07-01-2023, 12:07 AM | #1 |
136
Rep 834
leaves behind grill
Leaves seem to get caught behind the grill during certain seasons. I tried to blow them out with a leaf blower … but it didn’t seem to get them all out. Anyone else have a trick?
07-01-2023, 12:39 AM | #2 |
69
Rep 52
Yeah, take off the front bumper so you can have access to the radiator. Also, take off the oil cooler guard to get the leaves in there - you won’t get them all without disconnecting the oil cooler. I saw a bunch of stuff on the side of the oil cooler closer to engine when I replaced mine
07-10-2023, 09:25 AM | #4 |
80
Rep 325
https://www.google.com/search?q=gene...h=714&dpr=1.25
Grabber with a light, if you cannot grab the leaves, they will break apart and be easy to vacuum up. |
07-10-2023, 10:42 AM | #5 | |
125
Rep 138
i now use an ego blower with an apex aire stubby nozzle, the size/diameter/circumference of the nozzle almost matches identically with the size of the lower grille allows me to fully channel the air in there and blow out all the debris much quicker , every once in a while i’ll need to use the turbo setting on the ego but still easier than trying to suck it out with a shopvac |
09-28-2023, 12:57 PM | #7 |
80
Rep 325
You can also go a step further and take off your belly pan extensions and skid plate to access the oil cooler bolts. There are 3 of them, I forget the size, but get glasses and a face mask because a tons of small rocks, leaves and dirt will fall out.
09-29-2023, 08:33 AM | #8 | |
561
Rep 442
Drives: 01' E46 325i / 16' F80 M3
Remove the oil cooler skid plate and drop the oil cooler. It is 9 hex screws to remove the skid plate and 3 hex bolts to drop the cooler. From there you can clean everything.
mr.paulo.dias
Pauldunlop13425.00 |
