BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) BMW E-sys coding for the f48 x1
      10-23-2019, 10:47 PM   #661
bmwmotorrad46
49
Hi all,
Has anyone code the Audio after the amp upgrade? I'm able to do it but have few questions.
1)Amp was "Not" in Multichannel - changed it to multi channel after HK Amp upgrade
2)there are more than 2 Harman Kardon settings - I tried 3 different settings but no difference
      10-31-2019, 09:17 PM   #662
bmwmotorrad46
49
Did anyone achieve updating the equalizer or somehow manage to change how audio system works via coding?
      10-31-2019, 09:32 PM   #663
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by bmwmotorrad46 View Post
hi all,
has anyone code the audio after the amp upgrade? I'm able to do it but have few questions.
1)amp was "not" in multichannel - changed it to multi channel after hk amp upgrade
2)there are more than 2 harman kardon settings - i tried 3 different settings but no difference
amplifier_variant?
Eq_variant?
      11-01-2019, 01:44 AM   #664
alfran
Drives: X1 F48
Hi folks!
I wish to disable the volume change when the engine restart using the start&stop. It is possible?
Another issue I have is the volume difference between the am/fm radio and other sources.
Can someone help me?
Thx!
      11-01-2019, 12:19 PM   #665
bmwmotorrad46
49
Originally Posted by Almaretto View Post
amplifier_variant?
Eq_variant?
I need to check that
      11-02-2019, 12:00 AM   #666
bmwmotorrad46
49
does anyone know what is WERTE value for ?
for example AUDIO_SYSTEM has hifi_system_harmankardon and WERTE = 06
what does it mean?
other than that I see AMPLIFIER_VARIANT = external , which I upgraded from HiFi to Harman Kardon Amp , is it OK?
      11-02-2019, 05:12 PM   #667
Almaretto
Almaretto's Avatar
2374
what does it mean?
Whether your values are ok, I am not sure.
F48 with 675 Hifi HK
  • AUDIO_SYSTEM_VAR: 00
  • AUDIO_SYSTEM: 06
  • AMPLIFIER_VARIANT: 01
  • MULTICHANNEL: 00
  • LOGIC7_SYMBOL: 00
F10 with 688 HK:
  • AUDIO_SYSTEM: 04
  • AMPLIFIER_VARIANT: 02
  • MULTICHANNEL: 01
  • LOGIC7_SYMBOL: 01
      11-30-2019, 06:45 PM   #668
bmwmotorrad46
49
  • AUDIO_SYSTEM: 06
  • MULTICHANNEL: 00
  • LOGIC7_SYMBOL: 00
F10 with 688 HK:
  • AUDIO_SYSTEM: 04
  • MULTICHANNEL: 01
  • LOGIC7_SYMBOL: 01
what does Werte 06 mean? I really can't figure it out
      12-01-2019, 12:45 AM   #669
Almaretto
Almaretto's Avatar
2374
https://www.bimmerfest.com/forums/sh...d.php?t=983245
      12-01-2019, 10:59 AM   #670
//TMT
//TMT's Avatar
129
I think the simple answer is that werte is German for "value" and that 6 is the code to tell the car it's an HK audio unit. But if you're not positive you're setting the right thing, you may want to not do this. There isn't any user-friendly error-checking here!
      12-19-2019, 06:23 AM   #671
Takabo
Takabo's Avatar
Japan
49
Drives: G21 320d xDrive Touring MSport
Hello,
Steering vibration intensity (menu display)
HU_NBT_EVO > 300A SARAH, 32 >
VIBRATIONSSTAERKE = gen_1 = 01 (default: nicht_aktiv = 00)
The steering vibration intensity is displayed as strong, medium, or weak, but cannot be selected. advice please. Thank you.
BMW 320d xDrive Touring M Sport(G21)
Production Plant: Munich, Production Date: 2021-02-25
      01-04-2020, 06:40 AM   #672
kentxie
Search CAF, comes up nothing
Hello,
I was able to read ECUs, then, "Edit FDL data", and finally, CAF shows up with all ECUs.
Unfortunately, when i searched CAF, with MSA, or SBR, it came up nothing, says, " No more results ", as following picture.
My X1 I-step (shipment ): F056-16-07-506, (Current): F056-19-11-534, I used E-Sys 3.27.1, and latest PSdz: v.4.21.20_PSdZData_Lite.
Any idea what my problem is? Thanks in advance!
      01-04-2020, 11:41 PM   #673
Takabo
Takabo's Avatar
Japan
49
Originally Posted by kentxie View Post
Hello,
Hello,
Your X1 I-step may be too new for Launcher Pro.
      01-06-2020, 07:41 AM   #674
kentxie
Originally Posted by Takabo View Post
Hello,
After updated to Launcher Pro 2.8.2, and i got my job done. Thanks for your concerns, anyway!
Takabo49.00
      01-30-2020, 08:30 PM   #675
Johnpaulluna
Drives: 2018 x1 M sport package
Screen display differences
Hi
I have upgraded 6.5” to 8.8”. I have have posted coding changes and info in bimmercode adventures thread. So start by getting correct model 8.8” bmw oem screen (can confirm online using part finder for your vin - most important that the version was installed during your vehicle build date). The 8.8” screen will fit 6.5” screen tray with very slight fettling (basically enlarge width at bottom edge of sides by a couple of mm each side - I used a hot are gun to soften tray and then stretched with the larger screen). Finally there are 4 coding changes (for my 2017 f48 with ENTRYNAV2 08/2017 ) in three separate locations. As this is an esys thread the VO change for U.K. spec vehicles would be SA6UN to SA6UP (or S6UNA to S6UPA) but presumably the VO code would include fdl changed for HUD as well as touch controller etc etc, which you may or may not want (but anyone doing a complete dash/hud retrofit as well I would love to hear about it).
“Using Bimmercode in expert mode HU NBT 3005 display_pip_config section
Change CID_Display_res from 800x480 to 1280x480
Change CID_Display_ size from 6.5 to 8.8
Now go out and enter 3001 section and find
Display_Variante and change from schmal (German for narrow) to breites (wide)
Now go into Nav section
Find Display_Resolution and change from 800x480 to 1280x480
In brief 4 coding changes in 3 separate section of NBT HU ecu
All changes require expert mode.
Screen works after first two code changes, nav will work also but you need to change res in nav section to get full screen effect in map view and finally section 3005 change is needed otherwise idrive home screen will only show two menu icons (like in 6.5 display) rather than 3.
In U.K. 6.5” screen sold as basic business nav package and 8.8” was sold (with touch controller and hud) as Nav plus package, (in some countries and for different BMW models, professional was separate package but also had larger screen). In the X1 the head unit and nav software are the same for nav and Nav plus and I can confirm the 8.8” touch screen works happily without a touch controller.
Finally I have read that , on very rare occasions, if after fdl coding changes, the screen display comes on but says “no signal” then (assuming the connectors have been fully inserted and no pins have been bent) this can be due to BMW hardware protection being enabled and an unlock code may be needed (online sellers exist). In theory your dealer should be able to code new screen but advice is make sure any BMW oem screen (electronics part) you buy is from reputable seller who is prepared to give you the VIN of the donor vehicle.
When you upgraded to the larger screen, did the new screen size allow audio controls to be visible?
      01-30-2020, 11:47 PM   #676
alfran
Drives: X1 F48
Originally Posted by alfran View Post
Hi folks!
Thx!
Hi guys, there are some way to solve my issue ? my X1 was built in early 2016.
Thank you!
      03-11-2020, 10:14 PM   #677
jimmylin0906
Drives: f48
Hello everyone,
did anyone enable the addional driving mode?
currently i have enable BDC to get Sport+ Comfort+ and Eco+
FesHasMode2 - Comfort+
FesHasMode5 - Sport+
FesHasMode8 - Eco+
when switch the driving mode, that did shows some driving mode change in HU and kombi, but some how in Kombi small screen did not show correctly.
think need to enable addiotnal code in Kombi.
anyone has this kind experience?
      03-21-2020, 10:07 AM   #678
Takabo
Takabo's Avatar
Japan
49
Hi Everyone,
I would like to realize a US-style side marker using LED turn signals.
Is anyone successful at F48 / F39?
Thank you very much.
      05-27-2020, 09:27 AM   #679
samuelbpereira
Brazil
Drives: BMW X1 25i 2019 F48
The same F39 production in October 2018 was done with only 5_FACH_TIPPBLINKEN Thank you very much.
https://youtu.be/DK50hAgRHac
P.S.
Does anyone know how to set up an easy entry for an electric sheet?
Hello, in my app in headunit in expert mode it does not appear as HU_NBT_EVO but as HU_NBT and with that there is no option in "3000 HMI" 5_FACH_TIPPBLINKEN. Is there another way to activate the 5 arrow flash function? My BMW is an X1 F48 2019. Thanks
      05-27-2020, 11:37 AM   #680
SDriver18i
SDriver18i's Avatar
80
Drives: BMW X1 s18i 2019
No idea dude, its here in mine.
      05-27-2020, 12:48 PM   #681
samuelbpereira
Brazil
Smile
I did it, it worked, thanks for the previous tips, if you have more cool settings in expert mode you can pass it on to me, I think there are many more cool things hidden.
      05-27-2020, 01:45 PM   #682
samuelbpereira
Brazil
Hello!
Easy entry of the power seat was activated only with the following settings.
BIMMERCODE
ECUs → Seat Module Driver(CFAS_PLX_1)→ Expert Mode → EINAUSSTIEGSHILFE → Modus_FA_SLV(Default:nicht_aktiv)
But...
The seat position of my driving position is more behind (^ ^ ;;
It seems that I do not need Easy Entry.
https://youtu.be/vqNHXLkCT9Q
Thank you for teaching me.
Hello, help me with the doubt I'm having, this change causes the bank to retreat when unlocking the car and when I start the car it goes back to the original position or do I have to click on the memory button to get it back? My BMW is an X1 25i 2019
