05-13-2022, 03:58 AM | #1 |
Rep 2
Replacement Wiper Blades X2
Hi I've been having problems finding the right wiper blades for my X2 2018. I tried Bosch A495s which seems to be the recommended blade but it has the wrong fitting. Mine has top push button, any idea what would fit please?
Thanks Last edited by davro; 05-13-2022 at 10:12 AM.. Reason: image added |
05-14-2022, 09:46 PM | #2 |
129
Rep 426
Can you just move the old clips to the new blades?
FWIW, your clips look exactly like the OEM ones that came off my 2020, which I still happen to have. But, mine are LHD and are even marked that way. So, assuming yours is RHD, there may be a difference and you got the LHD part. |
05-24-2022, 05:21 PM | #3 | |
64
Rep 750
FYI our originals are 24" and 19" so the aftermarket one in the link is slightly larger but doesn't affect use. You can also move the clip over to a new wiper but when you do, your clip will be a little loose so I would only do this as a temporary fix. With all the searching you got to do - at one point it's just easier to order it at dealership… |
hgross881.50 |
