10-10-2019, 01:11 AM | #23 | |
30
Rep 83
If you have any suggestions how to activate it I would really appreciate your help, I am in Sydney |
10-23-2019, 05:43 AM | #24 |
Rep 2
SLI. Retrofit
I'd be pleased to pass on the details of the company in Europe.
They were an absolute pleasure to deal with. Feel free to send a private message to me, and I'll give you the contact details. Regards K |
11-14-2019, 08:07 PM | #25 | |
Dean
Rep 5
I did the same as you did but the cluster still shows --- in red circle. |
11-15-2019, 04:07 AM | #28 | |
49
Rep 69
---------- AppID 126 (0x7E) UpgradeIndex 1 (0x01) SWTType SWTclassic light FSCStatus accepted ←※Is it the same?※ FSCCertStatus not available ---------- Thank you.
BMW 320d xDrive Touring M Sport(G21) Production Plant: Munich, Production Date: 2021-02-25 |
11-15-2019, 04:24 AM | #29 |
Rep 70
Hi Sir,
Yes, I have AppId 126 as below and status is accepted. AppID 126(0x7E) UpgradeIndex 1(0x01) SWTType SWTclassic light FSCStatus accepted FSCCertStatus not available |
11-15-2019, 05:09 AM | #30 | |
49
Rep 69
Start with VO coding. And when you get “---” in the red circle, please send a PM. Investigate together for additional FDL coding. (Additional FDL items may be different in Japan and Taiwan.) Thank you.
11-17-2019, 08:48 PM | #32 | |
49
Rep 69
It is a pity that we cannot challenge SLI with "MINI F54".
06-23-2020, 05:47 PM | #35 | |
Rep 23
08-14-2020, 04:48 AM | #36 | |
Rep 4
06-02-2021, 03:41 AM | #37 |
Rep 114
Resurfacing this thread. Understand a couple of Sydney folks have managed to retrofit this and am hoping to get some guidance whether it be pointing me to a dealer or other source to get the SLI active.
For reference, have a 2016 340i LCI with all the relevant hardware Cheers Kash |
06-02-2021, 06:38 PM | #38 | |
1780
Rep 3,052
PM sent regarding SLI
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
09-25-2021, 01:44 AM | #39 |
Rep 6
04-07-2023, 06:36 PM | #40 | |
27
Rep 144
Hi,
My wife has a 2016 F48 X1 25i (Prod. Date 2016-07-07) with Kafas2 and I always assumed she didn't have SLI capabilty so I installed a chinese SLI emulator that worked well but obviously doesn't update SLI using cameras. I saw a FSC SLI online at a good price and enquired, I got this response. Quote:
What I'll do in a couple days is remove the chinese SLI emulator to see if her SLI using her FSC actually works. If SLI doesn't work correctly, I assume I'll have to do the same as my 2016 F26 X4 35d and update the Kafas2 ECU firmware to a later version, I've already downloaded psdzdata full just incase. I'll report back. Cheerz
2016 BMW F26 X4 35d, H&R spring lowered 30mm, QUAD exhausts
04-11-2023, 03:18 AM | #42 | |
27
Rep 144
Hi,
Did your wife's X1 have NBT_EVO or HU_EntryNav ECU? It's just that I've been told SLI won't work with HU_EntryNav. My wife's X1 was built 07-07-2016 and has 7E "FSCStatus accepted" in eSys. Cheerz Quote:
04-14-2023, 05:56 PM | #43 | |
27
Rep 144
Hi,
2016 F48 X1 25i, I can also confirm that SLI using the already accepted FSC code from factory works with NU_EntryNav after removing 8TD, I coded BCD_Body, NU_EntryNav, Kafas2 and Kombi. You may already know, the 2016 F48 X1 25i 5 blinker works as long as you don't check the "3 blinker" in i-Drive. After coding 5 blinker using e-Sys, it works and "3 blinker" in i-Drive is unchecked. Cheerz Quote:
01-01-2024, 05:35 PM | #44 |
Rep 2
