and indicates the state of charge (although you can also charge the car through its connector). It indicates Green - OK, Yellow - Charge or Flashing Red - Charge NOW! I know it is Flashing Red because that is what mine was indicating . My wife's Mini is also Flashing Red (not been used in about three weeks). Last edited by Bill_P; 04-03-2020 at 10:21 AM.. |
04-03-2020, 10:17 AM | #36 |
75
Rep 383
I plumped for the msx 10 simply because I always go overboard with what I need. I have an old Accumate 3 and it was ok but this Ctek is brilliant. I have an old caravan battery bought end of 2012. I put it on the recon mode and it now has sprung back into life. Can the Ctek charge from the power sockets. My BMW bike an R1200RT has a Canbus system so use this plugged into power socket and Canbus mode selected. I think it keeps the socket live when ignition is switched off.
https://www.amazon.co.uk/Optimate-4-...s%2C138&sr=8-7
04-04-2020, 02:50 AM | #37 | |
159
Rep 458
04-04-2020, 04:58 AM | #38 | |
95
Rep 268
oakey46158.50 |
04-04-2020, 06:56 AM | #39 |
75
Rep 383
I wonder why this charger has a Canbus mode that enables you to plug in to the power socket of a Bmw bike and The X1 manual only allows jump start terminal connection. This charger also it seems, is only for bikes yet both vehicles are Canbus.
04-04-2020, 07:02 AM | #40 |
75
Rep 383
Just found out Optimate 4 Bmw Canbus is only suitable for batteries up to 50ah.
04-04-2020, 07:09 PM | #41 |
64
Rep 261
Battery Charging/Checking Battery
I have a BMW automatic "trickle" charger that I throw on when we come back from trips longer than a week or two...brings battery up to snuff in a few hours. With the COVID19 "lock down"...I'll be doing this to both vehicles every couple of weeks.
To access battery you need to remove plastic "rain shield" at the back on the engine compartment...there a just a couple of fasteners ("expanding rivets") and a rubber trim strip that need to be removed to allow you to lift cover off...front part clips into the rear part. Lift up front edge to release clips. Here's liink: https://www.newtis.info/tisv2/a/en/f...rvo/1VnYtKH5Do |
04-05-2020, 02:52 AM | #42 | |
159
Rep 458
04-05-2020, 05:39 AM | #43 | |
95
Rep 268
04-26-2020, 03:23 PM | #44 |
Rep 33
