BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Steering
      10-01-2019, 11:13 AM   #1
Beagler
75
Drives: Sept 2019 Facelift X1 MSPORT
Steering
Had mine for a month and find the steering strange. Sometimes Steering wheel moves in my hand similar to a motorbike white-lining when the tyres are worn. I paid extra for the sport steering and tyres are at 40psi fronts.
Anyone else ?
Everthing goes to Entropy in this Age.
      10-01-2019, 12:07 PM   #2
Skyline2.0
137
Drives: 2018 BMW X1 xDrive
Anyone else ?
No steering issues in 24k miles of driving. Not sure what white-lining a motorcycle feels like. Your tire PSI seems high though. The recommended PSI is 32 on all 4 corners, but check the placard on the driver side door jamb for the appropriate tire pressure.
If 40 is high, my recommendation is to let some air out and see how it handles afterwards.
Beagler74.50
      10-01-2019, 12:26 PM   #3
Beagler
75
Tyres are 19in 225/45.
Will drop to 35 and see.
      10-01-2019, 02:02 PM   #4
Beagler
75
White lining on a motorcycle is when it runs over the centre white line and the bike moves slightly left or right of it involuntary.
      10-01-2019, 02:33 PM   #5
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
Don't assume any car actually has the correct steering alignment specs from factory. In my experience, these can be out quite a bit. Get dealer to check.
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
      10-02-2019, 08:35 AM   #6
Beagler
75
Cant believe 5psi could make so much difference. Car is fine now and ride has improved. Tried Sport Mode today..........Wow!
      10-03-2019, 09:04 AM   #7
Bluewater335D
33
Drives: E92 35D, F48 X1, M4, 911, 3.2
Just taken mine in for BMW to check - the steering wheel is "out of centre" - and not horizontal when in the straight forward position - just slightly out, down on the right.
18" wheels - I do find the ride a little bumpy with quite a lot of tyre noise, compared with say my 335D.
I'll play around with the tyre pressures - the temperature has just dropped in the UK - and the mornings are now much colder - it is recommended that tyres pressures are checked when tyres are "cold" - but "winter cold" is different from "summer cold" and all 4 tyres are now about 3psi down from when I last checked them a month ago.
      10-03-2019, 09:32 AM   #8
Jorix
73
Drives: BMW 120d, BMW X1 xDrive20d
Hm, I've owned a E90 3 series, and the X1 definitely rides smoother. Maybe you have the sport suspension?
      10-03-2019, 09:40 AM   #9
Bluewater335D
33
Thanks
The X1 is an M Sport Diesel, does that mean it has sport suspension? - I'll try to check the spec - I bought the car from BMW when it was 9 months old
      10-03-2019, 11:06 AM   #10
Beagler
75
Thanks
My M sport has sport suspension but in comfort mode its softer than my previous VW Tiguan.
      10-03-2019, 01:35 PM   #11
Bluewater335D
33
They sorted out my off centre steering wheel today with a wheel alignment, (which is what I would have done anyway, but FOC as obviously still under warranty), car has been driven 4,700 miles
      10-03-2019, 05:07 PM   #12
adi555
21
Drives: F48
Did they do front wheel alignment or rear as well?
      10-04-2019, 09:58 AM   #13
Bluewater335D
33
I never asked - but I would have thought that they only did the front
      11-06-2019, 07:20 AM   #14
Beagler
75
Finally decided to book car in at the dealer for the perceived steering problem.
I have to say they were very good and were determined to resolve the issue. Went out with a Tech but he didn't feel anything abnormal but only went 5mls. He did a health check on suspension and steering. He then put it on the diagnostic system but no faults. He then did a full wheel alignment check which did show misalignment. All in all they had it for 3 and a half hours.
It didnt cost me anything as they are claiming under warranty. Its early days but it does feel better and at least I know the car is fine.
      11-06-2019, 10:13 AM   #15
adi555
21
Drives: F48
Could you please upload the alignment report for reference?
      11-06-2019, 11:16 AM   #16
Beagler
75
Didnt get a hardcopy report just a verbal. Probably because it was done under warranty.
I think he said the KP span was out.
