09-28-2022, 07:15 PM | #23 | |
378
Rep 1,001
Drives: 2007 Z4 M Coupe 2012 e93 M3
The article also mentioned other cities, state like Boston, Washington State,etc...are looking at implementing same regulations |
09-28-2022, 07:51 PM | #24 |
2091
Rep 1,478
That's my point so many other regions jump on the oh California is doing it so we should. Soon this will come down to if you remodel a home it will have to meet the new compliance standards. I am glad I renovated when I did but I am considering buying another place and I know I will be doing renovations.
09-29-2022, 10:00 AM | #26 | |
2197
Rep 1,322
09-29-2022, 10:01 AM | #27 | |
2197
Rep 1,322
09-29-2022, 10:05 AM | #28 |
2197
Rep 1,322
So right now my current house has a gas furnace and gas cooking. My water heater is some sort of heat pump style thing that is electric and insanely efficient. Although since i dont have a family I kind of want to go on-demand when I have to replace this one. I think it would use less but mainly I want the space in my garage for a little work cubby.
I had gas mainly because I had alum/nonstick calphalon pans but I have since converted to all clad and now just waiting for the stove top to have an issue so I have an excuse to convert to induction. Have one of the portable cooktops and its freaking magic. |
09-29-2022, 03:58 PM | #30 |
4207
Rep 5,728
Drives: 2019 M2 Competition
Everyone should keep in mind that most of these eco friendly laws are not enforced. I mean there's no BBQ police anymore than there's a water lawn task force. Shit in some places they barely have enough officers to arrest the murderers...
iminhell13914.50 |
09-30-2022, 08:20 PM | #32 |
your average JAMF
3101
Rep 4,094
Drives: '21 M2 Comp, '19 Golf R
Gavin has all the answers, don't worry.
'21 M2 Comp
'19 Golf R |
Marmugmotleocay1568.50 |
10-01-2022, 08:13 AM | #33 |
Go Spurs Go
3897
Rep 2,876
10-09-2022, 08:10 AM | #34 |
3570
Rep 10,351
Peeps should keep in mind that the geography and climate of California are the driver for many of these regulations.
Calif will fix their generation issues. On the bright side solar has essentially become standard on new homes in Calf and heat pumps are able to reach cost parity with gas furnace. New construction uses less power today vs older homes but ya it's going to get expensive for those living in 50 yr old homes with little to no insulation in the walls and ceiling.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
10-09-2022, 09:43 AM | #35 |
5150
Rep 3,241
My vacation home was built according to Energy Star guidelines. I was involved in the entire construction phase and saw how the builder was having their workers and subs do their work. All gaps in the sheathing, holes drilled into studs/header plates/etc, outlet/switch boxes were all spray foamed. The house came with low E windows as standard. The HVAC and hot water heater are pretty high efficiency. And the final checkout was the home had to pass a blower door test. If it didn't pass, the builder had to find the source of the leak. The final approval of the test was given to me as part of my closing packet.
Yes, it's amazing how the homes are constructed these days...although the question about if they're built to last is another. The builder for my vacation home is the same as the builder for my primary home. So I can compare the two in terms of the evolution of how the builder has evolved in putting up homes. On the topic of solar, it's a bit more complicated. Solar panels are still not all the efficient. The current ones are what? Maybe 25% or so efficient from converting the light energy into electricity. And that degrades over time. So as the panels age, the less energy output they'll have. I don't know if the inverters used in solar systems have gotten more reliable or have had their typical service life extended, but when I looked into solar a few years ago, was told to expect to replace the inverter in a few years to the tune of about $3k. Plus you have to work with local building codes. My county had just implemented a code revision requiring a setback from the edge of the roof to where one can install a solar panel. This limited the number panels the solar company I was talking to could implement on my home. And there's the issue of if there is a fire. One of the homes in my development had a roof fire with solar panels on it. Not sure if the fire was caused by something else or originated from the solar panels. But there was some pretty noxious smoke coming from the burning panels. |
10-09-2022, 03:04 PM | #36 | |
4482
Rep 5,362
How? The sun doesn't shine at night and wind usually dies down then also. Eliminate fossil fuels like Newscum and the greenies want and this state (or any other for that matter) will be ushered back into the stone age. Because of that, electric companies are paying less for power sent back to them and charging more for power used when one's solar isn't being generated. |
10-09-2022, 05:26 PM | #38 |
your average JAMF
3101
Rep 4,094
'21 M2 Comp
'19 Golf R |
10-09-2022, 07:07 PM | #39 | |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
It would take an electrician 2 hours to swap a resi inverter tops. Even at 100 an hour 1600 to have another 10+ years under warranty or just get micros with a standard 25 yesr warranty from enphase. Not to mention the average resi solar system payback is roughly 7 years if your state has decent incentives. Making money daily after that. System costs 20k paid off after 7 years. Free money after that. The modules will last 50+ years. They all have 25 year warranties with guaranteed degradation curves down to 80%. So in 25 years the modules produces 80% of it original power rating. You install solar when your are 30 and the system will last your life basically. Look at the cost of energy in your town 30 years ago to today or look at the projected cost of energy over the next 20-30 years. The KwH you produce later in the systems life are worth so damn much. Edit: This California ban is just stupid. Unless Cali starts building nuke plants wtf are they thinking being so eletric energy dependent?!?! Last edited by Torgus; 10-09-2022 at 07:21 PM.. |
10-09-2022, 08:05 PM | #40 | |
99
Rep 0
https://www.ncelenviro.org/articles/washington-d-c-passes-ban-on-most-natural-gas-use-in-new-buildings/ |
10-10-2022, 06:33 AM | #41 | |
3570
Rep 10,351
Btw. Gas ranges are ridiculously inefficient because most of the energy is wasted heating the surrounding air. Gas furnaces and gas ovens can't function without electricity anyways. California utilities have a horrible track record when it comes to leaks within the gas distribution system.
chris7197334.00 |
10-10-2022, 06:43 AM | #42 | |
3570
Rep 10,351
Sounds like California is trying to reduce methane leaks.
10-10-2022, 07:08 AM | #43 |
5150
Rep 3,241
In the case of PG&E, they have a horrible track record of maintaining their electrical lines. So much so they've been directly blamed for fires resulting in deaths of people. But that hasn't stopped this electrical push.
10-10-2022, 07:51 AM | #44 |
2197
Rep 1,322
