BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Broken Pressure Sensor - everything needs to be replaced?
      05-02-2023, 05:04 PM   #1
swagetti_yolonese
Drives: x1
Angry Broken Pressure Sensor - everything needs to be replaced?
First of all I know very little about cars. Some details I mention below might not make sense. I hope you can still help me.
I have a bmw x1 and it's losing power. I guess it's in limp mode.
I finally got to a professional service that repairs BMWs only. First they thought that only the turbocharger was at fault. But after closer inspection the took the pressure sensor off and it was full of diesel.
Then they checked other parts and lots of them were full with diesel.
They told me the problem was very serious and will probably be very costly.
They are replacing the sensor and some pipes (?) at the moment and they will try to clean everything else. But they said the chances are pretty slim because they tried it in the past on 3 other BMWs and the issue was never fixed with cleaning.
They told me that we will probably have to replace many many parts and not just the turbocharger.
They checked with ISTA+ and the details are:
Code: 298E00
Charging pressure actuator, activation, overloading.
Existent: No.
I also have other errors but they said this was the main one.
So any ideas on what I should do?
      05-03-2023, 05:07 AM   #2
MJE60
MJE60's Avatar
England
678
Code: 298E00
Existent: No.
Sorry to read about your misfortune. The pressure sensor failing and causing leaking fuel and wider damage is a known fault, there is a thread in this forum giving more info.
https://f48.bimmerpost.com/forums/sh...ressure+sensor
      05-05-2023, 07:03 AM   #3
swagetti_yolonese
Drives: x1
Thanks. Unfortunately what was recommended in that thread, did not work for me.
So here are the errors I get:
298800- Charging pressure actuator, activation: Current too high
298B00- Charging pressure controller, output 2 (DC+), activation: Short circuit to B+
298E00- Charging pressure actuator, activation: Overloading
298A00- Charging pressure controller, output 1 (DC+). activation. Short circuit to B+
25D400 - Exhaust backpressure sensor before turbocharger, signal too high
S 0398- Power management, battery condition: Battery faulty or worn out
801189- Mixing flap drive, right Specification of desired position failed
This is what we tried so far:
- Replaced fuel pressure sensor and pipes
- Cleaned everything that was full of diesel.
My mechanic says that he thinks the next part we have to replace is the turbocharger.
Reading the thread above, everybody said the DDE control unit (engine computer module) is at fault.
What should I do?
      09-22-2023, 04:15 AM   #4
Bmwdiyeruk
Drives: X1 F48
What should I do?
I basically have the same issue and I don't know what to do next. What did you end up doing next?
      09-22-2023, 05:04 AM   #5
swagetti_yolonese
Drives: x1
I just replaced the Turbo Actuator and some wires. The turbo is 100% fine. Good luck.
      09-22-2023, 07:00 AM   #6
Bmwdiyeruk
Drives: X1 F48
I might have to do the same. Was it hard to remove the turbo, and replace the actuator? or did you take it to a mechanic?
      09-22-2023, 07:10 AM   #7
swagetti_yolonese
Drives: x1
I took it to a mechanic and he said it was a TON of work. Took a whole day to fix it.
I live in a cheap country so it cost me only $200 (actuator $100 + mechanic $100)
